Sabotage?: CV boot busted (2nd time in probably 50K miles)
Raxles are more than double than what Autozone charges - is it really worth it? Will they last more than twice as long? I have 63K miles on my '97 Maxima and the original CV boot just ripped. My guess is that whatever axle I put on the car now will outlast the remaining useful life of the vehicle. I'm inclined to use the ones from Autozone or equivalent unless someone can point out a flaw in my logic. Thanks
Also, any pointers on the installation?
the passenger side is the one with the 3 bolts. I just changed mine a couple of weeks ago. I was able to get the 3 bolts off with a wrench after that its supposed to slide out of the bracket, for me it didnt, I ended up takin off the bracket also(while attached to axle). Im also soon gonna have to change my driver side its starting to click and has a small tear somewhere.
I wonder if the gas in it is any good any more. J/k I do start it every now and then and let it run till the garage is full of CO.
Well, if anyone cares, I ended up using this clamp: http://www.partsamerica.com/ProductD...egoryCode=3530
Beware, though, because the item description says it's 750 mm long and it was more like 375 or something, and this part is supposed to be 365 mm long and it was way under that. It would not even fit around the big side of the boot.
Also, as for the clamps that came with the boot from Nissan, I'm not sure any tool was even required at all. While I screwed up the big one, on the small one I just bent the curved part extending outward from the clamp down onto the clamp and I tapped the little arm things over it and it was pretty snug on the boot. I'll bet I could have done that for the big one, too. I just thought that you needed a tool because of what everyone was saying. If you need clarification, I'd be happy to draw you a picture of what I'm talking about. At any rate, I'm rollin' again. A freakin' month to change a CV boot.
Man that's hilarious. I had wanted to try to change the right control arm, but I'm wondering if I want to put the car down for 4 months trying to do that.
Plus, hanging around under the car on jackstands, I don't know if I'd like that. I wish I had access to a lift.
My alignment is noticeably off. Or, at least, the steerting wheel is way clockwise of center when I'm driving straight. Could it be that I really screwed up my alignment when I disconnected the steering knuckle to get to the axle? Can I just adjust that wheel back until the car drives straight? I do not want to pay 80 bux for another alignment! WWDD? (What would dealerships do?) Would they realign it when they disconnected that stuff? Or was I just not being careful and I moved something out of spec?
They would re-align
Starrider
Sep 17, 2015 07:26 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
