What am I doing wrong with these rear struts?
Old 09-13-2007 | 09:40 PM
Hunter11's Avatar
My KYB AGX rear struts blew about 2 months ago. So I put some other KYB's on. There is now a rattling from the rear everytime I go over a bump. It wasn't rattling at first but over the last month or so it has started.
But the kicker now is that the rears seem to be blown again(there is oil all over them) except it doesn't ride like it, they aren't very bouncy like the other were when they blew.
So why are the rears rattling like they are? I believe I installed correctly. The springs are sitting on the strut right and I put the rubber on the bottom of the spring so it wouldn't be metal on metal. Everything is tight. I mean, there are only 3 bolts that could be loose. Any ideas on something I am doing wrong?
Old 09-17-2007 | 08:33 PM
Hunter11's Avatar
Anybody? I know the rear strut is an easy install and plenty of people have done it. Anything come to mind on what I could have done wrong?
Old 09-17-2007 | 08:45 PM
Nopike's Avatar
Make sure those are the correct struts for the car, correct part number. Otherwise you may have installed them incorrectly, this may help.
http://www.courtesyparts.com/betasit...1873_1877.html
Old 09-18-2007 | 08:07 AM
XJinCT's Avatar
<3's the all motor section
could be the bushing in the strut mount.
Old 09-20-2007 | 06:25 PM
nitromax's Avatar
when my rears started to rattle while going over bumps, i found that the bushing at the top was bad and allowed the strut's rod to lean to the side and tap the metal surrounding it. new bushings stopped the rattle. this problem only happened after i had replaced the original struts.
Old 09-20-2007 | 07:58 PM
Hunter11's Avatar
That seems like it could be the sound. It sounds like a metal clanking sound but I really don't think it's the spring, more like the strut rod itself. Thanks for looking out, I'll see if that fixes it.
Old 09-20-2007 | 09:48 PM
wiggafly808's Avatar
3?
Arent there three on the strut top - two on the sides (12 mm) and the one middle one from the shock (14 mm) - and one on the bottom (17 mm) holding it in?
Not sure if you just didnt count it as a bolt, or you overlooked something.
Old 09-21-2007 | 07:21 AM
cardana24's Avatar
Blown
I think you are having the same problem I am having, here is a thread I started http://forums.maxima.org/showthread.php?t=403309
it has been very frustrating to me. I have also changed my AGX's and the problem is still there. What springs are you running?
Old 09-21-2007 | 04:34 PM
Hunter11's Avatar
Originally Posted by wiggafly808
3?
I'm talking about the rear not the front. When I counted 3, I was talking about the bolts that actually hold the strut to the car. 4 total if you count the one on the strut itself.
Old 09-21-2007 | 04:43 PM
Hunter11's Avatar
H&R
I was gonna try to replace all the bushings on the strut assymbly and see if that helps. They all appeared fine but looks may be deceiving.
Old 09-21-2007 | 09:37 PM
cardana24's Avatar
Blown
H&R
Let me know if anything you do helps.
Old 09-22-2007 | 05:18 AM
Yeah, i was talking about the rears.
I think the fronts have 5, 3 on top and 2 holding the bottom in.
Anyway, good luck with your fix.
Old 09-22-2007 | 07:06 PM
rocketrich's Avatar
I had the same noise. I found out it was from not properly securing the piston rod nut (some people call this the top hat nut). This allowed the piston rod to rattle around inside the bushing and eventually all the beating made the hole in the bushing larger, which produced more noise. I think the trip is to make sure you torque down piston rod nut securely to spec to make sure it draws all the parts together tightly. I chase after that clunking noise for a long time before I figured it out. Rich
Huttig2009
09-25-2015 04:31 PM
iflexsteel
09-15-2015 04:37 AM
MaxStock
08-14-2015 10:59 PM
MaxStock
08-08-2015 02:18 AM
laparka66
08-06-2015 10:36 AM
Quick Reply: What am I doing wrong with these rear struts?
