2008 Hesitates
Old Nov 20, 2007 | 08:08 AM
sparky1562's Avatar
2008 Hesitates
Title is wrong, can't change it. This is about a 1998!
A friend has a 1998 Maxima that hesitates when accelerating between 30 to 45 mph, fast or slow acceleration, and usually when the engine is hot. It is worse on hot days then cold.
Car has 180K miles, no upgrades, original injectors and knock sensor, as far as we know.
Where should we be looking for a solution?
Old Nov 20, 2007 | 08:30 AM
Snypa's Avatar
stickies probably.
Old Nov 20, 2007 | 09:57 AM
heynow's Avatar
+1, check for codes tooo.
Old Nov 20, 2007 | 12:06 PM
mowgli29's Avatar
Horizontally opposed.
Describe hesitates...
Does is seem like cylinders are missing? Maybe off balance and vibrating?
Does the engine just bog down?
Does it really just hesitate, or stutter in a way?
Auto or 5spd?
are you sure it's only 30-45? Does it do the same thing in different gears in that speed range?
Old Nov 20, 2007 | 12:25 PM
IlyaK's Avatar
The Golden One
Might be TPS also...who knows...
Old Nov 20, 2007 | 12:48 PM
DEVINEER's Avatar
Thats funny cause im having the same problem.
Mine is a 98, SE, and Auto. I also just serviced my K+N filter. I hope its not the MAS.
Old Nov 20, 2007 | 01:04 PM
IlyaK's Avatar
The Golden One
It could also be the MAF...good catch. Try cleaning your TB, IACV, and MAF.
Old Nov 20, 2007 | 01:34 PM
JtzMax's Avatar
Whatchyou say?
AutoZone, pull codes then re-post the codes ... or better yet, check the Stickies for the codes.
Other than that .... clean the MAF, TB, and IACV .... make sure you don't have a vacume line off.
Cheers!
Old Nov 20, 2007 | 04:53 PM
sparky1562's Avatar
Thanks!
Thanks guys. I read through all the stickies. He is going to change the plugs anyway. If that doesn't help, then we'll clean the MAF, go after the TB, etc.
I told him to check for codes before he does anything.
Old Nov 21, 2007 | 10:04 AM
DEVINEER's Avatar
P0325---KNOCK SENSOR!
Old Nov 21, 2007 | 10:17 AM
mowgli29's Avatar
uhh no.
That just retards the timing, resulting in lost power, not hesitation.
Old Nov 21, 2007 | 12:16 PM
DEVINEER's Avatar
Well....Thats the code i pulled on mine so im going to test it out this weekend.
Old Nov 24, 2007 | 09:04 AM
sparky1562's Avatar
Originally Posted by mowgli29
uhh no.
I agree, not the problem.
James92SE
142
Jan 2, 2024 09:23 AM
6spd4dsc
Mar 4, 2016 05:19 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
JoelP
Sep 19, 2015 01:08 PM
