easiest way to syphon gas (im not stealing)
Im trying to get the gas out of my parts car. it has about 2/3 of a tank left. i tried syphoning but there must be a screen that prevents a hose from going into the tank.
what is the easiest way for me to get this gas out?
Turn the car upside down and push the little flap aside with a stick
Drill a hole in the bottom of the tank and hope it doesn't spark
Seriously you actually might not want that gas depending on how long it's been sitting.
thanks thats a good idea. hope it will work
To get power there is a relay on the drivers side behind the kick panel. If you can put a battery in the car just use a wire to jump the terminals. If not just hook up a battery there. The pump doesn't pump very fast but it will work.
thanks again, i wouldnt have thought of that
Also don't remove the fuel filter. Just cut the hose after the filter and shove a larger diameter hose over it. Like a garden hose 6 feet long so the gas can can sit on the ground. Or just pull the other max up next to it and throw the hose in the gas tank.
ef9
Oct 4, 2015 08:43 AM
