closed loop module
Old Nov 18, 2007 | 03:54 PM
Xzecution'R's Avatar
closed loop module
i still have code 0308. changed the o2 sensor and checked the wire under DC 20 and my numbers came up, heater is 13.5, ground .2 and the black wire .7-.8. it comes on when i got the engine @ 2-3 g's for maybe a minute mostly on the hwy.
Old Nov 18, 2007 | 03:56 PM
btw it's only for the rear bank 1,3,5
Old Nov 18, 2007 | 04:01 PM
pmohr's Avatar
No more Maximas...
Did you check any of the other items listed in the FSM as a possible fault for P0150?
Old Nov 18, 2007 | 04:05 PM
pmohr's Avatar
No more Maximas...
Left == front == 2, 4, 6
So, which is it?
Old Nov 18, 2007 | 10:16 PM
0308
Diagnostic Trouble Code 0308 points to a problem with the Engine Control Module Closed Loop Logic for the Right Bank. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5
P1168 --- 0308 http://forums.maxima.org/showthread.php?t=76800
P0151 --- 0308 http://forums.maxima.org/showpost.ph...67&postcount=7
WTF???
Old Nov 19, 2007 | 02:56 AM
pmohr's Avatar
No more Maximas...
0308
WTF???
Mine is straight from the FSM, i.e. Nissan themselves. I can tell you which I'd rather trust...
Old Nov 19, 2007 | 02:11 PM
can u give me the info. on the fsm for the code? thanx
Old Nov 19, 2007 | 02:55 PM
pmohr's Avatar
No more Maximas...
Which O2 did you replace? Front or rear?
Old Nov 19, 2007 | 06:20 PM
i replaced the one closest to the firewall.
Old Nov 19, 2007 | 06:37 PM
NmexMAX's Avatar
dot dot dot ...
So, then, maybe you changed the wrong sensor.
Old Nov 19, 2007 | 06:48 PM
pmohr's Avatar
No more Maximas...
I would take out the 'maybe', myself.
Old Nov 19, 2007 | 06:51 PM
NmexMAX's Avatar
dot dot dot ...
Just trying to state it as subtly as possible.
Old Nov 19, 2007 | 07:46 PM
i'm confused cu'z that's 2 nissan FSM's now one is urs and the other's is 99blkonblkse's they they contradict eachother and the site has 2 diff. defenitions as well.
Old Nov 19, 2007 | 08:02 PM
pmohr's Avatar
No more Maximas...
Where's his listed?
Old Nov 19, 2007 | 08:04 PM
dunno but he's got it for every nissan from 90 and up. he works for nissan too.
Old Nov 19, 2007 | 08:06 PM
pmohr's Avatar
No more Maximas...
I used to work for Nissan too, I fail to see the relevance
Is he saying that or does he have a pic showing it?
Old Nov 19, 2007 | 08:08 PM
NmexMAX's Avatar
dot dot dot ...
I never worked for Nissan.
Old Nov 19, 2007 | 08:13 PM
NmexMAX's Avatar
dot dot dot ...
That's exactly what my 95 FSM states. Page EC-153
Old Nov 20, 2007 | 08:45 PM
replaced the front O2 closest to the rad and no more code thanx for the help guys
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
