sticky valve???
Old Dec 4, 2007 | 02:06 PM
showdown's Avatar
Because I Can
sticky valve???
i turned my car on and its making a knocking noise...someone told me they think its a sticky valve...is this true...has neone else had this problem...and how do i fix it
Old Dec 4, 2007 | 02:09 PM
f550maranello2's Avatar
timing chain tensioner??? is it only on start up???
Old Dec 4, 2007 | 04:01 PM
Any codes?
Old Dec 4, 2007 | 04:25 PM
NmexMAX's Avatar
dot dot dot ...
How's the oil level? Need better description on the noise before we can tell you :wtf to do. One key item on this forum, BE AS DESCRIPTIVE AS YOU POSSIBLY CAN.
Your post is vague, so then it deserves a vague answer.
Old Dec 4, 2007 | 05:36 PM
mowgli29's Avatar
Horizontally opposed.
how many miles on the car? does it go away after a little bit?
i put my money on worn timing components.
might want to check for exhaust leaks, especially if you have aftermarket stuff on there.
my y-pipe used to tick because the front wasn't tight enough.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
tardrex
Sep 11, 2015 07:35 PM
