Is there a HOW TO on cleaning the EGR without removing it?
Old 11-26-2007, 12:53 PM
JoshBarber's Avatar
j/w
JoshBarber is offline
Old 11-26-2007, 12:59 PM
Blackwind's Avatar
seafoam mabey. other than that no i dont think.
Blackwind is offline
Old 11-26-2007, 02:40 PM
black_maxed95's Avatar
seafoam wont really do much for the egr. remove it and scrub away
black_maxed95 is offline
Old 11-26-2007, 02:50 PM
JoshBarber's Avatar
having trouble seeing what exactly needs to be removed, sounds like a tube - but Im not sure WHICH tube, and how you remove it?
I have plenty of throttlebody cleaner and high pressure air to clean it out...but I need to know what and where to get at it first
Old 11-26-2007, 06:08 PM
andrei3333's Avatar
andrei3333 is offline
Old 11-26-2007, 06:11 PM
f550maranello2's Avatar
man quit being lazy and remove it....
f550maranello2 is offline
Old 11-26-2007, 06:24 PM
andrei3333's Avatar
or buy a new one and replace it if you cant clean the old one
Old 11-26-2007, 06:51 PM
Max Noob's Avatar
no way.. thats 10 years of old solid carbon buildup, from what i heard, it feels and looks like a peice of coal inside the egr valve. u also have to worry about the lines feeding intot he egr valve cause they get pretty messed up too.
Max Noob is offline
Old 11-26-2007, 08:20 PM
Hammy
How much is a new egr?
Edit:
http://www.courtesyparts.com/Merchan...ode=14710-A32B
Old 11-26-2007, 08:22 PM
i used a cut up coat hanger and busted my way through it!
Old 11-27-2007, 05:19 AM
JoshBarber's Avatar
wow. is it common for them to be THAT backed up?
Old 11-27-2007, 06:21 AM
2da mizzax's Avatar
Originally Posted by andrei3333
Hey you still have that?? I forgot where I put that file.
2da mizzax is offline
Old 11-27-2007, 06:34 AM
Double E's Avatar
I'm interested in this thread... Thanks for being here. Please forgive the hijack but I have a related question...
I'm wondering if anyone can provide "operational theory" of the EGR valve? Like....what it does, what it means for it to clog and any improvement realized from cleaning or replacing it.
FYI To date:
I replaced the KS (tough but possible with some creative toolwork & small hands)
I had all 3 O2 sensors changed
I took apart the IAC and cleaned it up (it was DUHRTY!)
I also pulled the TB and cleaned it (also DUHRTY)
160K miles
I've got no codes and it's running great. I do have some long cranking time 'till it fires though...
Last edited by Double E; 11-27-2007 at 09:17 AM. Reason: forgot to add the O2 sensor change
Double E is offline
Old 11-27-2007, 06:55 AM
jvckustumz's Avatar
i have 215xxx miles and mine has never been cleaned, i heard it was a ***** to do tho but i should prolly clean it, has anyone ever had the studs break off due to the rust???
jvckustumz is offline
Old 11-27-2007, 07:12 AM
2da mizzax's Avatar
it helps keep the combustion chamber cooled. recirculates unburned fuel that may be in the exhaust. it clogs because the tube was designed with too sharp of a bend, but considering it doesnt get clogged until around 100k miles, its not that big of a deal. not like you have to do it every year or something.
the studs wont break due to rust. rust is your friend here since if they are really rusty, the studs will come out before the nuts come off.
Old 11-27-2007, 07:19 AM
jvckustumz's Avatar
sweet, i was worried that a stud would break off and i would be in a big mess
Old 11-27-2007, 07:29 AM
Snypa's Avatar
agreez that he should remove it.
Snypa is offline
Old 11-27-2007, 08:18 AM
Blackwind's Avatar
30 mm open end wrench will do the trick. trust me.
Old 11-27-2007, 08:19 AM
JoshBarber's Avatar
what nut is 30mm?
Old 11-27-2007, 08:45 AM
JoshBarber's Avatar
safe bet that a 96 Maxima with 140k has a clogged EGR pipe?
Old 11-27-2007, 09:02 AM
Double E's Avatar
Josh,
Same bet goes for the 97 I30t with 160K?
If I'm passing emissions, I have no codes & I'm getting over 400miles on a tank in mixed driving, I'm thinking that only the marginal lowering of combusion chamber temps would provide any performance benefit.
My position (for now) is to not bother unless I'm given a good case to do it...anyone?
Double E is offline
Old 11-27-2007, 09:06 AM
JoshBarber's Avatar
Originally Posted by Double E
Josh,
I wasnt stating it..I was asking the question IF its a safe bet that mine is clogged if its never been cleaned and its a 96 with 140k
Old 11-27-2007, 09:15 AM
Double E's Avatar
Whoops...I missed the ? mark, thanks.
I'm thinking that you're ok as am I...
I'd sure like to see the pics from what BlackMaxed was able to do with his before & after...
Double E is offline
Old 11-27-2007, 12:24 PM
Blackwind's Avatar
Originally Posted by JoshBarber
what nut is 30mm?
the end of the tube.
Old 11-27-2007, 12:27 PM
jvckustumz's Avatar
what did you do?? just unbolt the end of the tube to clean it??
Old 11-27-2007, 01:07 PM
2da mizzax's Avatar
incorrect.
it is the small tube that needs cleaning. not the large one.
Old 11-27-2007, 04:15 PM
Mctwist77's Avatar
What kind of gains can be regained from cleaning this beast?
Mctwist77 is offline
Old 11-27-2007, 04:21 PM
andrei3333's Avatar
^ yes 2da mizzax i keep every file regarding to maxima's
and no MCtwist77, you cannot gain gains by regaining them lol
you would be returning to oem spec and not see a gain per say. a gain is an improvement over stock. in this case it is probably negligible
Old 11-28-2007, 01:34 PM
vilmaxima's Avatar
I just cleaned mine a couple weeks ago, when I took off my intake manifold to be painted, and man was it CLOGGED, anyways did anyone have a gasket in between there? Cause i sure as hell didnt, someone at Nissan said it should have one, is that true?
vilmaxima is offline
Old 11-28-2007, 02:24 PM
2da mizzax's Avatar
its there. its metallic and prob stuck on the plenum.
Old 11-28-2007, 02:45 PM
TunerMaxima3000's Avatar
does it need to be replaced ?
TunerMaxima3000 is offline
Old 11-28-2007, 02:48 PM
i wasn't aware that it in any way cooled the combustion chamber,
i thought it'd be more likely to do the opposite.. hmm
Old 11-28-2007, 02:54 PM
2da mizzax's Avatar
ideally. but you should be ok if you didnt.
Old 11-28-2007, 03:47 PM
JoshBarber's Avatar
has anyone had a clogged EGR tube/system and noticed that it relieved the hesitations after they cleaned it?
Old 11-28-2007, 04:21 PM
aussie983's Avatar
was wondering exactly the same thing... feels like my car bogs and hesitates a bit with warmer weather so im thinking the engine would cool itself better once this is done.
aussie983 is offline
Old 11-28-2007, 04:40 PM
JoshBarber's Avatar
Im not trying to beat a dead horse here, its just that my gf can't find the printout with her original code on it so I can confirm the code was for a clog as opposed to something else EGR related - and it's cold as a witches tit at this point. So I don't want to pull the **** apart in this weather only to find out it made no difference.
Old 11-28-2007, 04:50 PM
7jackmack's Avatar
I noticed NO change in performance (car was running just fine) .
I cleaned the egr port simply to eliminate the check engine lite, because
the car would not have passed emissions test with cel lit.
7jackmack is offline
Old 11-29-2007, 08:00 AM
Blackwind's Avatar
incorrect.
no you ar INCORRECT! to take off the LARGE TUBE you can use A 30MM OPEN END WRENCH!! which seems to go in line with the instructional photos in the picture. if he his replacing the EGR VALVE then this would be a benifical step in aiding his progress. please do not question me, i HAVE removed this part from my car several times and i think i know a little bit about what i am saying.
Old 11-29-2007, 08:35 AM
JoshBarber's Avatar
why does it say "Banned" underneath your name?
I think when he said you were "Incorrect" he meant that the Large pipe isnt what needs to be cleaned...the small one does.
Old 11-29-2007, 09:33 AM
leewang's Avatar
Like 7jackmack, my 96 NM runs very well with the ECL on (P0446, P1400). Even there is no difference to clean EGR system still I'll try to work on it. Who can provide more detailed pictures for cleaning both EGR valve and EGR solenoid valve? Appreciate!
leewang is offline
Quick Reply: Is there a HOW TO on cleaning the EGR without removing it?
