ABS code diagnosis help please?
Pulled a 12 and a 21, (though the 21 may be a 30, was hard to tell)
Does anyone have a list of diagnostics for the ABS codes?
I searched and found lots on how to pull them but nothing on interpreting them.
PS: 1999 Intiniti i30t
Thanks!
Thanks!
12 -- Self-diagnosis could not detect any malfunctions.
21 -- Front right sensor (open-circuit)
30 -- couldn't find such code
Check your front RH sensor and connections, reset the light.
I'd be interested to know as well what the proper method is to ground the ABS to pull and clear codes. Chilton's describes what part of the unit to ground, but doesn't say how to do it specifically.
Just use a small jumper wire to connect those two pins, or a wire connected to any other ground source.
Excellent! Thank you. I had the procedure from your manual, but needed the ground to #4 pin part.
I still need help with my 0505 code which came back again today. As I mentioned in the other thread, the system is charging fine at the battery. Suggestions?
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
