Tie rods for 4th gen
Old Sep 14, 2007 | 03:35 PM
wirelessdude04's Avatar
Whats everyones experience replacing these on there cars?? Do they make aftermarket ones?
Old Sep 14, 2007 | 03:50 PM
accordingtou's Avatar
VQ30 DE T
The outters tend to wear faster than the inners.
Not that hard to replace.I recomend a computerized alignment.
Yes they sell "stock" "non performance"after market tierods
You will need a special tool to remove the inners (inner tie rod remover)
I shop ebay all day http://search.stores.ebay.com/World-...149511QQsofpZ0
96ItaliaSE's Avatar
il massimi bassi
http://www.worldpartsexpress.com 27 per outer rod end....oem!!
Old Sep 14, 2007 | 03:58 PM
heynow's Avatar
I got MOOG inners and outers from rockauto. All new tie-rods feel nice
Old Sep 14, 2007 | 04:27 PM
yea i gotta get a alignment sooner or later for my springs.......... Gonna change out the tie rods, cv boots, wheel bearings, and cj joints and replace all the bushing..... my suspension is goin lol
Old Sep 14, 2007 | 06:05 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Its a pain in the *** without the special tool. Get the tool, it will make the job much easier. If you dont feel like getting an alignment after or wont be getting one for a while, line your new ones up with your old ones and match them up.
Old Sep 14, 2007 | 06:06 PM
thanks for the advice guys just gotta make time to replace everythinggg
Old Sep 14, 2007 | 08:17 PM
f550maranello2's Avatar
get OEM ones.. dont be cheap DO NOT GET EBAY ONES... they are crap and will fail in like 2 months...
Old Sep 14, 2007 | 09:09 PM
Nealoc187's Avatar
SLOW
i did my outers, piece of cake. I went with OEMs.
Old Sep 14, 2007 | 10:11 PM
VQ30 DE T
You do realize some of these ebay stores are actual reputable companies.
Some are wholesale distributers that deal with your local parts store.
Heard of CARDONE?/AC/DELCO? any way not everything on ebay is "Crap"
I prefered to spend the difference on a HKS BOV & a AEM wideband.
I have no problems with my "EBAY" steering & suspension parts. Going on two years now But yeah go oem if you like.
Old Sep 14, 2007 | 10:30 PM
im thinkin OEM but might try a good aftermarket company
Old Sep 14, 2007 | 10:55 PM
96ItaliaSE's Avatar
il massimi bassi
i used moog once the oem nissan are slightly thicker in diameter
Old Sep 15, 2007 | 12:06 AM
Vlasic's Avatar
When I replaced mine I didnt use OEM, just what ever Napa gave me. The inner tie rod ends were the same thickness as OEM and the outters were beefier. Doesnt really matter, its not like your going to break one, aftermarket are fine.
Old Sep 15, 2007 | 01:39 AM
TurTLe*'s Avatar
outer tie rods are like.. loosen 1 nut, pull 1 cotter pin, loosen another nut, use a tool or hammer it out easily and spin off tie rod.. repeat backwards.
more or less those steps on all cars. Just dont really loose your place of how far the tie rod was to begin with or you will be driving with one crazy steering wheel.
Old Sep 15, 2007 | 05:09 AM
96ItaliaSE's Avatar
il massimi bassi
Vlasic -are you going to sell me the red clears if you got em? like i said I used oem ones and they were 27 a piece. I got 2 years out of aftermarket ones but i am dropped pretty low. I guess i need to see how long the oem will do.
Old Sep 15, 2007 | 11:46 AM
hey if u guys think some cheap *** ebay or autozone parts will last... get them and learn the hard way like i did...
ball joints from napa.. went bad in 1 year....
inner/outer tie rods.. from ebay... 6 months
look the oem lasted you 10 years.... y not go with them again.. u wont have to replace them again...
Old Sep 15, 2007 | 02:41 PM
TurTLe*'s Avatar
you have that arguement there about the whole ten years. but as i remember you really do have bad luck with cars in general just off the CMC problems you posted.
Yea OEM will last you 10 years but i think 60%+ of us owners right now dont plan on keeping the max for even 5 years, or will not have the same 4th gen due to other reasons.
Personally only problems i've come accross are the cheaper ebay items, autozone to me is a 65% chance of you doing the repair twice. And napa, the only things i've gotten from them is a rebuilt CV axle kit on own side and a cv axle for the other side and the have held up for 3 years now on the camry.
Old Sep 15, 2007 | 03:53 PM
bwinter7's Avatar
+1 to that,
My 93 was a 5 speed, se, abs, w/o lsd, yadda yadda yadda (this was my first car mind you, I didn't have the knowledge I do now) I ended up getting 4 different CV's from autozone, before they finally got the correct one. You have no idea how much of a pita that was, but I could take the tire off, remove the ball joint, hub nut and have the axle off in less than 5 minutes at that point, but my god, what a pain.
Old Sep 15, 2007 | 05:40 PM
guys were are talking here about tie rods... they are like 27 bucks a piece.. the oem ones...
autozone ones are the same PRICE!!!
heres autozone.... http://www.autozone.com/selectedZip,.../selectZip.htm
heres oems ones.....
http://www.worldpartsexpress.com/par...layCatalogid=0
why the crap would you buy aftermarket ones... ???
why would u not use them? i agree if the price difference was like 20 dollars a piece then i would understand... ok but its like a couple of dollars difference.....
so yea i would rather buy OEM ones... and have them last 10 more years even though the car will not....
MAXSE5SPD
Sep 17, 2022 04:00 AM
Bonka
Sep 14, 2015 11:18 PM
ef9
Sep 10, 2015 10:35 PM
Violator
Sep 9, 2015 10:14 AM
MikesChevelle
Sep 7, 2015 09:11 AM
