My hood doesn't line up (pictures)...and its pissing me off
Old Nov 7, 2007 | 07:02 AM
ROCKART's Avatar
wants an I35
my hood should be sitting flush with the front body panel of the drivers side but it does not. its not sitting that much lower, but it still doesnt look right from the front.
ive looked at about every place the hood could be sitting and i dont see anyhting that looks off....so my only real idea about how to fix it was this little cushion sitting on the side of the frame. but that seems to be the same in feel and size as the other side (the passenger side) which is sitting flush...
ive seen this on other maximas both in real life and in pictures on here
do i have to replace that cushion? is there another piece im missing?
Old Nov 7, 2007 | 07:09 AM
jvckustumz's Avatar
mine does the same, it's alittle down and forward, it happened after i took my hood off and put it back on so i bet its just alignment issues
Old Nov 7, 2007 | 08:08 AM
maximabebe's Avatar
Has your car ever been in a front end collision that you are aware of?
Old Nov 7, 2007 | 08:13 AM
ROCKART's Avatar
wants an I35
no. i bought this from the original owner - a 92 year old woman. CARFAX checked out. she never drove at night or in the rain. no accidents. only 42k on the car. 4k a year...
Old Nov 7, 2007 | 08:36 AM
MDeezy's Avatar
its off my 4mm
you could try loosening the bolts for the hood and try shifting it back as far as it will go then see if it lines up, if not try loosening the fender and shifting it forward to line up.
Old Nov 7, 2007 | 09:14 AM
cardana24's Avatar
Blown
Have you tried adjusting the rubber bumpers that are in the radiator support. I think that helps to control the hood height. They should screw up and down a little bit. Yours could have gotten worn out over time.
Old Nov 7, 2007 | 09:26 AM
ROCKART's Avatar
wants an I35
you mean the ones that compress when you let the hood down?
they have an accordian type rubber flexing cover on them?
those can be adjusted?
Old Nov 7, 2007 | 09:33 AM
ROCKART's Avatar
wants an I35
are you talking about this thing? its height can be adjusted by screwing/unscrewing?
Old Nov 7, 2007 | 09:37 AM
darklegend06's Avatar
umm that thing is the security switch for the hood.
nothing to do with the hood not closing right, if I'm not mistaken
Old Nov 7, 2007 | 09:39 AM
ROCKART's Avatar
wants an I35
ok. i see what you are talking about now.
Old Nov 7, 2007 | 09:44 AM
Snypa's Avatar
yeah...neither red or yellow arrows have anything to do with it,its some aligntment about the place do, and you said no front collison....hmmm,overall its not all that bad.
Old Nov 7, 2007 | 09:46 AM
jvckustumz's Avatar
what if you adjusted your latch up on the drivers side alittle bit????? i would try it and see what happens,
Old Nov 7, 2007 | 10:05 AM
cardana24's Avatar
Blown
It's already been addressed but no, not that. The little round rubber bumpers on either side of the radiator support is what I am talking about. If that does not help then I would adjust the latch.
Old Nov 7, 2007 | 10:08 AM
ROCKART's Avatar
wants an I35
this (the blue one..) from the pic it even looks lower than the left side..
Old Nov 7, 2007 | 10:21 AM
jvckustumz's Avatar
is there a place to roder those new, mine are all busted up on both sides lol
Old Nov 7, 2007 | 11:15 AM
cardana24's Avatar
Blown
yeah the blue one is what I am talking about. It might not be your problem but that is what I am talking about. You could always smack your fender with a hammer to lower it a bit to make it match
Old Nov 7, 2007 | 01:29 PM
wirelessdude04's Avatar
take a hammer and bang it into place lol. It doesnt look that bad
Old Nov 7, 2007 | 01:34 PM
BLACKonBLACK98's Avatar
Former Vendor
just raise the rubber piece up by turning it counter clockwise (blue)
Old Nov 7, 2007 | 03:49 PM
maxima985spd
get over it, seriously MDeezy is right... it's off by 4mm worry about gas prices or some other shieet
Old Nov 7, 2007 | 08:15 PM
JSMax's Avatar
Sold
if you remove your pinstripe, that will help
Old Nov 8, 2007 | 07:28 AM
jvckustumz's Avatar
i hate those damn things
Old Nov 8, 2007 | 07:31 AM
ROCKART's Avatar
wants an I35
i tried moving the blue arrow things up last night. probably moved them an inch upward. didnt do the trick.
Old Nov 8, 2007 | 07:33 AM
jvckustumz's Avatar
loosen the 2 bolts on tour hood hinge on both sides and widdle your hood around till it's lined up again, you also should look at boh hinges and see if it is warped alittle compared to the pass. side one
Old Nov 8, 2007 | 08:32 AM
ROCKART's Avatar
wants an I35
yea well im broke. i got no money to put stuff into my car right now. im preoccupied with repairs that are free.....
matts95max
Apr 23, 2025 10:44 AM
boomerbrian
Oct 31, 2018 10:25 AM
doctorpullit
Sep 10, 2015 06:33 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
Hailstatejig
Sep 2, 2015 06:52 AM
