car bucking?
Old Oct 11, 2007 | 12:54 PM
Mr.Duck's Avatar
car bucking?
so around 3000-4000rpms, when im at 3/4 - full throttle, my car starts to buck a bit.. any idea what this could be?
Old Oct 11, 2007 | 01:03 PM
[s3]'s Avatar
Check for codes?
MAF?
Old Oct 11, 2007 | 01:49 PM
bipolar's Avatar
maf
MAF dude.
Old Oct 12, 2007 | 08:50 AM
Mr.Duck's Avatar
there are no codes for the maf, and although it bucks a bit it keeps going... also it doesnt happen in first gear, only in 2nd and 3rd...
Old Oct 12, 2007 | 10:24 AM
97SMG's Avatar
Are you still on your stock coils?7
Old Oct 12, 2007 | 12:23 PM
Mr.Duck's Avatar
I am on my stock coil packs but ive replaced one of them and it threw on on code when i did.. Could it be my spark plugs?
Old Oct 12, 2007 | 04:18 PM
Mr.Duck's Avatar
anybody got ANY ideas? please help!
Old Oct 12, 2007 | 04:49 PM
bigpulve+'s Avatar
could be a slight fuel problem...Do you have an AFC or Eu.....Could also be the very first sign of the fuel pump taking a dump....
Old Oct 12, 2007 | 05:03 PM
mansurxk's Avatar
doesn't a bad MAF cap your RPM at 2500? so it rules that out.
Old Oct 12, 2007 | 05:46 PM
G4nismo's Avatar
you could check and see if all your coil packs are running right
(emitting the right spark whatever)
Old Oct 12, 2007 | 07:00 PM
Snypa's Avatar
i think its a fuel problem.......perhaps water in the fuel.cud be wrong
Old Oct 12, 2007 | 08:38 PM
67whitegoat's Avatar
What maintenance have you or have you not done?
What is your mileage?
Old Oct 13, 2007 | 11:03 AM
AndrewR2442's Avatar
After I took my throttle body apart for cleaning .... like an a-hole i took off the tps. I put it on and didn't think anything of it. My car kept bucking like crazy but only at certain rpms. I adjusted it and there has been no more bucking.
Old Oct 13, 2007 | 01:38 PM
Mr.Duck's Avatar
Ok.. So my cheap generic code reader wasnt pulling up the code but it is cylinder 5 misfire i havnt changed my plugs yet and my car is at 78000 miles so im going to try that first got the plugs just need time to install them.. and i will check my coils with on on multometer the second i get my hands on one thanks everyone for your help!!!
Old Oct 13, 2007 | 08:34 PM
bigpulve+'s Avatar
If cylinder 5 is misfiring then your coil there has gone kaput...Change that and everything should be back to A ok...
Old Oct 14, 2007 | 05:40 PM
bigpulve+'s Avatar
Originally Posted by cowboys2233
juss hit the blunt and smoke out the car and think bout it later
Old Oct 14, 2007 | 09:04 PM
G4nismo's Avatar
why are you even on here? in fact, why did you even register?
Old Oct 14, 2007 | 09:21 PM
maxima985spd
good idea
Old Oct 15, 2007 | 10:22 AM
rockfordmaxII's Avatar
"juss hit the blunt and smoke out the car and think bout it later" ??~?~
you must drive a civic, so: :stfu:
Old Oct 15, 2007 | 04:14 PM
gunny11218's Avatar
^^haha^^
Old Oct 15, 2007 | 04:21 PM
KRRZ350's Avatar
Pull the coil first, plug it back in and plug in a spare spark plug, hold it to the intake manifold while you or assistant starts car, the plug can cause misfire code as well.
Old Oct 15, 2007 | 04:53 PM
hot_wax_tree's Avatar
have you changed you fuel filter? I had that same problem so I replaced mine and it helped a little but not all the way but I also have a bad O2 still gotta replace that. and if you do replace your filter I was told get a 300zx filter.
Old Oct 15, 2007 | 05:42 PM
JtzMax's Avatar
Whatchyou say?
I would try the following ::: new plugs first - if that doesn't do it, then do the coil pack. If the new plug and / or coil pack doesn't do it, try replacing the fule filter.
At first ... I though, learn how to shift mate! but ... I agree if you're pulling codes, that must be the reason! lol G'luck, keep us posted please.
Cheers ~!~
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Dasmith
Aug 25, 2015 10:15 PM
JMag90
Aug 25, 2015 09:17 AM
District
Aug 15, 2015 08:23 PM
