Annoying and embarrassing issue...
Old Oct 22, 2007 | 04:19 PM
Maxi98se's Avatar
I have this noise that is coming from the brake system I believe. I have checked everything over twice. It is a constant weeeeeeeeeee noise if im driving under 20mph. I completely removed the brake dust shields. I read up that this may be the culprit. I cleaned and reinstalled everything.... I just dont know what else it could be, the brake pads are still thick and the rotors are newer.... I love the max but I cant take this anymore!!!
Old Oct 22, 2007 | 04:23 PM
matty's Avatar
Wheel bearings might be on there way out
-matt
Old Oct 22, 2007 | 04:24 PM
TunerMaxima3000's Avatar
more info? 'weeeeeee' doesnt really give an accurate description, have you checked belts, etc. is it possible that you just dont hear it over 20mph or does it stop abrumptly?
Old Oct 22, 2007 | 04:30 PM
merlin2375's Avatar
sounds like a wheel bearing (but could be belts)...link below a good way to diagnose. Wheel bearings usually make a droning, humming, or whining noise. They'll continue to get worse if they're the problem.
http://forums.maxima.org/showpost.php?p=6019259
You can also jack the car up, grab the wheel at 12 and 6 and see if there is play. If there is wheel bearings are dying.
Old Oct 22, 2007 | 04:39 PM
Maxi98se's Avatar
I cant hear it over 20 mph, Its a sound similar to when your brake pads get low and need replacement. Im ruling out the belts as I had them replaced this summer. There is also no play with the wheels either, although im at 140,000+ miles so the bearings probably have to be replaced?
Old Oct 22, 2007 | 05:35 PM
KillaJakez's Avatar
Check calipers for seizing. My right rear caliper was seized and made that noise.
Old Oct 22, 2007 | 06:31 PM
SNOMAX's Avatar
PM me for LCA's!
If the sound is like "similar to when your brake pads get low and need replacement" as you say, then you might have the brake pads in backwards, this causes the squeal tab to make noise pretty much all the time.
Without a pic and based on what is posted so far, I would just double check that and maybe put some anti-squeal compound on the shims and back of the pads--if you haven't already.
Old Oct 22, 2007 | 07:12 PM
xkazik's Avatar
same thing happened to me last week it was the wheel bearing
Old Oct 23, 2007 | 09:27 AM
Double E's Avatar
+1 wheel bearing
Old Oct 23, 2007 | 02:02 PM
Snypa's Avatar
bearing retirement.
Old Oct 24, 2007 | 01:55 PM
Maxi98se's Avatar
Anyone want to help me replace the bearings?? From what ive read so far sounds like a pita....
Old Oct 28, 2007 | 04:22 PM
Maxi98se's Avatar
Just wanted to update you guys, I had both front wheel bearings replaced. Now I can enjoy driving the max again!!!
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
02PearlSE
Feb 1, 2016 12:37 AM
mpbclutch33
Dec 26, 2015 11:11 AM
