Anyone had a cracked radiator?
Old Nov 17, 2007 | 04:26 PM
MadMaxSE-L's Avatar
Doggah Bite...
Since my alternator went out, I was poking around under my hood, just checking some things to make sure the rest of my Max wasn't falling apart...
Come to find out, there is a ~5" long hairline crack in my top plastic radiator tank, right below the filler neck. It just seems to be seeping; but thereis no way I want to drive it around like that. If I put pressure on the filler neck, I can see the crack open up a little and some coolant comes out.
How does all this ****e happen at once?
Old Nov 17, 2007 | 04:34 PM
chillin014's Avatar
yep. replace. I got a metal one now.
Old Nov 17, 2007 | 04:52 PM
MadMaxSE-L's Avatar
Doggah Bite...
Yep what; you had the same problem? I know it will have to be replaced, I just wanted to know if this was a common problem. I have never heard of it before...
Old Nov 17, 2007 | 04:53 PM
chillin014's Avatar
mine had a small crack at the filler neck. Its an old plastic radiator, what do you expect?
Old Nov 17, 2007 | 04:54 PM
Fr33way™'s Avatar
Wild for Width
Group deal on Koyos IIRC. I wouldn't say it's common.
Old Nov 17, 2007 | 05:33 PM
MadMaxSE-L's Avatar
Doggah Bite...
Kewl, thanks for the info. I am hesitant to buy one from flea-bay...
Old Nov 17, 2007 | 06:19 PM
speed racer's Avatar
Yep it happens with plastic tops on the radiator. Get the Koyo or get a replacement from Autozone. Its not hard to do. You should also consider changing thermostat and hoses.
Old Nov 17, 2007 | 06:46 PM
MadMaxSE-L's Avatar
Doggah Bite...
I'm not really worried about the difficulty level; putting in a radiator is not exactly super-intensive work...
I will be doing rad/hoses/thermostat/coolant flush all at the same time.
Just gotta get my alternator fixed first...
Old Nov 17, 2007 | 07:25 PM
7jackmack's Avatar
Happened to me last week - 5" crack below filler neck. My engine had coolant
spritzed all over but I couldn't find the source until I parked one day and steam
was coming out . Hurried to open the hood and saw quite a stream briefly shoot
out of a practically indiscernable crack. $140.00 for radiator at Advance auto &
suprisingly it was in stock. I can't complain too much as I got 12 years , 285 K
out of the original radiator & hoses.
Old Nov 17, 2007 | 07:27 PM
MadMaxSE-L's Avatar
Doggah Bite...
Yours made it a little longer than mine did then. My 97 has 175k on it, but the Florida heat may have somethign to do with mine not lasting as long.
I am going to go with one of the rad's in the group deal section - they sound like a good deal.
Old Nov 17, 2007 | 07:28 PM
khantalha+'s Avatar
just got changing one in my dads car
Old Nov 17, 2007 | 08:15 PM
max ride 41's Avatar
go to a place that does rads and have it replaced. 248.00 to replace mine 6 months ago and i know it wont break again even though its plastic like the oem one. reason for plastic- no rusr like the solid metal ones.
Old Nov 17, 2007 | 08:35 PM
MadMaxSE-L's Avatar
Doggah Bite...
As I said before, I work on my own car. I have no need/will not pay for someone else to do something I can/like doing; working on my car.
Old Nov 18, 2007 | 05:52 AM
The plastic still has aluminum and its not the rust its the type of coolant you put in there or water. Always use distilled water.
Old Nov 18, 2007 | 05:54 AM
Yea, its not hard. One thing you may want to change is the by pass hose. Its a small 90 degree rubber elbow. You can get alot done with the radiator out. Like you said changing that alt my be the best thing to do also. You can change the belts as well.
Old Nov 18, 2007 | 08:47 AM
MadMaxSE-L's Avatar
Doggah Bite...
The alt. wil definately be going in at the same time, I'm going to get a H/O version to upgrade. I will also be doing all the hoses and everything; but the belts/idler pulley are less than a month old.
Old Nov 18, 2007 | 09:00 AM
dgeesaman's Avatar
Maintenance Monster
The plastic end tanks weaken with time and exposure to hot coolant.
My wife's eclipse popped a plastic rad tank this summer just like this. I bought an OEM-style replacement and installed it in a couple hours. Make sure to buy new rad hoses while you're in there. Yeah, metals tougher, but her car doesn't go to the track or anything, and the first rad lasted 160k. So plastic again. I can spend the extra $100 on beer to soften any worries I might have about it
Old Nov 18, 2007 | 09:02 AM
MadMaxSE-L's Avatar
Doggah Bite...
I like the way you think
Or, the extra $100 will damn near buy my alt...
Meh, I'll prolly get both anyway
Old Nov 18, 2007 | 09:50 AM
Crusher103's Avatar
Mine cracked and I had to use superglue for a while to the coolant in, got another OEM plastic one thou it last close to 200K
Old Nov 18, 2007 | 09:56 AM
MadMaxSE-L's Avatar
Doggah Bite...
I was actually thinnking about doing somethign similar to this; I was going to drain the coolant out and open the crack up as much as I could, then fill it with silicone and let the tank go so it owuld hold the crack together.
That was going to be my temp fix, but I think I am just going to get a new one.
Old Nov 18, 2007 | 10:24 AM
fat_kid's Avatar
it happens
Old Nov 18, 2007 | 12:01 PM
J-hop's Avatar
i doubt silicone would hold, if you need a temporary fix just use some JB-weld
Old Nov 18, 2007 | 03:37 PM
jstew's Avatar
JB-weld didn't work well for me. It held for about 3 days then coolant started seeping around the edges of the weld. Luckily my ebay radiator came in the mail 2 days later.
Old Nov 18, 2007 | 06:36 PM
Fr33way™'s Avatar
Wild for Width
1.) intsall Koyo
2.) take pics
3.) upload write-up
4.) ???
5.) profit
Old Nov 18, 2007 | 06:39 PM
dgeesaman's Avatar
Maintenance Monster
LOL at the suggestions of jb weld and silicone. Buy a new radiator already. No need for anything fancy.
Dave
Old Nov 18, 2007 | 06:50 PM
J-hop's Avatar
IE it will get you around for a few days until you can find a reputable shop to do the work or get one shipped, it should never be a permanent fix but some of us don't have the option of having our vehicles out of commission for an extended period of time.
Old Nov 18, 2007 | 09:48 PM
MadMaxSE-L's Avatar
Doggah Bite...
1.) intsall Koyo
2.) take pics
3.) upload write-up
4.) ???
5.) profit
my plan in the end
Old Nov 21, 2007 | 09:33 AM
Max Noob's Avatar
yeah....Jb weld, the only stuff that might have worked, lasted about 3-4 days. get a new radiator off radiatorbarn.com .. 130ish shipped. 2 row aluminum radiator. it is good not great quality, but it should last the rest of the life of the car with regualr maintenence. unless you live in the desert or a really cold state , i doubt u need a truly hi performance radiator,
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Excalibur23
Oct 13, 2015 04:33 PM
Andy29
Sep 29, 2015 05:32 AM
