Clearing my tails right now! questions!!... please!...
Old Oct 19, 2001 | 11:50 AM
NYCe MaXiMa's Avatar
I got all the stuff I need, big **** sheet of flourescent light cover from Home Depot, just removed 1 tail.... about to put it in the oven since i have no heat gun..... ok, so it's 250 for 15 minutes?????????????
Also, do i need to remove the bulbs from the housing ? can they sustain the heat of the oven???????
thanks!!!! check back i'll have more along the way!!!!.....wish me luck
Old Oct 19, 2001 | 11:55 AM
Sprint's Avatar
oven?
wake me up when you are done
Old Oct 19, 2001 | 12:08 PM
Originally posted by SprintMax
oven? :laugh
wake me up when you are done :laugh
:hammer:
GOOD NEWS!!!!!!!!!! It's heated I just got it out!!!!!! It fakkin came apart like butter!!!!!!! WOO HOO!!!!!!! no cracks!!!!!!!
Old Oct 19, 2001 | 12:15 PM
GaMax97GLE's Avatar
Great, a techique I could have known about months ago. Now I have to live with my crack.
update!!1
I got the orange piece out and the little red reflector out too!!!!!! Cutting out the flourescent light cover now!!!!!! taking pics along the way!!!!!
Old Oct 19, 2001 | 12:21 PM
Miguel97GLE's Avatar
Re: update!!1
Good luck with the cutting. You're gonna need it.
Miguel
Old Oct 19, 2001 | 12:24 PM
Re: Re: update!!1
Miguel
DAMN!
youre right!!!!!!!
That **** keeps cracking.... ***!
I'm looking for a glass cutter right now, i think that should work better, forget about scissors or a sharp *** knife... dammit... this is probably the hardest part.....
Old Oct 19, 2001 | 12:35 PM
DAMMMMNnnn
what can i use to cut out the light cover???? everything i put to it makes cracks around the edges.... I'm about to try a dremmel tool.... shietttt...
Old Oct 19, 2001 | 12:45 PM
WOOHOO!!!!!!!!
I got it!!!!!!!!!!!!!!!!!!
Freaking Dremmel tool works like a charm!!!!!!!!!! haahahahahahahahaa!!!!! i'm almost there!!!!!!
Old Oct 19, 2001 | 12:47 PM
99MAXSE-L's Avatar
i almost tried doing them...but too scared...this is like a live coverage of u doing ur tails!! lol
good luck, tell us how it turns out, along with tips!!
Old Oct 19, 2001 | 01:00 PM
njmaxseltd's Avatar
TIP !
I'll give you a tip regarding clean up. The glue that holds the assembly together is messy stuff. You can use a nice cleaner/wax such as Meguires or Mothers to clean up any glue which got on your lenses. Works like a charm! Makes them shin up nice, inside and out!
Old Oct 19, 2001 | 01:20 PM
«§»Craig B«§»'s Avatar
I've never done it since I have a 3rd gen, but heard MAC talking about it before and he said get a putty knife (or other flat wide blade) and heat it up on the stove top for a little while and then it will cut through easily and make very straight, precise cuts
congrats on your work so far; sounds like it's gonna turn out nice (for a 4th gen )
Old Oct 19, 2001 | 01:59 PM
Damn, i should have thought of that.... I'm about to try it!!!!!! I took a break but I'm getting back to it and I wasted a whole bunch of the flourescent light piece!!!!! i cut out like 4 and they are all not good in size!!!!!!!! what a ****ing pain!!!! it's all crooked and stuff and you can see the edges messed up...... I'm going to heat up a knife right now..... gottdamn... i've been at it for over 2 hours and i'm still on the 1st tail!!!!!!! thanx for the tip Craig, i'm going to cut out 2 covers if it goes ok, i'll keep u guys informed!
Old Oct 19, 2001 | 03:16 PM
ok.... i cut out 1!!!! what a ****ing pain... and as i was trying to snap it into place, a little corner of the flourescent light cover snapped off!!!! ****! well, i wasn't about to cut another 1 out so i just crazy glued it back and closed it up..... Now i have a question...
When re-sealing the tails, they don't line up exactly as the tails were heated the 1st time I bet they melted out of their shape a little so how do i seal them back? heat them back up???? i dont have a heat gun.....
Old Oct 19, 2001 | 03:21 PM
Hmmm
Are you using a template? If so how did you make it? I made mine using both the amber and red pieces. I then cut the plastic to be a bit too large using the flat dremel cutting bit. Once cut I used a sanding bit to grind the lense down to size. Lastly to minimize the chance of breaking the lense I installed it by placing the ends inside the housing and slowly pushing down in the center until the lense snaps into place. Worked like a champ.
Miguel
Old Oct 19, 2001 | 03:59 PM
Re: Hmmm
Miguel
dammit.... i did the same thing actually... but when i was snapping it back into place... i fukken broke off a small corner of the flourescent light cover....that came out a little fukked up, especially after resealing it, there is moisture build up in that place.... but i did not crack the lens!!!!! i managed to mess up somehow.. it's fixable... i need to re-open the tail again and make another flourescent light cover and replace that 1 with it..... But for now it's ok....
Well..... i think i'm done for today!!!!!! i did 1 tail.... i now have 1 clear and 1 amber tail! Tomorrow i'll probably do the 2nd.... it looks ok, when i put everything back in place the crooked edges of the flourescent light cover aren't that visible.... but the damn moisture sucks ***..... also, i melted the tails pretty bad, and they aren't very straight anymore, and i didn't seal them back well enough, 1 corner is sticking up..... not too bad, i took some pics..... let me upload them now......
I'm definately going to re-do this tailight in the future.....
Old Oct 19, 2001 | 04:55 PM
Uhhhh.
my damn Digi cams batteries died (as always) so I was only upload a few phots..... I got tons more.....
Here is 1 shot, i already put them tailight back onto the car.... Check it out,,, if u can't tell, there is a small screw up on the lower left part of the newly cleared tailight.... a piece of the clear flourescent light cover snapped off and i glued it back into place... but when i put everything back together and heated it... moisture build up inside next to it... as u can see, it's a little foggy and shiet... but it's fixable... plus the top of the light is so melted down it is not even that straight anymore... i couldn't seal it that well so it buldges slightly..... none of these things are very visible unless you are right there a few feet from it... check it out:
Old Oct 19, 2001 | 08:04 PM
190hpKiLLA's Avatar
Granny Driven
Re: Uhhhh.
Told you I should of done it for you. My lenses are priceless. I put an alarm just for the lenses, so no one takes them.
Old Oct 19, 2001 | 08:16 PM
Re: Re: Uhhhh.
i can't afford your lenses man! lol.. if i knew of the hassle... i probably would have held over until i got a job and had some $.. but i decided to try it out, since a big sheet of that light cover cost me maybe 5 bucks? I didn't even use a heat gun because I can't afford 1
Your tails look great, how did u cut the flourescent light cover out to fit? Only thing i'd do different on your car is take out those little red pieces in the corner
Old Oct 19, 2001 | 08:20 PM
190hpKiLLA's Avatar
Granny Driven
Re: Re: Re: Uhhhh.
All you had to say is. VAl I need your help I will pick you up and we will do it together.(Val has all the tools, Val is the man) But Nooooo you didnt. Remember the job I offered you. Did you ever call. Well drive with kia looking light now.
Old Oct 19, 2001 | 08:56 PM
Re: Re: Re: Re: Uhhhh.
I know man. I know.... no excuses.
It doesn't look like a KIA! Let me get to the 2nd one... i'll make it better.. if not, i'll drive around with ugly tails until i can get some used tails elsewhere and mess them up all over again... or just let u do it. We need to discuss your car, i've heard you've done a few things.....
Old Oct 19, 2001 | 08:58 PM
Vinipux's Avatar
Re: Re: Re: Uhhhh.
dude, don't put it in the oven for that long, put it on 250 for about 2-3 minutes, tops, it'll take little longer getting it out but it won't melt, mine didn't, I just have to paint mine now, I have 'em all clear because they're for my 95 max
Old Oct 19, 2001 | 09:11 PM
thanks, i figure 15 minutes is too F-in much. I managed to melt 1 a little bit... tomorrow i'll do the 2nd one, i'll try 7-8 minutes this time...
Old Oct 20, 2001 | 08:02 AM
Vinipux's Avatar
Re: Re: Re: Re: Re: Uhhhh.
NOOO, that's still too long man, do it for 4-5 tops, otherwise it'll start to melt, if that's not enough you can always put it back in the oven
Old Oct 20, 2001 | 08:35 AM
Re: Re: Re: Re: Re: Re: Uhhhh.
alrite... let's try 4-5 i really don't think that's enough.. but 15 is outrageous.. That is why the lens is a little curved and stuff. It melted so bad that while pulling it off gently i was able to mold it into another shape I might Re-do this tail light today
pears
Sep 18, 2015 05:25 AM
Steven Orozco
Sep 12, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
Johnny9595
Sep 3, 2015 05:18 AM
