Help with radiator question.
Old Dec 10, 2007 | 10:10 AM
laflyer23's Avatar
I was wondering if the radiator is the same whether it's an automatic or manual?? Reason i'm asking is because i was going to buy a radiator off ebay and some are saying for auto's. So are they misinformed or do i need to venture somewhere else? Thanks.
Old Dec 10, 2007 | 10:19 AM
Curt Deiner's Avatar
I would think the auto radiator has ports for trans cooling lines?
Old Dec 10, 2007 | 10:37 AM
laflyer23's Avatar
ic, that does make sense.
Old Dec 10, 2007 | 10:46 AM
pmohr's Avatar
No more Maximas...
That's the only difference, trans cooler ports on the radiator. Actually, not sure if they used different radiators between AT and MT models, but I can't access FAST right now.
Old Dec 10, 2007 | 02:47 PM
KRRZ350's Avatar
They do. But the only time you would run into a problem is if you wanted to use a 5-sopeed rad on an auto. Auto rad on a 5-speed is fine.
Old Dec 15, 2007 | 05:33 PM
laflyer23's Avatar
I bought a radiator off ebay and i installed it today. With a new thermostat from autozone. For some reason the new radiator is getting super hot and smoking from the inside and my car temp guage is going up . Wondering wat could be the problems. If the new radiator is bad or is there a clog somewhere. Thanks
Old Dec 16, 2007 | 08:47 AM
njmaxseltd's Avatar
If the radiator is getting hot, then your cooling system is flowing.
Do the fans come on when the temp gauge starts to climb up?
If not, you probably have cooling fan issues.
Motors, relays, sensors.
Old Dec 16, 2007 | 06:48 PM
laflyer23's Avatar
i will try to see if they come on when it starts to smoke. Also if i run the air conditioning or heater both the fans spin then and still over heats and radiator smokes. But i will look to see if they do turn on when it gets hot.
Old Dec 16, 2007 | 06:59 PM
maxx0831's Avatar
did u check your water pump?
Old Dec 17, 2007 | 09:09 AM
laflyer23's Avatar
Haven't checked the water pump. Will check it but i first gotta see how to check it and how to remove from car.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
pears
Sep 18, 2015 05:25 AM
