m45 Seat Installation
Old Oct 6, 2007 | 09:50 PM
OnEBadAsSi30's Avatar
So I got the bottom portion of a new M45. I ripped it apart noticed it had heated seats. So i took the heated seat portion off. Also noticed it had cooled seats. With the heated part there are for wires. Black/red/white/yellow. Obviously red and black are power and ground. What are the yellow and white...are they for the switch? If so how should I wire it up. ALso is there anyway I could put the cooled seat portion in my I30 seat? Just wondering if there is at all any possibility of doing this.
Old Oct 7, 2007 | 09:16 AM
JSMax's Avatar
Sold
I would think that one of those wires is for low heat and the other for high.
The cooled seat you would just need to hook up a different set of switches.
Or, run high heat on the high heat rocker switch and high cool using the factory heat low heat rocker switch.
Or low... whatever you want
hope that helps.
Old Oct 7, 2007 | 05:52 PM
Cdg2125's Avatar
yeah the other two wires are going to be the settings for the heat. Did you mean the cooling system is in the other seats or the front seats too? Both front and rear? What?
Old Oct 7, 2007 | 06:08 PM
OHH NOES's Avatar
6spd Swapped
hope that helps.
Actually the Ms have three temperature settings. Low/medium/high for each heating and cooling. So there are three of your wires.
Old Oct 7, 2007 | 07:00 PM
nope theres for sure only 4 wires for the heating element. I haven't really looked at the cooling yet. I'm pretty sure its from an M45 becuase I don't remember that the G35 came with Cooled seats. Would I be able to put it on a rocker switch and run a low heat and high heat when i want?
Old Oct 7, 2007 | 07:02 PM
MAXSE5SPD's Avatar
speaking as an infiniti tech, i dont believe you can do it with just a rocker switch. theres 3 heated and 3 cooled settings on the switch.
Old Oct 7, 2007 | 07:05 PM
Cdg2125's Avatar
do you have access to the switches? If so you might not have a problem wiring them up.
Old Oct 7, 2007 | 07:06 PM
MAXSE5SPD's Avatar
ya, but even at my price, there prolly expensive
Old Oct 7, 2007 | 07:07 PM
Cdg2125's Avatar
I meant if he does. He said he had the bottom half of the car (?). So I thought maybe he had them? I don't know. But it would save him time and I'm sure you could help him out.
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
GregL65
Sep 5, 2015 09:37 PM
Johnny9595
Sep 3, 2015 05:18 AM
