jwt cam
Old Nov 27, 2007 | 08:46 PM
thebandit6000's Avatar
96 pearl white max
jwt cam
does the jwt camshaft bolt directly in or do you have to buy bigger pistons and valves.
Old Nov 27, 2007 | 08:54 PM
MorpheusZero's Avatar
Do not buy this product.
Old Nov 27, 2007 | 09:03 PM
BlackMaxdout's Avatar
AHAHAHAHAHAHAHHA. He can buy it all he wants....just let someone else put it in
Edit: yes, please bore the stock VQ and buy bigger pistons and valves.
Old Nov 27, 2007 | 09:15 PM
JonBlz's Avatar
a.k.a. STuNtMAN
wut do the jwt cams do how much HP u get out of this and whats the benefit u get outta them
Old Nov 27, 2007 | 09:19 PM
96 pearl white max
you get better top end and 20-25 more hp. a little bit better mid range to.
Old Nov 27, 2007 | 09:21 PM
OnEBadAsSi30's Avatar
It says specifically on his website the lobe lift and duration and true dyno proven gains. And Yes it bolts "directly" in Also it says on certain cams to use only the JWT springs and shim kit. PLEASE research before you consider buying or putting this product in. It's alot more work than you may think it is. Research on the .org would be your best bet or even contacting JWT.
Old Nov 28, 2007 | 07:26 AM
nice grammar....
why don't you google the JWT website and find out?
To put it generally, cams will give you better mid or high end due to longer valve lift duration, and changed angles between intake and exhaust timing. Most of the time your low end will suffer and you'll end up with a loping idle.
Old Nov 28, 2007 | 07:30 AM
jvckustumz's Avatar
blop blop blop blop reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeerrrrrrr
my buddys hondata sound like that with a cam lol, just had to throw that in, it is so ****ing funny to hear than sob lol
Old Nov 28, 2007 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/oldthread.php?t=345006&page=2
Old Nov 28, 2007 | 08:26 AM
BLACKonBLACK98's Avatar
Former Vendor
good read... thanks.
*edit* any idea what the installation issues were?
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
gustavison
Oct 4, 2015 06:50 PM
Mahmuth
Sep 25, 2015 10:08 AM
