MT lock or shifter linkage problem??
I have had bearing failure on my trans for a couple of months now. The tranny has been riding on its last leg for quit a while. Today, I tried to put the car into gear but could not. I can shift the car into 1, 3, 5, and reverse. Is the tranny seizing on me or is it something involving the shifter? I have installed a short shifter as well.
Anyways, I have a spare tranny from Neal ready to put in.
Can you move past the gates into the actual gear, or are you prevented from doing so entirely?
If you know that the trans is 'on it's last legs', why even bother with a diagnostic? Could easily be the trans. Especially if you have a spare, just swap that one in.
Like I said, the bearings have been leaking and making whirling noises for months now.
Time to put in the tranny
btw how do you know that you have bearing failure and which bearing are you referring to, that will make a difference here.
well when the problem first appeared, the noises started coming from the tranny. Everytime I let the clutch out and was riding the clutch, it made whining noises. So, replaced the rear main seal and the throwout bearing. Noise quieted down but was still present. It progressively became worse and worse until I had this problem.
Just thought I could crutch this problem a little longer so I could save up for a Stage 1 clutch kit while the tranny was out, that's all.
Mar 12, 2020 12:06 AM
johnaschon
Sep 14, 2015 04:29 PM
ef9
Sep 10, 2015 10:35 PM
