99 ECU, Manual & Automatic the same?
Old Sep 25, 2007 | 12:26 PM
Thahman's Avatar
So I went to start my car this morning, and it cranks but it won't turn on... it doesn't sound like a battery/alternator issue... so I get it towed to a place down the street, and they're telling me that the crank position sensor is working but the injectors aren't getting a signal from the ECU. They took out the ECU and told me that they're also not getting a signal from it to the injectors... anyway, my question is - are all 99 ECUS the same, Automatic and Manual? I have a Manual...
And has anyone ever had a similar problem to this? I'm going nuts!
Also.... does having traction control, or FED vs Cali spec change it completely?
My car is:
1. MANUAL
2. Cali-Spec
3. No TC [Hence the manual]
Old Sep 25, 2007 | 01:15 PM
Fearfox's Avatar
the auto and manual ecu i believe are different. One thing i would be concern about is the 98-99 have chip in the key and would be curious by swapping the ecu if you would have to re-do the ignition key.
Old Sep 25, 2007 | 09:04 PM
oldngivout's Avatar
Willing to learn
If you are not getting a signal to the injectors on a 99 model Max, then it is very likely that you have issues with the immobilizer system.
This is precisely how the car is disabled when the system is working properly, that is, sensing a wrong or unchipped key in the ignition switch.
This is a dealer or big town locksmith fix.
Old Sep 25, 2007 | 11:01 PM
Thahman's Avatar
Wow, I actually was playing with that today... but how can I go around that? Is there a way to bypass it or something? When I first turned the car on, it sounded like it was getting gas, but then decided not to start up, and didn't get any gas from that point on....
PLEASE let me know if there's a way around it.
Old Sep 26, 2007 | 12:31 AM
Thahman's Avatar
Also... yah I've been using the same key - is it possible for it to have lost its signal/encryption, whatever you'd call it?
Old Sep 26, 2007 | 05:53 AM
oldngivout's Avatar
Willing to learn
No way around it that I'm aware of. Maybe someone else knows, but Consult 2 with the NATS software is the only thing I know of. Dealer only.
Old Sep 26, 2007 | 07:42 AM
Thahman's Avatar
Hmmm, I didn't think an already programmed key could go bad... unless something is wrong with the actual unit underneath the dash...
this bites because i don't want to spend the money on an ECU if that's not even where the problem lies...
Old Sep 26, 2007 | 01:38 PM
tlrmax's Avatar
My car key lost its code all of a sudden. It would crank but not start. I used my spare key and it started fine. So I had a friend at nissan and they reprogrammed the key for free and it all worked fine then.
Old Sep 26, 2007 | 02:17 PM
Thahman's Avatar
Yeah so I guess I'm going to have my car towed to Nissan tomorrow- as I only have one key. I'm crossing my fingers that it works.
Old Sep 27, 2007 | 03:59 PM
Thahman's Avatar
phew...
I'm sooooo relieved. I had the car towed to Nissan today...
They recommended that I get the newer upgraded ECU (1700!)
But I told em to chance programming me a new key... and it worked... so I'm using my old key as a back up
Old Sep 27, 2007 | 08:47 PM
oldngivout's Avatar
Willing to learn
Did they also include the old key in the reprogramming process?
If not, then it will not work anymore. The reprogram erases all previous keys. Must do all keys at the same time.
Of course it will still open the door, it just won't start the engine.
Old Sep 28, 2007 | 09:23 PM
Thahman's Avatar
Yah... so they cut me a new key, and they reprogrammed the old one. .which the highly recommended i don't use..
total cost.. 165.00
Old Sep 28, 2007 | 09:45 PM
nsnrider's Avatar
i also had problems with the 99 max key "loose" the info.
hope it doesn't happen again, only have one key at the time.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
ef9
Oct 4, 2015 08:43 AM
