rear brake prob
Old Oct 24, 2001 | 01:52 PM
is5150's Avatar
rear brake prob
here is the problem;
my wife has a 1999 nissam maxima and it has 45000 miles on it. the car runs great, but last week she had the squealing comming from the brakes. i took the car to pep boys(my trusted friends work there) and was informed the right rear was metal to metal and the left rear rotor needed replacement. and the front brakes were in perfect condition. i had pep boys replace brakes and rotors. i am not a novice to car repair, so my question is, has any one had a simular prob? i am thinking this might be a prob with the Proportioning valve. thanks for and info.
Pat Boytis
Old Oct 24, 2001 | 03:07 PM
Chunger's Avatar
My other car is a Hybrid
Re: rear brake prob
Pat Boytis
I only have 40K on my car...about 30K on the Stillen brake pads in back... I just checked a couple of months ago and I still have about 60% or more... I think your wife's car is going thru the rear pads quite fast (even OEM pads). Keep a close watch on it... look at the pad material every 10K when you take of the rear wheels.
Old Oct 24, 2001 | 04:26 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: rear brake prob
Pat Boytis
i changed my back brakes at 90,000 .. yes thats correct and they were stock. the were almost completly gone. one thing that may have happened is that your rotors were warped in the rear.if so pep boys took care of that. chunger said it best check them when you rotate the tires. good luck
Old Oct 24, 2001 | 06:06 PM
sinewave's Avatar
That's pretty low miles for the rear brakes to last. You might want to check to see if your emergency brake cables are too tight or are sticking. Another possiblity is that your wife has a tendancy to drive off with the brake still engaged.
Old Oct 24, 2001 | 06:52 PM
maxperformance's Avatar
Re: rear brake prob
Pat Boytis
I have a simular but a much worse problem,When i got out my 1995 Maxima, i heard a loud pulsing beep noise, i was scared at first i didnt know what the hell to do, i didnt have my cell phone on me. . and it was coming from the back. . and it was in the tire. A loud beeping noise was coming from the brakes. I got scared so i shot down to the Nissan dealer and they looked at it and put on the lift, but they didnt know what the hell it was. They want me to bring it back. Does anyone know what the hell it is, or has had this problem? Is it my ABS? OR do i need brakes or what!
Old Oct 24, 2001 | 06:57 PM
Eric L.'s Avatar
Re: rear brake prob
Pat Boytis
Maybe someone has been doing too many handbrake spins in your car.
Old Oct 24, 2001 | 10:26 PM
Chunger's Avatar
Re: Re: rear brake prob
Originally posted by maxperformance
... loud pulsing beep noise ...
Beep?
Is frequency of 'beeps' relate to speed of car?
Old Oct 24, 2001 | 10:37 PM
WizzaMax's Avatar
That is not bad, my rear brakes only lasted 20,000 miles on my 99 GXE and I work at Pep Boys so I got the Ceramic Quiet Stop pads from Raybestos and put them on...They are quiet and do not dust a fraction of what the staockers did.
Old Oct 25, 2001 | 11:12 AM
Max96's Avatar
Rears shot? Strange.... I have to agree with everyone else.... fix that handbrake problem. My max has 114k and the rears are fine. I did the fronts at 92k, and that was only done because the rotors warped and wiped out the pads.
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
