Cleaning IACV
Old Oct 16, 2007 | 07:35 PM
  #41
goldmax's Avatar
Originally Posted by f550maranello2
the screws are NOT the ones in that pic.. they are the ones that hold the valve to the body.. they are kinda tuff to remove so get a good #2 Phillips screwdriver..
Thanks...I figured they weren't on the picture from how you described them.
Old Oct 16, 2007 | 08:52 PM
  #42
maxx0831's Avatar
Finally got my gaskets from the dealer, altogether is cost 6.12 total . Will be working on it this week.
Old Oct 24, 2007 | 08:00 AM
  #43
int_buck's Avatar
These steps are great help. My TB and plenum were coated with oil on the inside (butterfly was wet around the edges). Is that normal?
Old Oct 24, 2007 | 08:14 AM
  #44
aznguymoo's Avatar
Originally Posted by black_maxed95
i did mine just for the he** of it but my idle was a little high (around 900). it gets carbon build up in it and i just used an old tooth brush and some carb cleaner. after cleaning it my idle became a little low (600). idk if its really preventive maintenance but i just like the idea of having a clean engine.
Hmm, I just cleaned out the IACV last night, my idle is more stable however it is at 1000, it use to fluctuate between 600-700. Overall I think it was worth it, I noticed a difference in the drive this morning.
Old Oct 24, 2007 | 08:48 AM
  #45
heynow's Avatar
uhhhh......ya gotta use the black plastic screw to adjust the idle back to ~750. That's the result of effectively cleaning your IACV (air actually flows thru it now).
Old Oct 24, 2007 | 09:10 AM
  #46
Double E's Avatar
Since cleaning the TB, I got 432 miles on a tank ...and that was before the low fuel light came on. After 158K miles on the clock...that's pretty good. I figure that's about 27MPG
I still have yet to do the IAC!
I love this site.
  #47
ROCKART's Avatar
wants an I35
subscribed
Old Oct 27, 2007 | 11:20 PM
  #48
maxx0831's Avatar
anybody run into a problem taking off the iacv, i cleaned my maf sensor and TB today but couldnt get the iacv off. Dat sh*t was stuck on and the bolt would not budge to come off.
Old Oct 27, 2007 | 11:31 PM
  #49
andrei3333's Avatar
use an open ended wrench, place it on the stuck bolt and slightly with increasing pressure hit the wrench with a hammer - guaranteed to come off
Old Oct 27, 2007 | 11:32 PM
  #50
maxx0831's Avatar
alright ima give it a try tomrrow
Old Oct 28, 2007 | 06:55 AM
  #51
sparky1562's Avatar
I will have to go clean mine now after reading this thread! Thanks for the info.
Old Oct 28, 2007 | 09:11 PM
  #52
got_max's Avatar
Wants a real car
sorry about bumping up an older thread, but is cleaning the entire upper and lower intake manifold worth it?, I mean If I am going to take of the IACV, Tb and I will probably to the EGR also, would there be any benifts to cleaing up the entire Manifold?
Old Oct 28, 2007 | 09:23 PM
  #53
andrei3333's Avatar
to do the things you listed you dont take off the manifolds just makin sure you know that, and no there is no point to clean them because the oil will muck them up pretty quick
Old Dec 3, 2007 | 03:17 PM
  #54
maxima_million's Avatar
Ok, I have a strange quesiton: while coming to a stop at a light (2 times over 3 days) I noticed the RPM's suddenly shoot up and I can feel the car shift into 2nd gear. I slam on the break to come to a full stop and throw the car into nutral. The car bucks like a MF and the RPM's come down. I put it in drive and everything runs fine. While researching this in the forum, I keep coming back to the IACV issue. I've had my car from 40k to now: 136k and I've never cleaned the IACV.
Could this really be my problem? I have bought a gasket for a whopping $1.97. Again, I've never cleaned this, but am I to assume that all I need to do is
remove the IACV unit with the nuts/bolts
clean the hell out of it with a cleaner/towels/tooth brush
ensure there is a clean surface in which the new gasket will connect to and replace
tighten the IACV unit back into position?
Could this be my problem? If so, I love simple things!!!
Old Dec 3, 2007 | 03:31 PM
  #55
Cdg2125's Avatar
could have a problem with your tps. Check the continuity on it.
Old Dec 28, 2007 | 11:28 AM
  #56
sparky1562's Avatar
ok... the ONLY way to clean this valve is to actually take it apart from the housing and cleaning the plunger by its self... so u need to remove the 2 gold screws and take it apart gently... then remove the little plunger and gently clean it with brake clean or what ever you wanna use..
you also need to clean the plungers for both the purple connector and the pink one...
again u need to take then out and clean JUST the plunger..
Just spraying the part that is in the picture above doesnt do SHI.T... you need to take it apart and clean it.. cuz after all carbon gets built up on the plunger and keeps the valve open causing the hight idle...
your welcome... good luck...
Is there an O ring in there that needs to be replaced? I am looking at the Haynes manual, and it talks about an O ring, but does not show it.
Old Dec 28, 2007 | 02:40 PM
  #57
Holty's Avatar
great write up, thanks a ton!
Old Dec 28, 2007 | 03:42 PM
  #58
VANGtastic97's Avatar
ME TOO!
Old Dec 29, 2007 | 07:29 PM
  #59
sparky1562's Avatar
Bump on that question and a problem:
Old Dec 29, 2007 | 09:16 PM
  #60
G4nismo's Avatar
i'm doing this tomm, yay!
Old Dec 29, 2007 | 09:25 PM
  #61
JonBlz's Avatar
a.k.a. STuNtMAN
write-up very helpful i will be doing this monday morning myself
Old Dec 31, 2007 | 10:55 AM
  #62
G4nismo's Avatar
how do you clean the plungers for the purple and the pink ones? do you unscrew the thing where the plugs are connected to (the long gold hexagon rod thingy)? i removed that and there wasn't really any carbon build up. maybe i removed the wrong thing...
Old Dec 31, 2007 | 02:52 PM
  #63
Conrad283's Avatar
I need a truck
Nice write-up ... Will do on Friday.
Old May 22, 2008 | 06:08 PM
  #64
jholley's Avatar
My 98 Maxima SE has 121,000 miles on today. I've sprayed TB cleaner in the throtlle many of times. I plan on taking apart the TB and IACV this Staurday so I picked up both gaskets today.
When I have the TB and IACV disconnected should I spray TB cleaner or pour liquid Sea Foam into the engine?
Which way do you turn the black Idle screw to tighten the valve and reduce the idle, clockwise or counter-clockerwise?
Old May 22, 2008 | 06:13 PM
  #65
ROCKART's Avatar
wants an I35
you should NOT just be spraying TB cleaner into the intake. that gets sucked into the IM and accumulates there.
you should REMOVE the tb and iacv and clean them once they are off. make sure to clean both sides of the butterfly plate.
Old May 22, 2008 | 07:13 PM
  #66
arrocha87's Avatar
any1 volunteer to help? or supervise? lol im just scared of messing something up.. i am going to do my suspension when it gets here!
Old May 22, 2008 | 07:20 PM
  #67
maxx0831's Avatar
theres actually nothing to mess up. Just take out the 3 bolts and use a new gasket. U cant mess up the plugs either because they are all color coordinated .
Old May 22, 2008 | 08:09 PM
  #68
arrocha87's Avatar
probably but everytime i fix something i always break something else! i was a honda guy and recently made the smart move to my max in sept 07 but barely started working on it myself the last two months.
Old May 22, 2008 | 08:37 PM
  #69
ROCKART's Avatar
wants an I35
i was in the same boat as you in oct 07. total noob.
i had ZERO experience with any kind of car
at this point i can safely say that cleaning the IACV is one of the easiest things you can do. trust me.
Old May 23, 2008 | 05:53 AM
  #70
jholley's Avatar
You're saying TB cleaner is not made to spray into the TB but only the surface of the TB?
The reason I am taking off both the TB and IACV is to clean them manually. Those aren't the only 2 parts on the engine that needs cleaning so I'm pouring liquid sea foam into the engine when they are disconnected.
I'll find out which direction closes/ opens the valve when I have the IACV disconnected.
Old May 23, 2008 | 01:53 PM
  #71
hotimportnight9's Avatar
wich number on the gaskets pic is the part number?
Old May 23, 2008 | 03:01 PM
  #72
jholley's Avatar
IACV gasket is 23785-AD100
TB gasket is 16175-31UO1
I found that turning the idle screw clockwise will tighten the valve and vice versa.
Tomorrow I'm taking apart the TB, IACV, PCV valve, EGR and a few other parts to give it a good cleaning.
Old Jul 13, 2008 | 02:27 PM
  #73
sergiovv's Avatar
to andrei3333 .
after about 10 months your pictures and instruction of the iacv and tb cleaning were posted are still showing us people not to spend too much money when it can be fixed with few bucks and also save time by not going to the shop.
doesnt matter from where you got the instructions , thanks for posted them in here.
Old Jul 24, 2008 | 08:28 AM
  #74
kmb38's Avatar
can you reuse the iacv gasket or make a new one?
Is there anyway that I can make a gasket? Im having a hard time getting a gasket from the dealers.
Old Jul 24, 2008 | 08:34 AM
  #75
maximized98's Avatar
Addicted to the Org
Call Dave at Southpoint Nissan. Go ahead and get a throttle body gasket too. He is a great guy and will be by far the cheapest. 512-444-1400
Old Aug 14, 2008 | 02:46 PM
  #76
xkazik's Avatar
just did both the throttle body and IACV . My IACV was very dirty just like the one on the pictures . easy job , dindt notice any improvement but at least i know its clean .
Old Aug 26, 2008 | 12:19 PM
  #77
ROCKART's Avatar
wants an I35
here are some recent pics that show the actual insides of the valve.
the last time i cleaned the IACV i never bothered removing that gold cap (fear of stripping a screw) - but this time i did and there was a pretty large deposit of debris.
and then the mounting point (looking at the inside of the EGR mount)
Old Aug 31, 2008 | 01:05 AM
  #78
Rob20's Avatar
I want to clean mine but im not really confident enough kinda scared with the throttle cables i dont wanna mess them up..but i think im gonna try soon as i got time,tool and gasket. Anyways very nice info on here thanks all
Old Aug 31, 2008 | 04:19 AM
  #79
magic_max's Avatar
[QUOTE=ROCKART;6589101]here are some recent pics that show the actual insides of the valve.
Good pics. Did you remove the pink and purple connector parts too? Is that an o-ring where the brown connector part was? If it is, did you replace it? Was there any difference?
I removed mine before but I didn't take any of the connector parts apart. There was no difference.
Thanks!!
Old Aug 31, 2008 | 01:05 PM
  #80
ROCKART's Avatar
wants an I35
naw i left the pink and purple plugs alone
and im not 100% sure onw hat you mean by brown connector oring, but the answer is no, there is no oring there.
as far as difference goes, i cleaned it as recently as january, so what you see here is only about 8 months of wear/
