What size is the Axle Nut?
Old Sep 21, 2007 | 12:31 PM
palaman's Avatar
Like many .org'ers, my suspension is dieing so I have been doing a suspension overhaul as well as my CV boots. I have a 98 Max.
I went to remove the axle nut (wheel bearing lock nut) and realized I don't have any sockets or wrenches that are large enough. The biggest I have is 1 1/4". My Chilton Manual only says "235-314 (24-32, 174-231)" which I believe are the torque values ... but no size for the nut.
So I guess, I need to go pick up a socket ... but I don't know what size to get Please help!
Also, if you can clarify what the numbers above stand for that would be great.
Old Sep 21, 2007 | 12:32 PM
Kevlo911's Avatar
Kevlo for President
Drivers side 36mm and pass side is 32mm IIRC
I have seen 34mm on replacement axles
Old Sep 21, 2007 | 12:35 PM
maxima985spd
I thought they were both 36mm.
Old Sep 21, 2007 | 12:37 PM
palaman's Avatar
Thanks, for the quick response!! Sorry, but what does IIRC stand for?
Also, why in the world would they be different on each side?
maxima985spd
IIRC = If I Recall Correctly
Old Sep 21, 2007 | 12:41 PM
Adrian112597's Avatar
Adrian
I think that's the only part I need besides the cotter pin. Anyone know for sure, thanks
Old Sep 21, 2007 | 01:52 PM
GStrength's Avatar
man they both 36mm aint no different size on either side, both exactly the same, oh yeah get yourself a breaker bar and another pipe for leverage if you dont wanna injure your back.
Old Sep 21, 2007 | 01:56 PM
cardana24's Avatar
Blown
truth......
Old Sep 21, 2007 | 01:57 PM
spdfreak's Avatar
36mm iirc.
Old Sep 21, 2007 | 02:01 PM
tvis's Avatar
Yeah, why would there be a 36mm and a 32mm?
..... Although, my MR2 does have a 32mm on one side and a 31mm on the other side, but thats because some A-hole that worked on the car before me put an NA size on one side and a Turbo size on the other side. Freakin half assed people.
Old Sep 21, 2007 | 03:25 PM
chillin014's Avatar
im gonna go check right now. one reason could be that we dont have the same ammount of power going to both wheels though??? just a guess.
brb
edit-both the ones i checked were 36
Old Sep 21, 2007 | 03:47 PM
KRRZ350's Avatar
There all always 36 both side's, maybe somebody put a 5-g one on your car kevlo? And yeah, I've also seen replacement axle's come with a smaller nut as well, big flanged fawker instead of the stock style.
Old Sep 21, 2007 | 03:50 PM
Kevlo911's Avatar
Kevlo for President
My pass side is 32mm, but I do have replacement axles so....
Old Sep 21, 2007 | 04:05 PM
maxima985spd
I bought a 36mm socket and it fit both sides...
Old Sep 21, 2007 | 06:16 PM
rocketrich's Avatar
Just did this today! My new revelation is...pneumatic tools rock!!!!! I bought the cheapest Sears impact wrench and it made short work of the 36mm nuts on both axles. Why did I wait so long to get this thing? Rich
Old Sep 22, 2007 | 08:33 AM
palaman's Avatar
where can you get a socket of this size????? Not at Sears or Home Depot
I am currently checking with Lowes ... but no one is in that department.
I can order it through Sears.com but I wanted to use it today ... time is wasteing away
I am sure specialty shops would have it but will also charge up to kazooo ...
Old Sep 22, 2007 | 08:43 AM
RA030726's Avatar
I'm nutty for Nissans
32mm is from 5th gens, which some axles are the same so its fits. My 01 VLSD axle came with a 32mm, but I reused the original 36mm.
Old Sep 22, 2007 | 08:51 AM
maxima985spd
Sears will have it. If they didn't then it was out of stock, but the stores do carry them.
Old Sep 22, 2007 | 11:25 AM
GStrength's Avatar
All you needed was that braker bar and a leverage pipe.
Old Sep 22, 2007 | 05:58 PM
rocketrich's Avatar
I bought my 36mm socket at Pep Boys, when I checked they had both for hand tools as well as for pneumatic tools. Gotta love Manny, Moe, and Jack!
Old Apr 16, 2013 | 08:12 PM
aliltipzy's Avatar
Actually i just started a transmission swap and was suprised to see that the drivers side axle was 36mm and the passenger side is 32mm.
Old Apr 16, 2013 | 08:41 PM
Nealoc187's Avatar
SLOW
i have never seen a 4th gen with different size axle nuts from one side to the other, personally. and I've owned 4 of them. all are 36mm in my experience.
Not sure why you felt the need to reply to a 6 year old thread however.
Old Apr 17, 2013 | 03:27 PM
RA030726's Avatar
Replacement axles may come with the 32mm or 36mm nut. You never know what you'll get.
Old Apr 17, 2013 | 05:59 PM
asand1's Avatar
OE is 36mm and NOT castleated. This is the castellated 32mm nut that came with my crappy APWI axle. I reused the OE 36mm nut and retainer.
Old Apr 18, 2013 | 11:24 AM
BlackThornDemon's Avatar
100% sure? Cause that means my cv axles aren't stock (they're castled). And, seeing the condition of my car, I'd be surprised if the previous owner replaced anything on it.
Old Apr 18, 2013 | 12:06 PM
Fauken's Avatar
Yup, not castled at all.
Old Apr 18, 2013 | 12:17 PM
Phromethius's Avatar
Same. I had a mechanic replace my CV axles from stock and he is cool enough with me that he brings out each greasy part and shows me what he's found. My 96 had castled nuts. /shrug
Old Apr 18, 2013 | 02:33 PM
Trini Boom's Avatar
Anything other than 36mm is questionable...both sides should have the same size.
Old Apr 18, 2013 | 07:20 PM
DennisMik's Avatar
Replaced both the axles on my 97 last year. They were the original Nissan axles and both nuts were the 36mm non-castle type.
Old Apr 20, 2013 | 12:15 AM
Logan30's Avatar
36 MM 0n both sides, I´ve just confirmed it when removed both axles to change my clutch.
Old Apr 20, 2013 | 08:51 AM
Fauken's Avatar
I found out while doing the upper oil pan yesterday that one of mine is a 35mm.
Old Apr 20, 2013 | 01:22 PM
asand1's Avatar
Axle nut is 36mm and not castellated. It has a stamped steel retainer that fits over it and interlocks with the cotter pin.
13-wheel bearing lock nut
14-insulator
15-adjuster cap
16-cotter pin
Originally Posted by palaman
My Chilton Manual only says "235-314 (24-32, 174-231)" which I believe are the torque values.
...if you can clarify what the numbers above stand for that would be great.
Look in the lower right of the image for the key.
N*M (kg-m, ft-lb)
235-314 Newton Meters
24-32 kilogram meters
or
174-231 Foot/pounds
Dependent upon what country you live in, and what kind of torque wrench you have.
If your mechanic is good, he re-used the OE nuts and retainers and placed the crap aftermarket castellated nuts on the old axles.
Old Apr 20, 2013 | 02:47 PM
174-231 Foot/pounds
Didn't realize Brian Shaw torqued Nissan's nuts. [/no pun]
Old Jul 7, 2022 | 12:57 AM
the real deal's Avatar
Y’all have me so pissed off right now because I read this thread.
IT IS NOT A DAMN 32 mm it is smaller like a 30 or 31 mm and I took mine apart but I went and got a 32 mm socket and it’s too big so ty so very much for wrong info that has me in a bind now
Old Jul 7, 2022 | 06:57 AM
RA030726's Avatar
These cars are old. Who knows what's been replaced. Can't fault anyone on here.
Old Jul 7, 2022 | 09:24 AM
KP11520's Avatar
Digital Calipers are cheap on Amazon. So cheap, there's no excuse not to have one to remove guess work.
Blame everybody else for your choices. It's going to be a long, and rough road.
Great First Post!
Old Jul 16, 2022 | 08:47 AM
vqmaxman's Avatar
Nissan OEM nut size is actually a 32mm nut I just ordered a OEM axle and it came with an OEM 32mm nut. The aftermarket Napa axle I had just replaced the nut was a 36mm. The aftermarket axle nuts can come in any size.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
