LED Boards For '99 tails
Old Oct 25, 2007 | 02:14 PM
  #121
kzoosho's Avatar
Originally Posted by BLACKonBLACK98
alright i just spent 7 hrs designing 1 of the smaller boards. i packed 54 sf and 14 resistors into the 2/3 section of the turn siganl. i hope the rest don't take as long. i'm going to build the prototype using the cb with holes rather than etching a copper clad board. expresspcb and me are one now. i actually feel pretty dern smart for figuring all this stuff out. thanks for the help guys.
as for the white, if i can't find anything i'll try the ebay sf knockoffs unless anybody else has any suggestions.
for white thats what you are going to have to do but for the red orange you can either hit ebay under madscientist they sell them 1200 at a time and they are the real sf also.
Old Oct 25, 2007 | 02:47 PM
  #122
BLACKonBLACK98's Avatar
Former Vendor
its amazing what you can learn in a couple days. heres my progress today:
first i adjusted the design for superflux leds. then i changed from a surface mount design to a through whole design. there were quite a few more versions (and i'm sure there will be more before tonight) but these are what i had print outs of.
Old Oct 25, 2007 | 06:06 PM
  #123
m00njal's Avatar
I was the first to reply to this thread, and I advised to "find a member who might make it for you"
But again the brotherhood of the org has greatly impressed me with everyone's insight, collaboration and determination. Thanks for making me a proud member and I really enjoy this.
........and I hope to buy a set of boards when you can get them ready, yippie!
Old Oct 25, 2007 | 09:15 PM
  #124
d3v0's Avatar
AMEN BROTHA! PREACH IT TO THA CHOIR! "I BELIEVE...." or better yet "I HAVE A DREAM......."
Old Oct 26, 2007 | 09:46 AM
  #125
Former Vendor
i grabbed 150 of the hk 5 chip sf knockoffs for the white. are you sure the "mad scientist" one are superflux? they say made by hp rather than phillips. are those 2 companies related?
*edit* i just found out i ordered the wrong ones. i ordered the 20ma version instead of the 100ma version. hopefully they'll let me change my order.
Old Oct 26, 2007 | 10:36 AM
  #126
kzoosho's Avatar
http://cgi.ebay.com/1200-Super-Flux-...QQcmdZViewItem
These are the ones i have and are indeed the real ones.
Old Oct 26, 2007 | 11:09 AM
  #127
Former Vendor
i'm gonna check them out. they are 1/3 of the price in the 120 pack. .04 vs. .12. man i'm gonna kick myself if i just got stuck with $60 worth of 20mA whites.
*edit* thats an auction rather than a buy now.
Old Oct 26, 2007 | 11:14 AM
  #128
Former Vendor
those are the 40 degree viewing angle rather than the 70. i'm gonna grab some for my proto, but i'll be using 70 for production.
Old Oct 26, 2007 | 11:16 AM
  #129
kzoosho's Avatar
those are 70 read specs on them.
Plenty bright and very visable.
Old Oct 26, 2007 | 11:24 AM
  #130
Former Vendor
in another auction he has them listed as the F4000 model. they are 70 mA but a 40 degree viewing angle. if you check the specs there are variations of the HPWT-DH00. i bought some anyway and bid on the auction.
Old Oct 26, 2007 | 11:31 AM
  #131
kzoosho's Avatar
Kinda wierd to read but thats 40 degrees at a 20 degree angle but 70 degrees at 0 degree angle . all in all they are all 70's in red orange. thats another thing youhave to look at . they have the hpwt-dh00 in a couple colors but all we deal with is red orange.
Old Oct 26, 2007 | 11:40 AM
  #132
Former Vendor
i was planning on using red for the running/brke lights to get that deep color. red-orange for the signals and natural white for the reverse.
Old Oct 26, 2007 | 11:52 AM
  #133
kzoosho's Avatar
ok cool . i used red orange in all of mine . doing the reverse lights is really over kill imho. u really dont use your reverse lights that much at all. I was wondering what you planned to do with the signal lights? Are you looking to get a new flasher or what were you planning on going about that? I honestly and just going to do my signal lights and tail / brake lights.
Old Oct 26, 2007 | 12:14 PM
  #134
Former Vendor
hmmm... haven't read anything about that. i can't use a pwm?
Old Oct 26, 2007 | 12:20 PM
  #135
Cdg2125's Avatar
using a pwm on the blinkers might be overkill. Unless you plan on doing a lot of them in the turn signals. I think the the signals would look best with just a single line of leds. Just my opinion on them tho. Either way, since the leds only need one source of power you should just need proper resistors. If you use higher value resistors you should be able to keep the leds far enough away from burning out. The point of the PWM is to control the brightness between the regular lights and brake lights. With the blinkers you don't need that since they only blink and don't need constant power then more to blink brighter.
Old Oct 26, 2007 | 12:31 PM
  #136
Former Vendor
yeah that makes sense. i was thinking of having them blink as bright as the brake lights but that might not be neccesary. acually it probably wouldn't even look good. i do have a LOT of leds in there though (1 board with 29, 1 with 53). why would having a lot of leds require a pwm?
Old Oct 26, 2007 | 12:53 PM
  #137
Cdg2125's Avatar
well i know as much as you do about this stuff but my assumption was that with a lot of them it would be better with the pwm to regulate the power going to the leds. So if you did...lets say 7 leds on top and 8 underneath
******** (left side of car so you have the angle toward the inside angle. if you can see what i mean)
You could do strings of 3 with resistors but use the pwm to control the voltage so when the blink they stay at say 50% of the maxium. So they wouldn't be so bright but would be bright and not burn out quickly. Just my thoughts.
Old Oct 26, 2007 | 01:01 PM
  #138
kzoosho's Avatar
Originally Posted by Cdg2125
well i know as much as you do about this stuff but my assumption was that with a lot of them it would be better with the pwm to regulate the power going to the leds. So if you did...lets say 7 leds on top and 8 underneath:
Well i was saying to use it to regulate voltage but you easily use resistors either singe or in strands and get a new flasher. i plan to use 15or so for my signal as i would want my signal light to be noticed just as much as my brake. You dont need pwm for the signals you can use resistors and be easier also. You would just need a led flasher which you can get pretty cheap.
Old Oct 26, 2007 | 01:06 PM
  #139
Cdg2125's Avatar
yeah but i think the amount you want is way offer necessary. I think the way I showed it would look best because the lines could be distinctive. They would still be noticed because they will be bright. Oh and flashing...
Old Oct 26, 2007 | 01:19 PM
  #140
kzoosho's Avatar
15 for my signal im sorry . 30 was my first design. 3 rows of 5 is what i am going to do. I have 40 in my outers and 35 in my inners
Old Oct 26, 2007 | 01:22 PM
  #141
Cdg2125's Avatar
wow thats a lot of leds. Too much to me. I think that too many won't look that good. My signals would be 15 as well 7 then 8 below. All personal preference ya know?
Old Oct 26, 2007 | 01:25 PM
  #142
kzoosho's Avatar
Have you seen my tails or made any? 15 leds in our housings would as if you were missing lights. if you need pics let me know. i do think if youl go with that few leds you will not get the lighting you will need to be safe.
Old Oct 26, 2007 | 01:27 PM
  #143
kzoosho's Avatar
there are 69 leds in the light i posted a few posts back.
Old Oct 26, 2007 | 01:39 PM
  #144
Former Vendor
i like the lights both you guys posted. i am designing mine to light up the housing completely and evenly ie no lines. it might look good, it might not... we'll just have to wait and see. i have 1/20" between mine vertically and 3/20" horizontal spacing. i'll give the official count a little later when i finish my last board, but i'm guessing about 250/side. thats inner/outer running/brake, 2 boards for the signal, and reverse. its starting to sound like overkill now that you guys are throwing out numbers, but i knid of invisioned them differentally than y'alls.
Old Oct 26, 2007 | 01:41 PM
  #145
kzoosho's Avatar
yea the reverse lights are crazy. after doing the inners and outers i said the hell with the reverse lights.lol
Old Oct 26, 2007 | 02:02 PM
  #146
Former Vendor
actually (assuming they let me change my order) they were the easiest because you can only use series of 4 100 mA leds. i figured since the signal and reverse are rarely ever on at the same time i could just do a 4x14 block. the hard ones have been the upper parts because of the shape and size. its not easy to get the shape right using series of 5 with very little spacing, but i'm almost done.
Old Oct 26, 2007 | 03:28 PM
  #147
kzoosho's Avatar
NO im not saying that it was hard. But after i did the outers and inners i said the hell with the rest . it was more time than anyting . i wasnt saying it was hard.
Old Oct 26, 2007 | 03:52 PM
  #148
Former Vendor
ok, well i'm done with my last design. i think it will be easier for me from here on out since i'm having the boards made. i've been designing these things for 12+ hours a day for the last 3 days. i think you'll be able to see them from the moon. not really, but there are a TON of lights. official count coming soon.
Old Oct 26, 2007 | 09:33 PM
  #149
Cdg2125's Avatar
original leds from kevlo that everyone loved had 108 leds. That's what I'm doing. 24 on the outsides 30 on the insides. I just can't imagine putting 200 leds into the tails. And from what I know about the kevlo tails, the 108 were very bright. They were originally worried that people would be pulled over they were so bright. So I don't think that less LEDs is unsafe. It's about how bright they end up being.
Old Oct 27, 2007 | 07:40 AM
  #150
Former Vendor
well the official count is in at 293/side. this is how i want my lighting to appear:
that is the car that belongs to the azdave guy we keep mentioning. i am going to find more details on a way to adjust the brightness of the running lights as well as the brake lights via pwm.
*edit*the look i'm going for requires more leds, but they can be run at a lower duty cycle which, to me, is a plus.
Old Oct 27, 2007 | 02:26 PM
  #151
Cdg2125's Avatar
yeah I know dave's car. Thats fine if that's what you're looking for. I don't believe those are regular superflux leds through the whole back tails. There are different leds in the middle. But yeah if you're going for a different look I understand. Hence I said stuff about peoples preferences before. Well the pwm should control both running and brake lights.
Old Oct 27, 2007 | 03:02 PM
  #152
Former Vendor
from what i understand his first versions were smd, but he later replaced them with sf. i was wondering if the pwm controlled both or not. does anybody know about/have links regarding sharp regulators?
also, if anyone wants to chime in about their preference in appearence, please do.
Old Oct 27, 2007 | 04:26 PM
  #153
f550maranello2's Avatar
i already told ya guts.. ONLY use Super Flux leds.. they are the brightest and last the longest...
also only use a pwm.. WHy you may ask.. heres ur answer why..
let say u have 5 rows of 5 leds.. ok and then u have 2 rows of 2 leds.. if u use a voltage regulator then the 5 rows of 5 are gonna be dim and the 2 rows of 2 are gonna be brighter... thats why u wanna use a pwm ONLY.. since in a PWM you arent regulating voltage ur simply modifying the duty cycle of the leds..
Why are u guys still asking questions about a simple process..
Old Oct 27, 2007 | 04:37 PM
  #154
Former Vendor
you know, i'm not 100% sure since i'm learning as i go but i think you're wrong. i think that you can use a voltage regulator with a pwm. as a matter of fact the pwm i'm buying has a built in regulator. you can have series of different amounts because the resistors in series with the leds vary in resistance.
smart guy...
Old Oct 27, 2007 | 05:10 PM
  #155
ok if u thing im wrong then do it your way... but dont ask me later one why some LEDS are dimmer and some are brighter and why they are burning out.. see ya..
by the way i have a bachelors in EET..
Old Oct 27, 2007 | 05:21 PM
  #156
kzoosho's Avatar
I understand what you are saying. and yes you do want to use a regulator with your pwm that way you have a constant voltage. theres no need to get hostile about things. the pic he posted is smd leds and they are nice and long lasting also. if you are not going to use as many as dave (i.e) 5000 then yes sf all the way. I didnt not use nor have i ever used pwm so it is not the only way to go . Please stop misinforming about that. Pwm is the best way to go but it can be had other ways. I personally have proved this over and over again.
Old Oct 27, 2007 | 05:26 PM
  #157
Former Vendor
i'll be sure to remember not to ask you, actually i never did. how could you argue that controlling the voltage then adjusting the resistors to make up the difference of the voltage drop is not right. the only reason yours aren't blowing is because series of 5 superflux can handle 13v. upgrade your electrical system and i bet you start burning something.
Old Oct 27, 2007 | 08:17 PM
  #158
Former Vendor
i got my led count to 241/side. i had to adjust for 12v regulators. i think my designs are perfect now. all leds are evenly spaced vertically and horizontally.
Old Oct 27, 2007 | 11:11 PM
  #159
Cdg2125's Avatar
cool. Glad to see that your designs are coming together. Just wanted to say that the comment I made before about the style of Kevlo leds was made because I wanted to say that those were the demand. Not to say people won't want your style but Kevlos design was a big part of what people wanted. Nice led design, simplistic, and really nice. So the point before was just to say that you might want to remember what the demand was for (in case you plan to manufacture them). I think it's cool to make the original design you have but I just wanted to make that point so it wasn't a big deal if you did want to manufacture but was not a high demand.
Old Oct 28, 2007 | 06:16 AM
  #160
Former Vendor
thanks. i understood what you meant by your comment. i liked kevlo's style as well, but i'm building mine the way i picture them. i feel i'm a person of good taste and high standards, so if i like what i make i'll put it out there. if i don't i will work on changing it until i do. all due respect to kevlo and his design, but being that it was the ONLY design out at the time theres really no way to determine what drew people to them. i do appreciate your input and it is something i have considered.
