need help my car wont start
so i just installed my cattman full exhaust and did my 5speed swap and now im having stating issues.
i changed my spark plugs b/c they were old and flooded with gas
i checked all my gaskets and looked for any header leak and its all good
the car cranks but doesnt start and i check the plugs and they look like my engine is getting to much gas please help thanks in advance
I think you have the dreaded bad ground to the starter after a tranny drop.
Look below....
Install seperate ground between transmission bolt, and on the block. Do not do what i did and tryed ground other places. It will not work. Just take time, ground to a mounting bolt on transmission to block. I have told my friends locally to sand block matting surface and transmission mounting surface.
Its not your starter....
http://forums.maxima.org/oldthread.php?t=452286
Transmission doesnt matter for the starter they all fit the same 95-01.
Assuming you have no codes I still think it's the ground issue, even on my car grounding wires didn't help 100%, only when I wirewheeled all four starter and bellhousing surfaces did I get perfect starts.
I can't thank Crazy enough, when I had the hard starts my muffler filled up with so much raw fuel that it violently exploded on the highway. The problem has stumped me and countless others.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
