brake jamming
Old Oct 13, 2007 | 01:41 PM
kasemodz's Avatar
brake jamming
Hi, I changed my front rotors and pads a couple months back. Ever since I changed it, I have been some small problems. Usually, sometimes the brakes would just jam. After I press the gas to about 1500 rpm, it finally unjams followed by a big jerk. Before, it only did that when the engine was cold. Now, however, its getting worse. Does anyone know what can be done to fix it?
Old Oct 13, 2007 | 02:44 PM
Drdla's Avatar
It sounds to me as if you have a seized caliper or two? Did you service the brakes when you did them?
Old Oct 13, 2007 | 03:41 PM
KRRZ350's Avatar
Before replacing the caliper do this first............
Jack the car up (E-brake Up, car in Nuetral, NOT park) take the wheel off and get the brakes to 'jam' so that you can't spin the lugs. When it is jammed, crack the bleeder screw loose, if loosening the bleeder screw allows it to spin freely you have a rubber brake hose that has collapsed internally.
Also check caliper guide pins aren't sticking/frozen, check for even pad wear, and pop caliper off and check that the pads can slide freely on the caliper bracket.
Old Oct 14, 2007 | 09:06 AM
kasemodz's Avatar
Hmm, one thing I did recall not puttin was anti-sieze lubricant on the rotor. Will that fix the problem?
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
