Need indepth clarification of these codes.
So my SES lights came on and i pulled up these codes
0701 - Random misfire
0210 - Fuel system lean/ Bank 2
I changed my plugs about 2 weeks ago, and thats when the light came on. I've combed the web and the org but havent found anything thats indepth enough.
My MAF is apprently fine, because i did a few tests and it passed.
Is it my 02 thats throwing the bank 2 code?
How many does 02s does my car have and which side am i looking at replacing?
I have a 98 SE.
Did i mention that its revving high too? This happened after i cleaned the throttle body. And i just replaced the fuel filter, so with all these things mentioned, can someone tell me what it is that i'm doing wrong?
someone please give me some insight.
P.S: Does anyone know other MAF test? I did a couple which shows its working fine, but i'd like to know what worked for you.
I have a 98 SE.
I did, and have had a second person double check it, but still the rpm is really high and it fluctuates between 1000-2000.
When i first start the car, it jumps to 2200, then drops to about 1500, then 1000 eventually.
Some suggest i try disconnecting the MAF harness and drive it. The car was hesitating BIG time, i couldnt even drive 2 meter and plugged it back in. Is my MAF truely gone or is it just a bad TPS?
Bare in mind the 0210 code i pulled.
I had one problem which was the rpm dropping to 500 from 650 sometime. so someone suggested i clean the throttle, and thats when the problems started.
As for the TPS i think the most i did was maybe unplug it and put it back.
How do i check to see if its off, and if it is, how do u reposition it?
CorollaULEV
30
Aug 9, 2021 08:11 PM
jchronis2552
Sep 21, 2015 05:52 AM
jholley
Aug 11, 2015 09:38 AM
Matt93SE
32
Oct 17, 2011 04:13 PM
