checked ECU, got three way catalyst code(72) how to fix?please help
Old Aug 29, 2003 | 02:52 AM
95seMax's Avatar
i got codes 72 and 73 and they are for the left and right back of the three way catalyst,
what would make this code come up?
what steps will i need to do to help fix the problem?
do i need a new cat?
Old Aug 29, 2003 | 07:05 AM
PoePoe2797's Avatar
No, the left and right bank 3-way catalyst refer to your y-pipe. Might wanna get that checked
Old Aug 29, 2003 | 11:25 AM
95seMax's Avatar
i just put a new budget y pipe in about 3-4 months ago
can it already be bad
is it possible air is leaking threw?
does this always happen wen u put y pipe on ?
thanks for help
Old Aug 29, 2003 | 01:39 PM
Kevlo911's Avatar
Kevlo for President
0702
Diagnostic Trouble Code 0702 points to a problem with the three-way Catalytic Converter.
The Cat is one of the principal components of the emissions control system. The Engine Control Module monitors the signals from the two front Oxygen Sensors and the one rear Oxygen Sensor. The signal frequency of each sensor indicates something about the condition of that sensor. A comparison of the frequency of the front sensors with the rear sensor indicates something about the condition of the Cat.
This malfunction was detected when the ratio of the signal frequency from the right bank front Oxygen Sensor to the signal frequency of the rear Oxygen Sensor exceeded a critical threshold value. This indicates that the Cat does not have enough oxygen storage capacity. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5. Possible causes of this DTC include ...
- Three-way catalyst
- Exhaust tube
- Intake air leaks
- Fuel injectors
- Spark plugs
- Ignition timing
0703
Diagnostic Trouble Code 0703 points to a problem with the three-way Catalytic Converter.
This malfunction was detected when the ratio of the signal frequency from the left bank front Oxygen Sensor to the signal frequency of the rear Oxygen Sensor exceeded a critical threshold value. This indicates that the Cat does not have enough oxygen storage capacity. Possible causes include ...
- Exhaust tube
- Intake air leaks
- Fuel injectors
- Spark plugs
- Ignition timing
taken from hte third link onj "help my check engine light is on"
Old Sep 1, 2003 | 09:37 PM
95seMax's Avatar
thank u so much for that info , great info about ecu codes, but would u know how i would go about to fix this problem
how would i fix :
-exhaust tube
-intake air leaks
-fuel injectors
-three way catalyst(does this mean my cat could be bad and i need a new one)
-ignition timing
i dont think its the spark plugs because they are farly new
if those problems suggested are the cause of this , how would i fix them , im not sure, also would this cause me to loose power in acceleration
thank u so much
sake1bs
Sep 19, 2015 09:32 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Slamrod
Sep 3, 2015 07:38 PM
doobadoo
Aug 15, 2015 06:43 PM
