Frequent Wheel Alignments?
Old Dec 7, 2007 | 01:11 PM
GStrength's Avatar
I was going to drop my car with S. Teins however I was told by a mechanic that when people tend to drop there cars, they frequently need a wheel alignment. How true is this statement. Also I plan to drop the front 2.5 inches and the back 2.0 inches. I'm not looking for a debate to pop up on which struts or springs are better I just wanted to know the facts about dropping and if you will need frequent wheel alignments and how to avoid that if so, thanks.
Old Dec 7, 2007 | 01:17 PM
NmexMAX's Avatar
dot dot dot ...
My car hardly needs an alignment, and if it does, it's because I hit a large pothole or something of that nature, kinda like it was before it was dropped.
Old Dec 7, 2007 | 02:19 PM
Hammy
I believe its true.
You are going to be changing the geometry in your car, ie. your axles.
I also just bought some S teins to get rid of my 4x4 status, and as soon as Im done Im off to get an alignment.
Old Dec 7, 2007 | 02:46 PM
Fr33way™'s Avatar
Wild for Width
What springs drop 2.5? Also, that statement is false.
Old Dec 7, 2007 | 03:24 PM
dgeesaman's Avatar
Maintenance Monster
They should not need frequent wheel alignments, however they will need one after the drop. Drop directly affects toe setting and camber.
Perhaps he meant "drop frequently requires a realignment"
Old Dec 7, 2007 | 04:07 PM
NmexMAX's Avatar
dot dot dot ...
I like that, it has a certain ring to it.
Old Dec 7, 2007 | 04:11 PM
97SMG's Avatar
Hmmmm 2.5/2.0 drop hey! Are these special one of a kind "S Tein" as you stated or are you referring to Coilovers? Info a bit vague
Old Dec 7, 2007 | 04:24 PM
99grnmaxgxe's Avatar
If you are using coilovers and adjust the height frequently than you need frequent alignments. Go to another shop that doesn't give you BS info.
Old Dec 7, 2007 | 05:25 PM
khantalha+'s Avatar
i had mine dropped 2.0'' all around, only had to get it once when i dropped it ... and its been runing fine for the 8th month now...still good..
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dcam0326
Sep 8, 2015 11:02 PM
