Need Help...Tranny Problems
Old Nov 1, 2007 | 12:05 PM
Gb2St's Avatar
it all started with a little grinding when shifting into 3rd, now its progressed to leaking and slipping gears..
any suggestions on what i should do??
replace, rebuild, upgrade to a racing tranny of somekind??? whats out there im new to the maxima?
suggestions are welcome thanks
Old Nov 1, 2007 | 12:10 PM
pmohr's Avatar
No more Maximas...
Assuming this is a 5MT, start with finding where the leak is coming from, seems like the first step. If it's axle seals, you may have bad diff bearings, though those are relatively easy to diagnose from under the car.
Replace the clutch, fix the leak is what I would do. Of course, that's just fixing the problems you have...not a very intuitive thing to do, I know.
Old Nov 1, 2007 | 12:19 PM
Any experience with working on cars/trannys? If not, let the pros deal with it. They'll tell you if it's cheaper to rebuild it or to replace it with a refurbished one.
No need for a upgraded 'racing' tranny if your NA.
Old Nov 1, 2007 | 02:46 PM
dgeesaman's Avatar
Maintenance Monster
If it's a manual, you could have trouble getting it rebuilt well. Make sure they remeasure and re-shim the tranny before calling it done. (most shops just ignore that step).
Impossible to say about cost, and I'm not going to suggest buying used is a whole lot better since used trannys tend to be hard to find and often need rebuilt anyway.
Dave
Old Nov 1, 2007 | 05:52 PM
Gb2St's Avatar
thanks for the responses guys, anything else to add is welcomed
Old Nov 1, 2007 | 07:30 PM
JtzMax's Avatar
Whatchyou say?
Said by the man with the huge SC on the front of his engine! lol
If it's not leaking from the CV shafts, it is possible that it is the IPS bearing and it's so bad now it's leaking. I don't know for sure if that would cause a grind into 3rd or not ... but I see how it could.
side note: if you want to do a "racing" tranny, do a 6spd swap or do a rebuild with an Altima (5spd) 3rd gear
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
