0505 trouble code
Old Sep 17, 2007 | 06:21 AM
federal officer's Avatar
0505 trouble code
ok guys i have a 1999 maxima given to me by mom (thanks) and it wont pass massachusetts strick emissions test because the check engine light is on. When i initialy got the car it threw a code of a map baro switch solenoid valve. I replaced the part and reset the light by the manual screw near the gas pedal. now the thing is throwing an 0505 code. i reset it the same way and after about 50 miles or so the damm thing comes right back on. any suggestions thanks in advance.
Old Sep 17, 2007 | 06:51 AM
Curt Deiner's Avatar
0505 is no fault code. Everythings ok.
Old Sep 17, 2007 | 07:09 AM
yes i know that, why is the damm light keep coming on after bout 50 miles of driving then ??? with the same 0505 ????
Old Sep 17, 2007 | 07:34 AM
Nopike's Avatar
Are you reading the code by the flashes of the check engine light on the dash or have you hooked up a diagnostic tool to the ecu to retrieve the code? If you have not checked by diagnostic tool I would consider that.
Old Sep 17, 2007 | 07:49 AM
ya just checking the flashes on the dashboard.
Old Sep 17, 2007 | 03:15 PM
Nopike's Avatar
Get it read by diagnostic tool, maybe there may be more than one code. Since this really does not make sense it is probably worth a try.
Old Sep 17, 2007 | 07:05 PM
Thanks bro i will give it a try !!!
Old Sep 17, 2007 | 09:18 PM
andrei3333's Avatar
did u reset the light ?
Old Sep 18, 2007 | 07:11 AM
XJinCT's Avatar
<3's the all motor section
check the actual solenoid. its on the air duct off the airbox, it says 'boost sensor'. see if its connected and the line isnt cut or have a hole. if all is good, hook it directly up to vacuum. that sensor doesnt do anything, its moreso just used as a check system for the maf.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
