Mevi Question..
Old Nov 12, 2007 | 04:20 PM
khantalha+'s Avatar
Mevi Question..
hey guyz i just got done putting mevi in my 95. got the wiring and every thing done... went to fire her up.... she started right up like nothings wrong with her and about 40-50 secs later started smoking from somewhere between fender wall and the motor.... ran it for about 2 mins but just kep on smoking....... didnot smell like gas or rubber so i know its not something big...... was just wondering if anyone else had a similar problem.
tnx.
Talha
Old Nov 12, 2007 | 04:27 PM
Spilled coolant getting burned off of exhaust components.
Old Nov 12, 2007 | 04:30 PM
khantalha+'s Avatar
that could be it....yeah i did cut some coolant lines to take em out but did replace em with the new ones...tnx ^^^^^^^^^^^^^^ anyone else?????
Old Nov 12, 2007 | 04:42 PM
bigpulve+'s Avatar
Does it still smoke? it is most likely the spilled coolant burning off...did you remeber to reattach the coolant lines on the back of the UIM?
Old Nov 12, 2007 | 04:49 PM
Originally Posted by mazzivart
........ UIM?
UIM??
Old Nov 12, 2007 | 05:03 PM
bigpulve+'s Avatar
UIM??
Upper intake manifold???
Universal incest manifesto???
Unadulturated infested monkeys???
unknown immoral maniacs???
Old Nov 12, 2007 | 05:24 PM
khantalha+'s Avatar
i did reattach everyline there was that i cut... i ll cehck it out in little bit... cuz it just started pouring rain out so...
Old Nov 12, 2007 | 05:32 PM
Winnar!!
You forgot United Intake Manifold. LOL
Old Nov 12, 2007 | 05:41 PM
bigpulve+'s Avatar
Winnar!!
I was thinking that something wasnt right with that one when I posted it...
Old Nov 13, 2007 | 01:17 PM
khantalha+'s Avatar
got everything wired up right way....cuz that geen light on my summit rpm switch does come on at 5100 to 5200 rpms but mevi wont open...my settings were 2400 rpm on the switch it self...did check all the vaccum line they all look good but no sign of mevi opening..?
Old Nov 13, 2007 | 01:39 PM
Maybe your vacuum lines are wrong....
Also, do you have a check valve somewhere in the system?
Old Nov 13, 2007 | 01:42 PM
Flava_24/7's Avatar
Boosted Panda
Im thinking the vac lines are wrong. What type of VSS are you using?
Old Nov 13, 2007 | 01:44 PM
96blkonblkse's Avatar
Alright heres what you should do.
I had the same problems, i re-did EVERYTHING.
My questions to you is:
What type of vacuum canister, how is your RPM switched wired up.
You should have a vacuum line coming from the intake manifold, or vacuum sourced t-eed off something, that should run to the INPUT of the vacuum canister. If your vacuum canister doesnt have a built in check valve you will need to place one between the vacuum line going to the vac canister.
second, you will have a vacuum line going from the OUTPUT of the vacuum canister going to the INPUT of the control solenoid. From there there should be 2 ports side by side and 1 on its own, the one on its own is a breather, that will attatch to nothing. The port beside the input will be the output, that port goes to the mevi actuator.
for the RPM switch, i had mine setup like this:
I tapped directly off the battery, wired in a inline fuse. That is for the red power wire, the black i grounded to the body. the white wire, or whtever color it is for the RPM signal i tapped off the ecu, should be the white with green stripe, i chose this over the tach because i had already tapped this wire for my safc2. Now here is the part where i think some people go wrong. the yellow ACTIVATION wire coming from the RPM switch needs to be hooked up to the GROUND of the control solenoid. For the positive on the control solenoid, i tapped into the power wire from the rpm switch after the inline fuse. this way i have both on a fused circuit.
My setup is a OEM nissan vac canister, check valve, dawes(GM) control solenoid, and summit RPM switch. If you would like i can post up pictures, if not search my username and you will see my issues with my mevi, i think i covered almost every aspect on it lol.
As for the smoke, make sure you hooked up those 2 PITA coolant lines near the EGR, i forgot to hook one up and realized it right away lol. The other thing is, if it continues to smoke, make sure the EGR is tight and the gasket did not fall off while you were putting it back on...trust me i know lol. I think i ran into almost every problem in the books.
good luck!
Old Nov 13, 2007 | 01:46 PM
khantalha+'s Avatar
Old Nov 13, 2007 | 01:49 PM
khantalha+'s Avatar
khantalha+'s Avatar
or may be i should use someother vaccume source lemme know
Old Nov 13, 2007 | 01:52 PM
You will want to T off a vacuuum source behind the throttle plate. There should be one just behind the TB, t he line kinda runs down underneath the TB. Alternatively you can T off the FPR, it is right near the "V" of the engine, by the knock sensor.
Old Nov 13, 2007 | 01:54 PM
khantalha+'s Avatar
aight i ll try that...
Old Nov 13, 2007 | 01:56 PM
bigpulve+'s Avatar
switch around the vacuum lines on the switch....You need to use one line on the side with 2 ports and one on the other side leaving on port on the 2 side open...You have a different version of switch then others...try that and see what happens
Yes its messy, but it has be fully re-wired so its a lot shorter of a distance and well it looks way nicer.
the two lines are backwards on the control solenoid, just never corrected it in that picture lol.
Good picture for those trying to figure out the wiring, becuse everything is so spread apart.
I believe his control solenoid is setup correctly, but play with it, i personally havent seen that one before so i cant say for sure.
Old Nov 13, 2007 | 11:14 PM
khantalha+'s Avatar
yeah ill try switching the lines around... that should do it but i dont have the car anymore its at my mechanis house getting a new clutch so ill just stop by there tomorrow and see what happens...thanks man
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
