Passenger door problems
Old Oct 23, 2001 | 10:28 PM
rkisa's Avatar
The front passanger door is difficult to open and close. Everything appears normal and it doesn't shut unevenly it's just hard to open and close. Any ideas?
Old Oct 24, 2001 | 09:06 AM
Toolrocks's Avatar
Was the car in a wreck? Have you had body damage? IF not then maybe someone leaned on the door to hard or something, I know there are adjustments for the door, check out a Haynes manual or equivelant. Also lube the door guide slide.
Old Oct 24, 2001 | 09:24 AM
mzmtg's Avatar
Minister of Silly Walks
Lubricate the hings and the little slider thingy.
Or, just jump through the window like Bo and Luke Duke.
Old Oct 24, 2001 | 11:11 AM
njmaxseltd's Avatar
Lube up the hinges and especially the door slider. It's that black plastic piece that rides in and out of the door as it opens and closes. This is a known culprit of "Sticky/Tight" doors on the 4th gen. Mine was replaced by Nissan shortly after I baught the car.
Old Oct 24, 2001 | 11:35 AM
AgtXmas's Avatar
Try using a silicone lubricant (as opposed to WD-40.) It worked great on my back doors when they were having difficulty opening. Spray some on the hinges, and move the door back and forth to work the lubricant in. Just make sure you don't inhale any of it.
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
maximusrising
Sep 2, 2015 09:55 AM
Hailstatejig
Sep 2, 2015 06:52 AM
