Weird noise from underbody, Grinding/Whistleing/Hissing
Old Nov 9, 2009 | 06:00 AM
SPER's Avatar
Keep getting this sound from my car. The hissing/whistleing sound seems to be constant. But there is also a metal on metal grinding sound that only seems to happen at slower speeds, and is alot more noticeable in stop and go traffic. Sounds like something is dragging on the ground.
I checked the underbody and everything looks fine. I know that I need to change the brakes, can this be the rotors making that noise? I ordered new pads and oem rotors, they should be here in a week. Till then, what can that sound be from?
Old Nov 9, 2009 | 06:14 AM
max ride 41's Avatar
dude, did you search?? of course brakes can squeal in stop and go traffic, pads wear thin. fluid in master cylinder on the line??? seriously, umless the calipers are sticking, which is another possibility its your pads.
Old Nov 9, 2009 | 01:21 PM
SPER's Avatar
Originally Posted by Bamfy98
I had this sound once, it was my tranny, at slow speeds my tranny's insides were grinding due to a fluid leak and damaged internals. That tranny went bye bye.
Ahhhh ****. I think this might be it, because this car has always given me issues with 1st and 2nd gear.
Old Nov 9, 2009 | 01:24 PM
SPER's Avatar
Actually yes I spent hours searching. Its hard to detect when your car makes 3 unknown random sounds (at least to me, since I've never heard these sounds). Yes the brakes makes squealing sounds, but thats an obvious sound that I didn't mention because I already know the solution to THAT problem.
Old Nov 12, 2009 | 07:16 AM
oVeRdOsE's Avatar
It could be stupid, but I already had that kind of sound. My metal rear disc protector broke by the rust and he was stuck in the rear wheel. It grinds my wheel.
Old Nov 12, 2009 | 07:55 PM
bend it back out, easy to do
Old Nov 24, 2009 | 08:21 AM
SPER's Avatar
FOund out the problem. I changed all my brakes and rotors and 2 calipers. The rear caliper piston was out a good inch, which was making it press against the pads really tightly and then the pads were grinding on the rotor. So had to change 2 calipers, 2 rotors and changed all the pads. No more noise!
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
