Going all out on 4th gen auto
Old Oct 23, 2001 | 11:35 PM
A-Ron Max's Avatar
I've descided that when i get back home in about a month and a half i'll splurge on my max and give it the bolt ons it needs
1. swap in CAI for my Stillen
2. Don's VB mod
3. JWT ECU
4. UDP
5. (maybe) RT CAT
Do you think with all of these and my Y pipe that i'd break into the 14's? or is that just a dream for an auto?
Old Oct 23, 2001 | 11:38 PM
NZ Max's Avatar
Re: Going all out on 4th gen auto
2. Don's VB mod
3. JWT ECU
4. UDP
5. (maybe) RT CAT
interested in my tip tronic mod?
Old Oct 24, 2001 | 12:01 AM
A-Ron Max's Avatar
Haha sounds a little sketchy, would it really make the max accelerate faster then just having the auto with the VB mod?
Old Oct 24, 2001 | 12:05 AM
NZ Max's Avatar
no probaly not. it means that you will be able to change gears hen you wan and not when the tranny gets around to it. Also I will test to see if the lockup can be used under load in other gears. A prototype controller is being built at the moment.
Old Oct 24, 2001 | 12:32 AM
black019's Avatar
where can i read more about the tip tronic?
Old Oct 24, 2001 | 06:16 AM
BLacKMax69's Avatar
im think i would like a tip tronic
Old Oct 24, 2001 | 06:26 AM
Sprint's Avatar
going all out would also include 5spd Swap
Old Oct 24, 2001 | 07:35 AM
1MAX2NV's Avatar
I doubt it. With all those bolt on mods, on a really cold day. You might pull 15.2-15.3. There are plenty of auto max out there with all the bolt ons. None in the 14s.
Old Oct 24, 2001 | 10:49 AM
maximaman1997's Avatar
Sub 14s
Are you sure. I thought Don in TX (The VB guy) got his under 14. It was documented once last year I thought.
Old Oct 24, 2001 | 10:54 AM
Rooster286's Avatar
From what I hear about Don's car, is it's about as tweaked as humanly possable
Old Oct 24, 2001 | 11:58 AM
1MAX2NV's Avatar
Re: Sub 14s
He doesn't count. He actually trailer his car to races. He probably have some track only suspension setup and engine setup.
Old Oct 24, 2001 | 12:59 PM
NZ Max's Avatar
No where, its in my head at the moment.
and since I cant seem to be able to make a web page, thats where it will stay for the time being.
Old Oct 24, 2001 | 02:39 PM
Re: Re: Sub 14s
He put it on the dyno at the shop that I use here in Houston. I would have to ask them, but I think it's street legal. Still pretty quick for a heavy car with an automatic.
Old Oct 24, 2001 | 03:08 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Sprint is right, this conversion would be the best thing (besides boost) to increase speed. I'm gettin it done sometime in the future, but got a special deal. I suggest you do the same
Old Oct 24, 2001 | 04:01 PM
SuDZ's Avatar
Cant go wrong with a 5 speed. Can I suggest a Y pipe in yopur list? That should help you out also since your already down there doing the CAT.
SuDZ
Old Oct 24, 2001 | 04:59 PM
Kashoggio's Avatar
going all out in mind includes about 300 more parts
Old Oct 24, 2001 | 06:22 PM
A-Ron Max's Avatar
I already have a Y pipe, i'd totally go for a 5 sp conversion, but i wouldnt' want to spend more then about $1000 on something like that or I'd be wondering why I didnt' just sell my car and BUY a used 5 speed, i'm sure the $$ hit i'd take probably would be less than $1000 since my GLE is worth a little bit more.....Is this possible to do for under 1k without me having to install anything? and if so, wouldn't there be a risk of something going wrong at all?
Old Oct 24, 2001 | 06:36 PM
Will Max's Avatar
Wait a sec, are you guys telling me that if an auto GXE had a complete or custom catback, aftermarket cat, aftermarket Y-Pipe, Don's VB Mod, and an ECU upgrade, he still would not run 14s?
Old Oct 24, 2001 | 06:38 PM
Will Max's Avatar
Wait a second, are you guys telling me that if an auto GXE had an aftermarket intake, complete or custom catback, aftermarket cat, aftermarket Y-Pipe, Don's VB Mod, and an ECU upgrade, he still would not run 14s? What's the point of modding a auto max then and why do people do it?
Old Oct 24, 2001 | 06:39 PM
Will Max's Avatar
BTW, add an UDP in that list, and I find that hard to believe.
Old Oct 24, 2001 | 06:45 PM
A-Ron Max's Avatar
I think a lot of the reason it wouldn't run 14's is because of the launch. From a rolling start I think a modded auto would easily take out a stock 5 sp. especially if the 5 sp. isn't a great driver.
Old Oct 24, 2001 | 06:53 PM
thebigsadler's Avatar
1000$ = going all out????
try spending 7000$ in a week like i did last week.. that's going all out.. and i dont want a CEL on all the time so i wont do a 5spd conv.. plus my car is slow.. 18's and bags.. 400lbs in stereo.. shiat.
Old Oct 24, 2001 | 07:21 PM
SWEETSOUND2001's Avatar
1. swap in CAI for my Stillen-keep the stealin
2. Don's VB mod-yes
3. JWT ECU- maybe
4. UDP- yes
5. (maybe) RT CAT - Ditch it and get a Y-pipe and a B-pipe
6. Get lighter wheels and lose as much weight as possible. At this point you'll be close to 15 flat.
Old Oct 24, 2001 | 08:21 PM
98sterlingmist's Avatar
I have given up on my Auto. Everything I do slows me down.
Old Oct 24, 2001 | 08:45 PM
A-Ron Max's Avatar
sorry, by "all out" i ment on n/a performance...not handling, looks, or stereo. Personally, i think w/the ftsb, and rsb, the max handles great, it looks fine, and since i don't listen to rap or any music w/a lot of bass, the bose sound system is more then fine for me.
Old Oct 24, 2001 | 09:13 PM
Nismo87SE's Avatar
Your forgetting one of the most important things, a higher stall torque convertor. Since your going all out just buy 2 spare 15in rims and run some 205/50-15s. This will give you shorter gearing and higher trapspeed. I've seen a simularly modded max run 15.1-15.3 at HRP.
2. Don's VB mod
3. JWT ECU
4. UDP
5. (maybe) RT CAT
Old Oct 24, 2001 | 09:17 PM
Nismo87SE's Avatar
Re: Re: Sub 14s
Actually last time I seen him run he was using the tokico/eibach setup. Also he only had bolt ons (I/Y/E/UDP/ecu) but he did have his VB mod and a L10 TC. On his first and only NA pass he did like a 14.9 @ 91 with a 2.29 60ft IIRC on slicks. Given a better launch (not bogging like on that run) his car NA is good for 14.6-14.9s.
Old Oct 24, 2001 | 11:23 PM
black019's Avatar
7000k in one week? wish i could throw that kinda weight around...
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
