What is wrong here
Old Nov 20, 2007 | 12:23 PM
Kof's Avatar
Kof
What is wrong here
I have noticed that my car fishtails a bit when i hit like a bump in the road. Its nothing severe but definitely noticeable. I have also noticed this happening more especially while making a turn, the rear end will shift a little as if i was drifting(i know im not drifting or even going fast). But it just seems like my rear doesnt grab the road after a bump. What could this be?
Old Nov 20, 2007 | 12:25 PM
IlyaK's Avatar
The Golden One
Struts are bad. I think that's the what causes this...
Old Nov 20, 2007 | 01:13 PM
Kof's Avatar
Kof
Thanks i thought it was what but a second opinion always helps.
Old Nov 20, 2007 | 01:28 PM
Peebs187's Avatar
Take it in to a mechanic and have him look over your suspension. Could be bad bushings too, and I hear they are a pain to do.
Old Nov 20, 2007 | 02:44 PM
Snypa's Avatar
struts/suspension
Old Nov 21, 2007 | 06:03 AM
dralucard's Avatar
i had a combo of bad struts & crappy tires. i also did the springs at the same time.
Old Nov 21, 2007 | 06:20 AM
maxima1239's Avatar
It has to be the struts. My 3rd gen was doing that to.
Old Nov 21, 2007 | 06:27 AM
MaXiM@KiD's Avatar
MaXXiN
check struts and bushing...not sure if you have lo pros or not...but also check you tires are in correct rotation ..one time i lend my bro the car and i dont noe wtf happened but when i got the car back they tires where switched...i only happened to noticed when i felt like i had no traction...wierd ...but hey ish happens sumtimes...good luck
Old Nov 21, 2007 | 06:51 AM
mowgli29's Avatar
Horizontally opposed.
Check tire pressure. You'd be surprised what under/overinflated tires can do.
I had a low rear tire once, and it slid bad enough it was hard to drive quickly.
Old Nov 21, 2007 | 07:26 AM
|Bijan|'s Avatar
UCF Lexus
You MIGHT have the special edition RWD Maxima
Digitized's Avatar
are you dropped? or stock height?
with the "trailing arm" suspension ( the beam between the rear wheel), the feeling of the rear sliding out should be very minimal..
Old Nov 21, 2007 | 07:40 AM
LILMAN's Avatar
If it's your shocks get them fixed before it starts snowing. You don't wanna be fishtailn with snow on the ground.
Blackwind's Avatar
its the suspension. my wifes car does that all over the place. still stock and bounces like a 77 deville
Old Nov 21, 2007 | 08:18 AM
Snypa's Avatar
wish i had that.
Old Nov 21, 2007 | 09:16 AM
nick_auto96's Avatar
Your handling mods? Do you have a aftermarket shocks/spring and or rear sway bar? That would help to narrow down the problem
Old Nov 21, 2007 | 11:41 AM
JtzMax's Avatar
Whatchyou say?
Could be poor tires too ... but I'd suspect struts
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
