7L:3S Three way Catalyst
Old Sep 14, 2007 | 09:01 AM
Linkage23's Avatar
I got a CEL and this is what it gave me: 7L:3S Three way Catalyst...WTF does it mean?! I got it after I hit a HUGE speed bump and my exhaust hanger ripped a small hole in my exhaust right before the muffler....
Old Sep 14, 2007 | 09:55 AM
Linkage23's Avatar
^^^Anyone? Do you know what this means?! is an internal issue or a sensor failure?! Anyone have any ideas?!
Old Sep 14, 2007 | 10:19 AM
the_3d_man's Avatar
Pretty much answered your own question huh... Might wanna fix the hole in your exhaust. The code is telling you that your catalytic converter is not working, but really it's because you have a hole in your exhaust. Least that would be my first guess. If it's a small hole just JB weld it, that stuff is the shiznit.
Old Sep 14, 2007 | 11:58 AM
pmohr's Avatar
No more Maximas...
No reason to bump your own thread after less than an hour...people will answer.
An exhaust leak at the muffler area has nothing to do with a catalyst efficiency code. Check to make sure the rear oxygen sensor didn't sustain damage. Your cat could or the rear O2 sensor could be failing.
Old Sep 14, 2007 | 12:01 PM
Linkage23's Avatar
Interesting...I think that may be a good idea, however from the cat all the way to about 3 inches to the start of the Magnaflow muffler is "full" exhaust so I wouldn't imagine the cat to be losing too much back pressure or whatever else it needs to work properly...thanks for the advice, it did turn over new stones of knowledge...
Old Sep 14, 2007 | 12:02 PM
Linkage23's Avatar
it may be a sensor indeed...I almost hit a black bear on a canyon road driving too fast and went through the ditch where I found a huge bump which released the exhaust into a marionette dance...thanks again for the advice...
Old Sep 14, 2007 | 12:11 PM
pmohr's Avatar
No more Maximas...
What do you mean it's a ' "full" ' exhaust? Full would be headers all the way back.
Old Sep 14, 2007 | 01:20 PM
Linkage23's Avatar
you're reading a little too into it...I have a y-pipe, test pipe, cat, more tube, than a muffler to clarify....
Old Sep 14, 2007 | 04:13 PM
NmexMAX's Avatar
dot dot dot ...
Why not try checking the condition of the rear O2 sensor for damage after the speed bump incident
NissanNismoZ
Sep 12, 2015 07:30 AM
minsbang
Mar 24, 2004 02:32 PM
minsbang
Mar 19, 2004 04:38 AM
JCW915
Sep 26, 2003 10:28 AM
95seMax
Sep 1, 2003 09:37 PM
