LED Boards For '99 tails
#81
i plan on using 3 pwms. those are not the housings i will be using, i just had them laying around and they were already broken so i figured "might as well". i think i'm going to try to make my own pcb. i need a project right now anyway. thanks for the offer though.
#82
what would youneed 3 for? u know you can use one for each side. then you only need 2. If you plan to do the signal lights since you can run those with no dimming theres no need for a 3rd pwm .
#84
not a problem man i dont mind helping anyone. do you have leds? i have 1400 hp superfluxes lol i have alot i know. let me know if you need any i am willing to sell some but not all i have 6 cars and only 2 have leds so far.
#85
i haven't got that far yet, right now i'm trying to get supplies together to make the boards. once i have a grasp on that i'll start researching the components. i'll definately keep you in mind though. what colors do you have? and on a related note, do you think i should use orange or white for the blinker? anybody feel free to answer that last one.
#88
cause i put hyper white bulbs in my blinkers and my dad was driving my car and he got a sitation by a cop, so then i had to change them to the ungly yellow bulbs. then again i do live in fairfax county in virginia.
#90
I thought i would carry this over from HIDPLANET if your looking for something to draw up schematics, check out this free tool, i haven't had a chance to use it yet but from screen shots it looks pretty good.
http://www.expresspcb.com/ExpressPCBHtm/Download.htm
#93
Red blinkers in the front are illegal in NY...
Only emergency vehicles can have red/blue in the front... Im thinking they have to be yellow, white is pushing it...I got pulled over for having red blinkers in the rear, but It was just an excuse to pull me over.
I kept cool not to mention the crown victorias and lincolns with red rear turn signals as well???
I hate dirty cops!
Kevlo911- You still have your order form, with the design? Maybe we can reorder from yours??? Just a suggestion...
I hate dirty cops!
#94
#95
I hate dirty cops!
I hate dirty cops!
#96
All OEMs are PWM controlled. It is the only way to get reliable, stable and consistent performance from your LED assembly. I'm not saying non-PWM designs won't work, but they are not as refined per se.
I too have Agilent Super Flux (Piranha style) automotive spec red-orange LEDs. If anyone wants to buy some, LMK. I have 1000's. I'll get some pics of my lots of LEDs, seems some of ya'll may need some!
BTW, if someone could perfect the PCB layout, you could have sunstone make about 100 PCB's at a cost of about $8 a board. With components, a generic off the shelf PWM setup and LEDs you shouldn't need to spend more than $150. And those Taiwanese made ebay garbage Altezza style LED tails are junk, IMO.
Edit:
Pics of prototype PCB with PWM control using Agilent Super Flux Red-Orange DOT bin LEDs
Dimmed:
#97
Ok, kinda though it was obvious reds in the back would be legal??? maybe I was wrong??? But doesn't a lot of cars have red rear turn signals??? especially American made cars?
Todays project: Spot the red turn signals... get a count lets see how many are out there?
#99
If you are going to use those copper boards that azdave was talking about then start a thread on hidplanet and make sure you get ahold of azdave. Also the dimming can be done without pwm as i have yet to run one in any of my cars. pwm is the best but not the only. heres a site to get a cheap pwm from.
http://www.quickar.com/tkit.php?session=O66wTsFL
#100
Red turning signals in the rear are perfectly legal. It is in the fron that they are illegal. No need to look for cars with red rears.
#101
side note: i just finished my first pcb design. it will be modified when i get the actual leds. i'm not sure how wide the spacing will be yet. teaser pic:
#102
i've checked out that and other pwms. when the time comes i'll just pick whichever one is the most pnp. both that one and azdave's require a little modification. if i do have these professionally produced i would like to have the pwm mouted on the back of one of the boards, but thats down the line a little. are you saying he's a good source of info on the leds as well?
#103
thanks, but i wasn't happy with those so i now have an updated version (top secret) that looks AWESOME! it will also disapate heat better than those would have. i started a new led tail thread that i will use to write-up my build.
#104
I wasnt aware LEDs generated much heat.
#106
#107
its the resistors that create heat.. if u use 1/4 watt resistor with a 70 mA LED ITS GONNA GET HOT... LIKE 750 mA hot...
I have 280 LED's i left it for 24 hours just to test it out... i used 1/2 watt resistors (5 LEDS for each resistor ) and you could not feel crap...
#108
what type of leds did you use? superflux? my first design is for 20mA leds. theres a combo of 1/4 and 1/2 half watt resistors because i have strands ranging from 1 led to 7. yours look great btw.
#110
i'm considering both. i personally like the wide angle 20mA from what i've seen, but i'm sure most people would prefer the sf. one of the problems with the sf is i don't have room on my boards for the larger resistors. i actually had to modify my design a little to accomidate some of the 1/4 watt resistors.
#112
WHY? because regular LEDs arent bright enough during the day... its Dangerous..
i did that as well the first time.. i used regular "high intensity" LEDs yea until my buddy drove my car and i drove behind him... i almost rear ended my own car..
Now.. what u mean u dont have room for large resistors.. i have a strings of 5 with a (1) 27 ohm resistor.. and that resistor dissipates about 115 mW....
u dont need any other big resistor.. the reason i said that is because the dude that posted pics used 1 resistor per LED, which is gonna be stressed with like 700 mA even if he used 1 watt ones..
#113
I think my proto board used (1) 1/4w resistor per every 4 Super Flux LEDs. Nothing became warm. There is so much voltage drop across the 4 LEDs (10V) that the single resistor can be a very low value and easily maintain 70ma drive current (recommended for Super Flux LEDs). The only LEDs that should be driven so hard that they get hot are power leds. And those get heatsinks.
And I concur, don't use the 5mm ones. A few reasons:
The 5mm from eBay are cheap. Yes they are initially bright, but they have inconsistent brightness/color/voltage drops. etc. They are all made in China (ebay) and you get what you pay for.
5mm LEDs are not as easy to line up consistently on a PCB. The Super Flux LEDs have 4 legs and they will solder onto a PCB perfectly level, maintaining good appearance.
Even good 5mm LEDs should only be run at 20-30ma. Super Flux LEDs easily handle 70ma drive currents and are much brighter because they have larger reflectors and heavier components that dissipate heat better.
The super flux LEDs are honestly rated. The eBay ones use the brightest spot to measure MCDs, and they have spotty beams with artifacts. Super Flux LEDs use spherical measurement. Much more honest. Which brings me back to the ebay Made In China LEDs....ahem, "honesty" anyone?
#116
no u dont... ok so EVERYBODY HERE UNDERSTANDS!! ONLY use SuPERFLUX..
#117
if i read it right azdave used the smd in his prototype but is now using sf. i'm a little confused by your last sentence. i assume you're saying the sf are more expensive but easier to mount. i will be spending today redesigning all my boards to accomidate sf. do you still want to get rid of some? i need the red-orange and the red. also what do you guys reccomend for the white? i want to use a natural white and there aren't any white sf listed on the luminled website.
#118
something just crossed my mind. am i waisting my time designing a pcb if i'm just trying to make a prototype before i have professional boards made? this just occured to me when i was working on my design and was having trouble fitting everything because of the clearence i would need to solder the pins. the profeesional versions won't be surface mounted so there will be a ton of waisted space. actually, i just answered my own question but i'm interested to hear other opinions.
#120
alright i just spent 7 hrs designing 1 of the smaller boards. i packed 54 sf and 14 resistors into the 2/3 section of the turn siganl. i hope the rest don't take as long. i'm going to build the prototype using the cb with holes rather than etching a copper clad board. expresspcb and me are one now. i actually feel pretty dern smart for figuring all this stuff out. thanks for the help guys.
as for the white, if i can't find anything i'll try the ebay sf knockoffs unless anybody else has any suggestions.
