Offset question +30f/+33r
Will they fit properly? Or will they stick out. I want them flush or close to it. I just don't want them hanging out.
I am on TEIN Coilovers. And rim size is going to be 18"
Ok the specs:
F18x8 +30
R18x8.5 +33
Yes 99BlackMaxMS is right
I am looking for 350z 5 Spoke 18's
225/45/18 and 245/45/18
Ok the specs:
F18x8 +30
R18x8.5 +33
19x9 30 offset here link to some pics that have side shots http://s91.photobucket.com/albums/k2...hite%20maxima/
![rolling eyes](https://maxima.org/forums/images/smilies/rolling_eyes.gif)
![Blah blah](https://maxima.org/forums/images/smilies/blahblah.gif)
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
the 2k3 touring came with staggered tires only
and actually tires play a role too... i had 2X5/50/17 and they were so flush, then i got 2X5/45/17 and they were less flush
Fronts will be flush depending on the tire if you plan on using 245s. Rears could use a 10mm spacer to offset the shorter track with the beam. If you're low you'll rub so you might need to roll your fenders.
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
