The perfect 4th Gen tool box
Old Oct 2, 2007 | 08:12 PM
clh288's Avatar
I'm not sure if I am the only one, but I keep a small tool box in my trunk just for my maxima. I like to be ready for anything that might happen on the road and I also like to go to u-pull it junk yards. Here is what I keep in mine, I might have forgot one or two.
1. A multi tipped screw driver
2. A very stubby Phillip's head screw driver
3. Oil filter wrench
4. An adjustable wrench
5. A metric ratchet set
6. Tape mesure
7. Pliers and needle nose Pliers
8. Flash light
What tools do you think are accentual for any 4th gen maxima owner?
Also what spare pairs, if any do you keep close at hand, because you just know that they break often in 4th gens?
Old Oct 2, 2007 | 08:17 PM
maxima985spd
mine is reliable
1. cell phone
2. AAA in phone book
Old Oct 2, 2007 | 08:18 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by maxima985spd
mine is reliable
How's them axles?
A cell phone
j/k...it is a good idea to keep a few tools.
Old Oct 2, 2007 | 08:22 PM
NmexMAX's Avatar
dot dot dot ...
My needle nose pliers are nestled in between my trunk net and and a Nestle Crunch candy bar.
Old Oct 2, 2007 | 08:30 PM
maxima985spd
Old Oct 2, 2007 | 08:36 PM
shaft369's Avatar
New to *****
Muti tip Screwdriver (real cheap but great for unscrewing the corner lights then pulling that shaft out and reversing it to the flat head and popping out those bumper lights)
Basic Socket Wrench and Set
Maglite (of course with the upgraded LED bulb)
last but not least GIRLFRIEND, in case i break down somewhere and need something to do while i wait for AAA
Old Oct 2, 2007 | 10:44 PM
MorpheusZero's Avatar
i usually lug around a full toolset (3/8", 1/2" drive socket wrenches and torque wrenches, full metric socket set/deep sockets, spanners, bit driver+screw drivers etc), a 6 D cell maglite and a inova X0, sometimes a floor jack and stands.
i want to figure out a way to mount my floor jack in the trunk.
what can i say, maybe some hot blonde will be stuck by the side of the road in the dark some day and she'll bang me to fix her car on the spot
maybe i should add condoms to that list...
Old Oct 3, 2007 | 04:41 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
I just carry one of those 125 piece Stanley multi set kits that you can buy at your local stores. So far I've be able to get by with it.
Old Oct 3, 2007 | 05:25 AM
3 point slow's Avatar
I just keep adding to mine as I need them. Slowly, all my tools are finding their way into my trunk. It all started with a prop rod to hold my hood open. lol
Old Oct 3, 2007 | 05:31 AM
heynow's Avatar
lol @ MorpheusZero
Old Oct 3, 2007 | 05:45 AM
Pimpmobile's Avatar
2 O2 sensor sockets, since you will crack one for sure getting the rear o2 off...
that was fun
Old Oct 3, 2007 | 05:50 AM
Double E's Avatar
Extra starter?
Old Oct 3, 2007 | 05:51 AM
wetzelman1's Avatar
vice grip, best way to hold that hood open.
Old Oct 3, 2007 | 06:31 AM
ZachsMax's Avatar
Ridin' Spinnaz
They'd melt
Otherwise a very solid idea.. pockets work though!
Old Oct 3, 2007 | 07:09 AM
max ride 41's Avatar
christ, vice grips??? there easy to do and fairly cheap so why would you not fix them?? best thing i did after i got my ride was replace those hood struts. friggin reminded me of when i had a 72 toyota corona and could'nt afford to fix anything on it. and, the best defense against problems is common sense. keep up with the maintenece and you wont have to worry so damn much.
Old Oct 3, 2007 | 07:49 AM
aznprid972's Avatar
zip ties, possibly spare fuses, rubber gloves (optional if you're manly enough), shop towel (also optional but helpful in case of spills)? All of those have helped me out at times before.
Or... just macgyver it and carry a paper clip at all times.
Old Oct 3, 2007 | 07:52 AM
GodFather's Avatar
Made in Taiwan
Don't forget Orange Clean for hands.
Old Oct 3, 2007 | 08:11 AM
Tatanko's Avatar
Bacon Lover
I keep a 10mm socket (w/ ratchet), an 8mm open-ended wrench, a flat-head screwdriver, and a roll of duct tape (yes, seriously) in my glove box. I figure anything that would require more tools than that shouldn't be dealt with on the side of the road.
Old Oct 3, 2007 | 08:21 AM
I think anything you can fix with duct tape you probably shouldn't.
IBwd40andducttapebishess
Old Oct 3, 2007 | 09:46 AM
Tatanko's Avatar
Bacon Lover
Well, when you're at the track and your intake falls apart, and you're a 2 1/2 hour drive from home, and it's a quick, simple fix...it's a little different
Old Oct 3, 2007 | 10:23 AM
NmexMAX's Avatar
dot dot dot ...
I keep a 10mm socket (w/ ratchet), an 8mm open-ended wrench, a flat-head screwdriver, ............... I figure anything that would require more tools than that shouldn't be dealt with on the side of the road.
QFT. . . .
Old Oct 3, 2007 | 12:37 PM
Fr33way™'s Avatar
Wild for Width
Tiny screwdriver that fits the AGX ****. That's it except for track days.
When there's something real going on under the hood I will keep a basic set in the car.
Old Oct 3, 2007 | 01:02 PM
MaximaSpd85's Avatar
you know what...this is absolutely correct and i think i need to go ahead and remove my completely full tool box AND the the craftsman tool set on the other side of the trunk. Its making my rear end sag a bit
Old Oct 3, 2007 | 05:23 PM
JtzMax's Avatar
Whatchyou say?
Morpheus ... HAHAHAHAHAAH only in the movies mate! lol Just kidding~!~
I keep a basic metric set in my trunk. screwdrivers and a blow up doll
Old Oct 3, 2007 | 06:19 PM
m00njal's Avatar
Nice thread guys (and/or gals), everyone's input really is helping!
Old Oct 3, 2007 | 06:45 PM
RA030726's Avatar
I'm nutty for Nissans
tools? i dont need no stinkin tools.
Old Oct 3, 2007 | 07:06 PM
96blkonblkse's Avatar
I keep a 1/4" drive ratchet set in my trunk with that, i could take apart half the car. Serioulsy, 8, 10, 12 is pretty much the only thing that the engine bay requires. I have a miniature tool box, has needle nose pliars, philips screwdriver, and 1/4" drive ratchet set, oh and wire cutters.
Old Oct 3, 2007 | 07:28 PM
SmileyFace's Avatar
i have a baseball bat in front of my seat that helps all my problems when i break down on the my ghetto side of town but i drive a nissan so never will happen lol but i have a socket set in trunk in case.
Old Oct 3, 2007 | 07:57 PM
EnervinE's Avatar
i has college
Don't forget a magnetic pole. Those things are lifesavers when you drop a screw deep in the engine bay and the block's too hot to touch.
Finkle
Sep 27, 2015 09:53 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
