Starter vs. Crankshaft Position Sensor
Old Oct 23, 2001 | 11:56 AM
jrtmouse's Avatar
I've got a 95 GLE.
Has anybody ever received the 0407 code from their ECU?
If it IS the crankshaft position sensor and NOT the starter, is this part easy to replace? Have any of you replaced this part? How do I tell if it's the CPS and not the starter?
Thank you.
Old Oct 23, 2001 | 01:24 PM
MardiGrasMax's Avatar
Re: Starter vs. Crankshaft Position Sensor
CPS is located where the motor and transmission meet, on the side facing the radiator. It a black things with a three wire harness connected to it, held in by a 10mm bolt.
The Chiltons book has a good discription on how to test it, Their ~$15.00 at most auto part stores.
Originally posted by jrtmouse
I've got a 95 GLE.
Thank you.
Old Oct 23, 2001 | 04:18 PM
cbr2's Avatar
I've got a 95 GLE.
Thank you.
Well if you can crank the car (at good speed AKA it sounds normal) but it won't fire off then it is the sensor.. If it won't crank it is the starter..
Old Oct 24, 2001 | 08:04 AM
jrtmouse's Avatar
I'm going to take the little darling in for a tune-up and see if they'll adjust or fix the CPS. I'll also look into testing the CPS myself to see what's going on.
Thanks for your help!
Old Oct 24, 2001 | 10:20 PM
got rice?'s Avatar
The CPS is only $15 on the Maxima? It's normally an expensive part ..
Old Oct 24, 2001 | 10:25 PM
emax02's Avatar
I think he meant the Repair manual . A CPS list for about $95 for a maxima, I got one for $67 from Courtesy nissan.
Old Oct 26, 2001 | 08:44 AM
jrtmouse's Avatar
emax, Was it simple to install yourself?
Old Oct 26, 2001 | 09:00 AM
Its easier than changing a spark plug!
Old Oct 29, 2001 | 10:10 PM
jrtmouse's Avatar
They checked the car out and said that the ECU has problems. They didn't seem to think it was the crankshafot position sensor. They told me that the car was doing some weird stuff and that I should take it to the dealer. Now I don't know what to do. I'm afraid the dealer will charge me up the yin yang just to look at the friggin' thing.
Has anybody had problems with the ECU or ever had to have it fixed or replaced?
Old Oct 29, 2001 | 11:45 PM
emax02's Avatar
The ECM{Engine control module} will spit out a MIL code if something is wrong with the ECM, unless of course the ECM is so far gone it can not even complete that task. I dought it is is the ECM, but good luck!
BTW the CPS is really easy to change, all you need to do is unplug it from the harness and then remove 1 10mm bolt, after that do the reverse to install.
mvm062
Nov 30, 2020 09:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
James92SE
Oct 8, 2015 04:57 PM
msellas
Sep 23, 2015 09:16 PM
ac max 92
Sep 17, 2015 07:35 AM
