Help! KS thread got stripped! : (
Old Sep 17, 2007 | 05:21 PM
truculent's Avatar
I was so happy I finally go the knock sensor out, I put the new one back but it took forever to screw. I pulled it with my fingers and the bolt came out! With the thread on it! The bolt looked like brand new! But the thread on the hole got stripped! What the hell do I do now? Any advice appreciated!
How long is the hole? Can I try a longer bolt hoping to find good thread deeper? Otherwise I need to take the whole intake manifold and I can't do that myself. How many hours of labor would a mechanic charge me for that? When they take the manifold out can they fix the ripped thread?
Maan, i never even got to a point where it was tight : ( May be it ripped when I first unscrewed it : (
Any advice appreciated, no transportation now : (
Old Sep 17, 2007 | 05:49 PM
TurTLe*'s Avatar
the easiest and most logical way now is to remove the manifold and just rethread the hole, this way you can properly torque the sensor on there as well.
Old Sep 17, 2007 | 05:54 PM
f550maranello2's Avatar
^^^ the mans right...
u gotta remove the bish and retap the thread... ya i know it sucks
Old Sep 17, 2007 | 07:13 PM
67whitegoat's Avatar
Normal shop labor to do a knock sensor is 4-5hrs plus what ever time it takes to repair the stripped hole.
Old Sep 17, 2007 | 07:18 PM
G4nismo's Avatar
ooooo man this ones gonna bite you. kinda sucks man. unless you can remove the manifold and have the tools to rethread yourself, your gonna pay a lot...
Old Sep 17, 2007 | 07:19 PM
truculent's Avatar
What is this?
Why can't I post a picture here?
Please open this link and tell me what the sensor that I surrounded with blue is.
http://aycu02.webshots.com/image/284...1899874_rs.jpg
There are 2 little hoses that run into the sensor. One of them broke right where the red arrow shows. I am thinking of glueing it so I can take the car to the mechanic but I don't want to take any chances. I know, I messed it all up.. : (
Anyway, to those that can help thanks alot!
Old Sep 17, 2007 | 08:31 PM
truculent's Avatar
guys, still need to find out what the senson on the link above is : (
Old Sep 17, 2007 | 09:14 PM
andrei3333's Avatar
i dont know what the sensor is, for the stripped KS hole, rim the intake off and thread it yourself, u can buy the tools at any shop
whats wit the white zip ties around the TB > nissan zip ties are black, why u need them there what are they holding ?
Old Sep 17, 2007 | 09:55 PM
oldngivout's Avatar
Willing to learn
EGR valve solenoid.
Don't bother with the glue, it won't work. You can drive just fine without it if you need to. Just get another one as soon as you can and install. They are known to go bad anyway, so look at it as preventative maintenance.
BTW, you can also safely drive the car without the KS hooked up. If necessary.
Old Sep 18, 2007 | 01:27 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Find out what the thread size of the KS hole is, then go to this site; http://www.mcmaster.com/
Pick up a tap and tap the hole yourself.
Old Sep 18, 2007 | 05:05 AM
truculent's Avatar
Great help.
Greatly appreciated too.
the white zip tie is tied to my wrench in case i drop it, because I couldn't trust my bloody hands anymore.
I will get the solenoid valve and take the car to a guy that was a mechanic at the time and will charge me $40/hr. I would love to take crack on this myself but can't do it on the parking lot..
Old Sep 18, 2007 | 07:44 AM
truculent's Avatar
Guys, this EGRC - solenoid valve is nowhere to be found online. Any ideas where to look for, or dealer the only way?
Old Sep 18, 2007 | 08:10 AM
oldngivout's Avatar
Willing to learn
Got a salvage yard anywhere nearby?
The same part is used on many other Nissans. Go there and look under the hood of some. One will have have it.
Dealer sells them new of course, may be the easiest way out.
Old Sep 18, 2007 | 11:12 AM
Vlasic's Avatar
Yeah get one at a junk yard or look around here in the fs section. That is a really expensive part from teh dealer.
Old Sep 18, 2007 | 12:45 PM
truculent's Avatar
My SGRC solenoid valve is (or should be) fine, it's just the plactic nose that the hose goes onto is broken. I'm not even sure that's a part of the solenoid or is part of the 'harness'.
I see nothing can happen to the engine driving like that but can I damage the solenoid if I drive like that? If it's expensive as u say I wana be careful.
The junk yard has just one max, a 91. I will check it satirday. Can I really use other nissans?
Old Sep 20, 2007 | 10:14 AM
Fasteddie01's Avatar
For your KS problem, simplest solution till you can pull the mainfold would be to install the 'resistor' in the harness. Then don't use low octane gas and don't hammer the gas. I went to Radio Shack, but had to buy a pkg of 25 assorted resistors. Maybe go to a TV/Radio repair shop to get only 1. Look up thread for KS resistor replacement.
truculent's Avatar
Fixed!
Not proud of they way I fixed it but so far so good. CEL disapeared and my car runs strong again on high RPM. Turned out it was the knock sensor.
I fixed the stripped thread with this permatex stuff + used 10mm longer bolt. Was able to tighten hard as I can.
The broken hose was glued with some krazyglue. After I glued it I just poured the rest of the bottle over it and when it dried it made plastic-like ring around the broken part. Breaking from that same point seems really unlikely, I was only afraid glue might get inside the hose and disrupt flow but so far car runs good.
Thanks again all!
Old Sep 21, 2007 | 12:16 PM
AceTKK's Avatar
Right on. I've heard good things about that Permatex epoxy threadmaker, hopefully it will hold up well for you.
Old Sep 21, 2007 | 02:34 PM
pmohr's Avatar
No more Maximas...
Fixed!
Thanks again all!
You tightened it as hard as you can? For one, 8mm threads (or is it 6? I forget) aren't going to take a whole lot of torque as it is (as you found out earlier), and two, the KS will be extremely sensitive as you have it, it has a torque value for a reason.
Old Sep 21, 2007 | 06:51 PM
truculent's Avatar
It's a 12mm. Then, I don't know how your car is, but on mine the EGR solenoid vacuum is right on the way so access is nothing but a b1ttch. Hard as I can is not that much but I i think I got it up to 20 lbs. May be a few more but I don't believe sensors are that precise..
If you youse that permatex thread fixer you better practice first and know exactly what you wana do. This thing goes form gel to stone for like 2 mins and for that time you have to apply it and you have to run the bolt through it and thats not the easiest task with such limited access. Its important to know ahead of time because if you apply it and dont run the bolt right away then you will have to drill through it.
Old Sep 21, 2007 | 06:58 PM
pmohr's Avatar
No more Maximas...
The head is 12MM, yes, but the threads are 8MM - the head has the least amount to do with how much torque the bolt can handle.
Old Sep 21, 2007 | 07:41 PM
truculent's Avatar
oh, you right, you right. actually permatex is rated like 16 lbs for 8mm. So if it werent for the 10mm longer bolt I would have stripped it again.
Whats wrong with more sensitive? I don't want to run the engine with predetonation.. small or big predetonation.. I dont care..
Old May 19, 2008 | 03:39 PM
shadyonedeath's Avatar
how would U rethread the hole if its stripped? Wont you have to go a size bigger, which in turn wouldnt fit the Knock sensor hole?
Old May 19, 2008 | 04:57 PM
A99MAXIMA's Avatar
you cold have someone tig weld the hole shut, then redrill and tap it.
Old May 19, 2008 | 05:51 PM
z32drifter's Avatar
I think a Helicoil or a Threadsert would be a eaiser and just as strong a repair.
Old May 19, 2008 | 06:00 PM
pmohr's Avatar
No more Maximas...
And welcome to a post from 09-17-2007, 08:21 PM
Old May 19, 2008 | 06:01 PM
pmohr's Avatar
No more Maximas...
Come on, I know you know better than this... OP: 09-17-2007, 08:21 PM
Old May 19, 2008 | 06:11 PM
Who gives a ****, is that all you have time to do? Call out dates? Its a similar thread about my problem. Get off your high horse Internet Cop.
Old May 19, 2008 | 06:14 PM
pmohr's Avatar
No more Maximas...
Yep, that's what I do 24 hours a day, 7 days a week; troll here trying to point out problems.
Old May 19, 2008 | 06:18 PM
Sarcasm is the lowest form of wit.
Old May 19, 2008 | 06:27 PM
pmohr's Avatar
No more Maximas...
Who's trying to be witty or sarcastic?
Seriously, I'm on here 24 hours a day, 7 days a week.
Old May 19, 2008 | 06:49 PM
Coolsaber57's Avatar
Just one more pwn and you'll get 6000!
Old May 19, 2008 | 06:53 PM
pmohr's Avatar
No more Maximas...
pwn.
Thanks, I didn't even notice. Haven't kept track of my post count in a while, actually. Ever since I stopped going into the Friday threads
Old May 19, 2008 | 07:18 PM
G4nismo's Avatar
pwn.
congrats! you have reached 6000 posts, you have no life...
Old May 19, 2008 | 07:42 PM
pmohr's Avatar
No more Maximas...
That news is even older than this thread
Old May 19, 2008 | 08:15 PM
QNO_A32's Avatar
"congrats! you have reached 6000 posts, you have no life...
" actually made me laugh out loud haha
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
RealityCheck
Oct 2, 2015 06:34 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
