Best way to remove knock sensor?
Old Oct 3, 2007 | 05:08 AM
wrightbenz's Avatar
I'm sure someone has some tips on this one? I need to replace my knock sensor
what is the easiest way to remove it? And why isn't the search working on the forum?
Old Oct 3, 2007 | 05:25 AM
ROCKART's Avatar
wants an I35
search isnt working becuase you havent donated...go to www.motorvate.ca for a walkthrough on the KS replacement. i ended up getting my friends 9 year old son to stick his hand in underneath the manifold (after loosening it with a socket).
Old Oct 3, 2007 | 05:55 AM
Double E's Avatar
I got an open ended wrench on it and used a pry bar on teh other end of the wrench to then get enough wedge-force on it to break it loose. I also had a strong magnet nearby cuz I dropped the wrench down in there a few times.
A swivel ratchet was useless for removal.
With nitrile gloves, I was able to get my hand in there for the re-installation but used the swivel socket to get it started with some masking tape to hold it in the socket & start the threads.
Don't give up.
Old Oct 3, 2007 | 05:59 AM
wrightbenz's Avatar
I can search but all of the links are either bad or wrong.
Old Oct 3, 2007 | 06:03 AM
Quadcells's Avatar
Hi All,
I get a engine code for knock sensor, but it seems to run fine. Do I need to replace it?
-quadcells
Old Oct 3, 2007 | 06:10 AM
JwaxMax99's Avatar
Originally Posted by Quadcells
Hi All,
-quadcells
The engine WILL run fine, just replace the KS anyway. It will increase power in mid to top end slightly.
Old Oct 3, 2007 | 06:20 AM
Quadcells's Avatar
Thanks for the reply.
That sensor is $$ and sounds like ***** to replace.
Old Oct 3, 2007 | 06:53 AM
NmexMAX's Avatar
dot dot dot ...
Sensor is cheap on eBay, and if you want to do it correctly (torque down the sensor to spec), take the manifold off.
I've done it both ways, but it seems more thorough to take the IM off. Not that big of a deal either way.
Old Oct 3, 2007 | 06:56 AM
ROCKART's Avatar
wants an I35
yea i forget where it was online, but it was $65.17 before shipping. granted my car got wrecked about three days after installing it, but my low end torque was far better and it seemed like my MPG was better as well. its worth it.
Old Oct 3, 2007 | 06:59 AM
ROCKART's Avatar
wants an I35
here it is. i got a thread open on this from a couple weeks back.
http://www.rockauto.com/catalog/cata...1211432k319760
Old Oct 3, 2007 | 07:04 AM
ROCKART's Avatar
wants an I35
and heres the thread
http://forums.maxima.org/showthread.php?t=408365
Old Oct 3, 2007 | 07:10 AM
Quadcells's Avatar
Hi again,
Is the 61.79 part just as good as the Nissian part?
Old Oct 3, 2007 | 07:14 AM
HotMaxx02's Avatar
I got mine off Ebay for $50, genuine Nissan part. It was a Bisnich to replace. Took me 5 diffrent wench, socket, extension combo's before i got one to work. Took 30 mins total. Would have been 5 mins if it was easier to get to.
Old Oct 3, 2007 | 07:36 AM
Quadcells's Avatar
I just ordered 59.90 shipped from Ebay, hope to get for the weekend.
Old Oct 3, 2007 | 09:16 AM
Holty's Avatar
After the knock sensor is replaced, is there anything else that needs done to the pcm? Do i need to take it to advance auto to have them clear any codes it might have stored? i'm not getting any CEL's
Old Oct 3, 2007 | 09:30 AM
ROCKART's Avatar
wants an I35
yea you might as well have the codes cleared. ive heard stories on here of the KS being replaced and the code being wiped, but then showing up 10 days later. you should feel a boost in performance especially as well as a rise in gas mileage. if you arent feeling those and the code is still showing, then you probably didnt install it properly or you got a defective unit.
Old Oct 3, 2007 | 01:49 PM
mansurxk's Avatar
best way for removal is buying a 12mm swiveling socket....not the swivel joint plus the 12mm socket on top.
also put a piece of electric tape on the end (a small piece inside the socket area)
and use a combination of different extension bars to have enough room to maneuver.
the electric tape will allow the swivel socket to stay snug.
literally took me 10 minutes to do the entire thing (not including the 5 minutes to take apart the intake and filter box).
i actually used a piece of plastic bag instead of electrical tape last time. a strong magnetic wand will help
Old Oct 3, 2007 | 02:02 PM
grey99max's Avatar
LandShark has Cosworth
^ ^ ^ what he said....
A short 12mm 6pt socket on a 3/8" flex joint, with a long 3/8" extension to a long-handled ratchet will take it off. Use tape inside the socket to hold the bolt taking it out and putting it back. Have one of those long 3-finger grabbers nearby and a good light too, so when you drop something, you can fish it out. A magnet on a long handle also works good.
It takes me about 10 minutes to pull one and replace it. Don't have to take anything else off - if you can see the sensor, you can take it loose. Don't tighten the new one too hard. It's a sensor, not a lug nut!
Old Oct 3, 2007 | 04:24 PM
KRRZ350's Avatar
But only if you run premium............
Old Oct 3, 2007 | 04:30 PM
nismology's Avatar
Best way to remove knock sensor? Take off the LIM.
Old Oct 3, 2007 | 04:47 PM
NmexMAX's Avatar
dot dot dot ...
I try telling them in every KS thread
Old Oct 3, 2007 | 05:34 PM
wrightbenz's Avatar
What is the LIM?
Old Oct 3, 2007 | 05:35 PM
wrightbenz's Avatar
I have it off now but it is a PITA to get back on !!!
Old Oct 3, 2007 | 05:36 PM
NmexMAX's Avatar
dot dot dot ...
Lower Intake Manifold.
Old Oct 4, 2007 | 07:32 PM
Specialeded's Avatar
I would search and look into something else as a bad knock sensor will not give you a CEL.
Might want to check the voltage on your sensor before going ahead and replacing.
Old Oct 5, 2007 | 08:19 AM
Double E's Avatar
Removing the manifold also requires replacing the gasket for it right? It's also a good oportunity to clean the intake, but for me I would probably end up breaking something else. I'm sure glad I didn't have to....
I would record every step if you do it... I always forget to hook crap back up and always have half the time I think I do to complete car stuff.
+1^ for not cranking down in it too much during installation. Tight is tight...hell you were just lucky to get it out & the new one back in. Clean the connectors at the other end of the wiring harness too.
My code cleared itself afterwards after about 3 weeks of normal driving cycles. (home-work-home & various errands)
Old Oct 5, 2007 | 08:39 AM
tc97max's Avatar
How do you check the voltage on the sensor specialeded. That seems like a much beeter way to check if its bad then just replacing it. I have a nice meter but never learned how to use it.
Old Oct 5, 2007 | 08:52 AM
97SMG's Avatar
Search / Read and you shall find Post #3(0304) http://forums.maxima.org/showthread.php?t=76800
Old Oct 5, 2007 | 08:41 PM
JwaxMax99's Avatar
Um, I said NOTHING about a check engine light. Can you read and process information?
Old Oct 6, 2007 | 04:12 AM
mr2_ed's Avatar
takes me about a good 10 min.... with a #12 1/4" universal socket extension and ratchet...
Old Oct 8, 2007 | 03:50 AM
96maximized's Avatar
enthusiast
12mm offset wrench worked for me. just bent the bracket with the green connector(?) and voila!!! wear thin gloves with fingers cut off to minimize sliced up hand. took about 20 min.
Old Oct 8, 2007 | 08:58 AM
KRRZ350's Avatar
Hell if you run '87 alot of times it will show up 10 minutes later.
ballerchris510
Sep 23, 2015 08:46 PM
bumpypickle
Sep 20, 2015 08:22 AM
ballerchris510
Sep 11, 2015 05:29 PM
