Knock Sensor
Old Nov 19, 2007 | 02:45 PM
  #41
xkazik's Avatar
ok so i guess i just order from dealer when ever i will be about to change it . now i just need somone to help me lmao
Old Nov 19, 2007 | 04:03 PM
  #42
ROCKART's Avatar
wants an I35
i was pretty concerned with it all too. the online walkthroughs suck as far as pictures. i was imaging all these things going wrong and causing some sort of huge issue cuz of incorrect installation.
i was actually PMing local members offering them 40 or 50 bux to drive to my city and help me with it. but once i just sat and looked at it and started trying to map out what i was gonna do (or tell my neighbor to do) it was easy. like i said, the most consuming part of the job was getting the virgin bolt loose for the first time.
the moral of the story is just get a small girl or child who is willing to be bought with food and give them a small wrench and tell them to go to work. you dont even need an org member, just someone responsible enough to not drop the KS or the bolt into the manifold valley.
Old Nov 19, 2007 | 04:07 PM
  #43
andrei3333's Avatar
HMMMM Rockart, what have you come to...... soliciting minors for illegal underage work is soo unkool man !! hahahah
bribing them with burgers is cheap tho lol
Old Nov 19, 2007 | 05:36 PM
  #44
xkazik's Avatar
ROCKART don't u have to worry about the torque you put on the bolt ? like someone mentioned it before ? hmm i wish i could of lived in Fl maybe then your neighbor would help me haha .. but yea anyways so basically what u do is disconnect the battery then disconnect the harness then unscrew the bolt , put the new sensor in the with the harness attached and screw back on ? or did i miss something
Old Nov 19, 2007 | 05:42 PM
  #45
ROCKART's Avatar
wants an I35
yea i was mildly concerned. i told her to tighten it to "snug" and then had her practice on a couple of other random exposed bolts in my engine bay. i dont know what setting she ended up gettin it at, but its running fine. like i said i feel a very dramatic difference in pull.
its like i was driving a 4 cylinder before.
Old Nov 19, 2007 | 05:49 PM
  #46
xkazik's Avatar
i have 107,000 miles what about u ? should i change it ?
Old Nov 19, 2007 | 06:52 PM
  #47
andrei3333's Avatar
xkazink you got your instructions a bit wrong
Dont need to disconnect the battery, i duno about cali spec, but regular fed spec there will be a green connector in the way of the KS valey. remove it temporarily, do not remove the KS harness first, just undo the bolt and pull the whole assembly out, this way you will ge the KS out easier, and not loose the clip that holds it to the harness...
installation is the reverse. dont forget to reset the ECU after and only use 91 octane to feel any difference, otherwise there is no point replacing the KS if you wanna run 87
Old Nov 19, 2007 | 07:04 PM
  #48
ROCKART's Avatar
wants an I35
yea see the green connector in the first pic i posted. its labeled DISCONNECt.
i would just replace it anyway at 107k. use a 12mm bolt on an extension or just a 12 mm rachet and someone with small hands. its pretty easy to figure out once you are looking at it.
Old Nov 20, 2007 | 07:55 AM
  #49
scooby68's Avatar
Yes it is a sensitive sensor and its amazing how after having my parts guy deliver it a bomb proof package how quickly I managed to drop it 3 feet onto the concrete floor! I can't believe the bad luck I've had lately! Fortunately it worked fine and the car has had so much more pull that I'm driving it like the sports car that it is for the past two months.
Bad news is I pushed my remanufactured transmission so hard that I flushed out a flaw in its rebuild and it now needs its main bearing and or ring gear redone....again, its currently undriveable...........:{
Originally Posted by ROCKART
yea i paid 120 something from dave b at south pointe. ive seen a picture of the same one that i got from him at ROCKAUTO for like 66 bux.
you should know tho that when i ordered it from dave i asked him why and how rockauto could sell them so much cheaper. he said something like they get these generic parts and are manufactured in these huge companies in japan and as a result there is no quality control.
at that point i figured id spend the extra 60 to get the OEM nissan-backed one. after all this is a sensor, not just a peice of metal or plastic. i imagine its pretty fragile and prone to errors.
Old Nov 20, 2007 | 08:58 AM
  #50
UncleMax98's Avatar
No need to replace the KS if there is no code. You need to to read the code, however. A bad sensor does not light up the MIL.
Old Nov 20, 2007 | 09:35 AM
  #51
Blaxima95's Avatar
Owns way too many maximas
Why do so many people replace the harness as well? I know Courtesy sells a kit with the sensor and harness, but on all of the ones I have done, I never had to replace a harness. As long as your careful with removing the metal clip that is...
Old Nov 20, 2007 | 12:24 PM
  #52
Geophrum's Avatar
in my case i had some retard that owned the car before me and he put on the wrong Knock Sensor (looks like it came from an xterra.... plug is round not square like ours) and broke the Harness to make it fit.. HMMM wonder why the thing is bad!
so yeah i needed a harness too.. but i am getting a used one that should be fine..
Old Nov 20, 2007 | 12:29 PM
  #53
ROCKART's Avatar
wants an I35
actually in my hightened excitement i broke the little plastic tooth that holds the metal U clip in place around the harness. but i just bent it a little more than normal to keep it tight and it fit pretty well.
Old Nov 20, 2007 | 12:33 PM
  #54
ROCKART's Avatar
wants an I35
Old Nov 20, 2007 | 07:53 PM
  #55
andrei3333's Avatar
i see a rat's infestation in the back there lol
i have a tree growing in mine tho
Old Nov 21, 2007 | 05:38 PM
  #56
histo13's Avatar
KS replacement
I'm from pawtucket . I changed mine last year.Not really that bad as long as you got the right tools and of course patience. What year is your car? where 's in RI R u from.
Old Nov 21, 2007 | 07:14 PM
  #57
KRRZ350's Avatar
Originally Posted by xkazik
where can i get the knock sensor ? i mean besides the dealers any better places with better price ?
Forget that, where can I get a hot neighbor to do knock sensors for me?
Old Nov 27, 2007 | 06:19 PM
  #58
vilmaxima's Avatar
I was able to get my left hand in there(yeah i did get cut up, and is pretty frustrating) but after a couple beers and a little more patience I was able to get her off with a wrench(one with the fork on one side, and round on the other, I used the round part) then used a magnet on an extension to pull out the loosened KS. Didnt torque it cause my torque wrench wouldnt fit but I noticed more pull soon as I started driving.
Old Nov 27, 2007 | 09:11 PM
  #59
BlackMaxdout's Avatar
I wish I had neighbors that looked like that....
Old Nov 28, 2007 | 11:52 AM
  #60
EpzMaxima96's Avatar
I did mine. 1st I dropped the tools I used into the spot where the KS is and I got my hand in there and got the socket on the nut and just used a bar to crack the bolt and did it by hand afterwords...Tooks me about 30mins-1hr Nissan wanted to charge me $450 because it was a "4 Hour" Job...Ya if your taking off the manifold and the rest of the engine apart to get to it...Becareful sticking your hand down there its like razor blades litterally got cut up pretty bad...
Old Nov 29, 2007 | 03:56 PM
  #61
arpangurjar's Avatar
So I figured i would take a peek at my sensor too
My milage was horrible. So I removed to take a look,
And OH MY, it looks like a car had run over it. Its cracked and broken from 2 places.
But now when I check the resistances between pin 1 and 2 it give me 550 ohms. I know my multimeters range is 40M so its ok. But then it still give me the correct resistor reading. Does it mean its still good. Or I need to change it.
Any advise would be useful.
THanks
Old Nov 29, 2007 | 04:02 PM
  #62
ROCKART's Avatar
wants an I35
i have no idea but i would just change it for peace of mind. any "sensor" that is cracked is not functioning i guarantee. just spend 120 on an OEM one and get some kid to help you. its cake.
Old Nov 29, 2007 | 04:37 PM
  #63
Thanks Rockart,
I appreciate your reply, I would have wanted to post some pics but the forums dont allow me. I think I will do it myself because I am able to get my hands in there. I am pretty underweight, 95 lbs. and my wifes even smaller.
Appreciate it.
Old Nov 29, 2007 | 04:41 PM
  #64
Geophrum's Avatar
Ebay you sometimes can find them for like 70 shipped.. try looking there first
bought mine there
Old Nov 29, 2007 | 07:18 PM
  #65
scooby68's Avatar
550 k Ohms on KS
So I replaced mine a couple months back and the bad one read 550 k Ohms also, with and without the harness, same as the good one with the new harness......put the old one back in.....ran like crap.......put the new one in....runs like a racehorse! I don't know why, the piezo crystal may be firing when it shouldn't .......I dunno........I would replace it though and see for yourself. Buy a new box of bandaids before you do the job..and search "Knock sensor" for lots of threads on it.
THanks
Old Nov 29, 2007 | 07:24 PM
  #66
andrei3333's Avatar
Please! no one needs to spend 120 on a KS, every one knows that they are readily available for around $65 depending on the site and their shipping rules
Thanks Rockart,
Appreciate it.
something like this ?
Old Nov 29, 2007 | 07:31 PM
  #67
ROCKART's Avatar
wants an I35
yea as i said, www.rockauto.com has the generic one for 66 bux. but i asked dave burnette about it and he said it wasnt a good idea, especially for a sensor. then again hes a salesman.....
Old Nov 29, 2007 | 07:42 PM
  #68
andrei3333's Avatar
My sensor that i bought here http://catalog.eautopartscatalog.com...2b2187b0529cfa
looked exactly like the one i pulled out of the car, with the nissan logo, stamp, writing and quality control dot.
even if it was "fake" there is no one on this site that has yet to report problems using ANY of the sensors bought all over the place - even ebay
Its not even that an important of a sensor that you need to go all out .
Old Nov 29, 2007 | 10:02 PM
  #69
Tmcgradyfann1's Avatar
close but no cigar
Yea guys ebay has Oem Nissan Knock sensors made in Japan just check those out they are all around 60 dollars shipped. But yea rockart thanks for doing those pictures
Old Nov 29, 2007 | 10:17 PM
  #70
andrei3333's Avatar
Umm that last one is mine
Old Nov 30, 2007 | 05:29 AM
  #71
ROCKART's Avatar
wants an I35
no problem man.
just givin back to the community that has given me so much.
Old Nov 30, 2007 | 07:58 AM
  #72
Yes exactly like this
Whoa, you hit the nail right on the head, thats exactly how it looks -thanks andrei3333, I just ordered one from ebay, the original URASIA one that is OEM, and wiht a 5 year warranty. Waiting for it to come.
Thanks a lot all of you and specially Rockart and andrei3333 for the pics, I will report back after I recieve and replace it.
Have a good weekend.
Old Nov 30, 2007 | 08:17 AM
  #73
close but no cigar
I knew i forgot someone
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
