Starting Problem
Old Dec 7, 2007 | 06:51 PM
rome06's Avatar
Starting Problem
Hey guys my friend has a 99' and it wont start. All it does is crank crank crank and nothing else. I ran the ecu and i had 2 codes pop up. Both codes were P0335 which is the crankshaft position sensor. I replaced BOTH the front and the side sensor and still all it does is crank but wont fire up. No other codes pop up so what else can it be? Thanks
Old Dec 7, 2007 | 11:41 PM
pmohr's Avatar
No more Maximas...
Do you have spark? fuel? How's the timing? Compression?
Has it ever started before? Any recent work done to it that might cause this?
Need some more info...
Old Dec 7, 2007 | 11:49 PM
rome06's Avatar
the car was running fine. The maf went out and i didnt have another maxima maf handy however i did have a z32 maf laying around so i put that in and the car has recently had a rough time starting. Well i jumped it and it started and then after about 10 minutes of driving i turned it off, and it never started again. I ran the ecu and i pulled up 2 codes for 0335 which was for crank position sensor, i replaced the one on the tranny bell housing, and it still didnt start, i checked for codes again and i was still getting the same codes. So i replaced the second crank position sensor and still nothing. Can it be the harness? Starter?
Old Dec 7, 2007 | 11:52 PM
pmohr's Avatar
No more Maximas...
I'll ask again. Fuel? Spark? Timing? Compression?
Old Dec 8, 2007 | 06:02 AM
rome06's Avatar
yes everything is fine just changed spark plugs, it does have gas, the timing and compression is fine. it was running one day and the next it wouldn't start. I ran the codes and got one for p0335 crankshaft position sensor circuit malfunction. Changed both front and side crank sensors and still nothing. Any ideas? Could it be the starter? it still cranks but will not turn over.
Old Dec 8, 2007 | 06:20 AM
Nopike's Avatar
If the starter is cranking it should be fine. But, I understand it is easy to remove, you can remove it and get it tested. Also make sure starter connection to frame ground is good I understand many people have problems with this.
Old Dec 8, 2007 | 06:28 AM
pmohr's Avatar
No more Maximas...
You say you changed spark plugs, but did you check for fire? Check fuel pressure?
Old Dec 8, 2007 | 06:30 AM
pilotguy18's Avatar
Have you checked starter solenoid? My friend had same prob on a diff car but it might be similar. Also check to make sure the starter is properly grounded.
Old Dec 8, 2007 | 09:14 AM
rome06's Avatar
havent checked that, where is the solenoid located?
Old Dec 8, 2007 | 09:16 AM
pmohr's Avatar
No more Maximas...
It's on the starter.
Though if the starter is turning the motor over (i.e. the gear is kicking out) then the solenoid shouldn't be the issue.
Old Dec 8, 2007 | 09:19 AM
rome06's Avatar
it has fuel pressure, i didn't check for spark , the car was running perfectly fine i dont see how one time it just doesnt start out of no where
Old Dec 8, 2007 | 09:20 AM
rome06's Avatar
well the starter does not turn the motor over unless the car is sitting on cables
Old Dec 8, 2007 | 09:24 AM
pmohr's Avatar
No more Maximas...
What's the fuel pressure at right now?
You say it doesn't run, and it ran before. Obviously, something is causing it not to run now. It's either spark, timing, compression, or fuel.
Fuel: You say it has fuel and that you checked the pressure, how exactly did you check?
Timing/Compression: You say these are fine, but have you checked them?
Spark: You haven't checked this, yet it's one of the FOUR things that will cause a no-start condition. You probably don't have spark, but we won't really know until you check...
Well that's new information. You mean on jumper cables? Battery could just be low/bad.
Basically, we need all of the above information to do any sort of diagnosis. If you're not up to or capable of doing the above, then you'll have to see a mechanic, there's only so much we can diagnose over the net.
Old Dec 8, 2007 | 11:12 AM
antti's Avatar
Hi,I also have problems with starting the car. I swapped a repaired engine,and manual transmission. How can I check timing and valve timing,as my guess is that something might be done wrong,as the car starts,revs up to 300rpm and then dies,and it sounds like its choking. No codes from ecu,but the CEL light is blinking.
Old Dec 8, 2007 | 01:00 PM
rome06's Avatar
Would a z32 maf have anything to do with the car not starting? My maf went out and i didnt have another maxima one handy but i did have a z32 maf laying around so i put that in. Im not boosted or anything but shouldnt it still start with a z32 maf?
Old Dec 8, 2007 | 01:04 PM
rome06's Avatar
well even if the battery was bad, wouldnt the car still start if i had it hooked up on cables to another car?
Old Dec 8, 2007 | 03:17 PM
rome06's Avatar
anyone?
Old Dec 8, 2007 | 03:57 PM
EnervinE's Avatar
i has college
It will start even without a MAF attached, so try removing the Z32 MAF altogether.
Old Dec 8, 2007 | 04:08 PM
rome06's Avatar
pulled the plugs and they wet soaked with fuel so it has fuel, it does NOT have spark however, how would you go about checking for timing? But i think spark is my problem, so does anyone have a clue as to what it can be? Thanks
Old Dec 8, 2007 | 04:43 PM
rome06's Avatar
is there any ways to test the crank sensor with a multi meter? If so how many ohms should it be reading?
Old Dec 9, 2007 | 06:17 PM
rome06's Avatar
anyone?
Old Dec 9, 2007 | 06:45 PM
Nopike's Avatar
COMPONENT INSPECTION
Crankshaft position sensor (POS)
1. Disconnect crankshaft position sensor (POS) harness connector.
2. Loosen the fixing bolt of the sensor.
3. Remove the sensor.
4. Visually check the sensor for chipping.
5. Reconnect crankshaft position sensor (POS) harness connector.
6. Turn ignition switch “ON”.
7. Check voltage between terminals 2 and 3 when bringing a
screwdriver into contact with, and quickly pulling away from the
sensor core.
Terminal Condition Voltage
Contacted Approximately 5V
Pulled away Approximately 0V
There should be a steady 5V as the screwdriver is drawn away
slowly.
If NG, replace crankshaft position sensor (POS).
TROUBLE DIAGNOSIS FOR DTC P0335
Old Dec 9, 2007 | 06:48 PM
Nopike's Avatar
Terminal pins 2 & 3 are on the left hand side if you are looking at the connector with the clip at the top.
Old Dec 9, 2007 | 07:25 PM
rome06's Avatar
terminals 2 and 3? If i reconnect the sensor to the harness, which terminals should i be testing?
Old Dec 9, 2007 | 07:55 PM
Nopike's Avatar
You need to get at the wires with the connector connected. Sorry FSM does not go into more detail. Maybe connector has pin numbers on it?
Old Dec 9, 2007 | 08:06 PM
rome06's Avatar
hmmm illl look at it and try something i guesse, thanks tho !
Old Dec 9, 2007 | 09:02 PM
pmohr's Avatar
No more Maximas...
...have you checked for spark, fuel pressure, etc. etc. yet?
Old Dec 9, 2007 | 09:34 PM
adriena's Avatar
hey i'm the friend with the 99 maxima and yes we have checked it all and the car does NOT have a spark. we replaces both crank sensors checked all the harness the engine grounds the ignition switch starter batery fuel pump and fuses coil packs spark plugs everything we could think of that had to do with the code p0335 crankshaft position sensor and some ignition. the only thing we came up with is that the car has NO FIRE. if anyone can give us any more suggestions it would greatly be appriciated. but if not i think i'm going to take it in to nissan because we have seriously tried every troubleshoot in the book!
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
