Engine light on!! Code 01-02. Mass Air flow Sensor
Old Oct 19, 2001 | 12:38 PM
2THEMAX
I need to know how to get my engine light off for the code 01-02. I removed my mass air flow sensor and put it back in and my light came on? Can someone please reply with some usefull information.
Thanks alot
Old Oct 19, 2001 | 01:08 PM
clee130's Avatar
This is covered in the sticky at the top of the forum: http://forums.maxima.org/showthread.php?threadid=45274
Old Oct 19, 2001 | 01:18 PM
Sonic's Avatar
It problably will return. You may need to order a new one.
Old Oct 19, 2001 | 08:02 PM
WaarrEagle's Avatar
Re: Engine light on!! Code 01-02. Mass Air flow Sensor
Thanks alot
Are you sure you plugged it back in? One time I left mine unplugged and I got a code.
Old Oct 20, 2001 | 03:12 AM
Dahnryman's Avatar
i had that happen
i reset the ecu...by turning the screw lef then right then back left i think.......but the light did not come back on afterwords...so i knew it was ok....if it does come back on afterwords....but the car seems to run fine and not funny idal....you may see if you read the code right....
good luck
CorollaULEV
30
Aug 9, 2021 08:11 PM
homeyclaus
Sep 3, 2015 06:15 PM
bc992164
Aug 26, 2015 12:19 PM
maxinout93
Aug 20, 2015 02:17 AM
Samedi
Aug 13, 2015 04:05 PM
