Radiator Replacement
Old Dec 10, 2007 | 05:27 PM
ddurandd's Avatar
I just ordered a radiator replacement from Radiator Barn yesterday and am getting ready to do the job. Any last minute tips from those of you who have done it? It looks like a couple of bolts on the upper bracket and some clamps on the upper and lower coolant hoses - I'm just not sure about the transmission hoses. How are these attached? I welcome any advice...
Old Dec 12, 2007 | 02:05 PM
ddurandd's Avatar
Radiator installed!
I ordered the radiator Sunday morning and it was at my front door when I came home Tuesday.
I drained and saved the old fluid (it was still fresh from a recent water pump replacement). All bolts and clamps were 10mm and there were two phillips head screws for the stock air intake that had to be moved. There were a total of 4 hose clamps, 2 radiator mount brackets, 2 electrical connections for the fans, the over flow tube, and some plastic guards underneath the car that had to be removed. Once I had the radiator out, I moved the fan assembly over to the new radiator (2 - 10mm screws) and dropped the radiator back into place. There are 2 rubber doughnut type mounts that the radiator fits into on the bottom. It ended up taking me longer than it should have because of a clamp that got messed up, but I did the job in 2.5 hours.
I tested everything out today and have no leaks. I definitely would recommend letting everything cool down before starting. I got a burn on my arm from something that was really hot.
I got 208,000 miles out of the first radiator - I hope this one lasts as long!
Old Dec 12, 2007 | 02:10 PM
MadMaxSE-L's Avatar
Doggah Bite...
I just did mine last weekend, along with my alternator. I tried doing mine with the car half-way warm too - big mistake. The exhaust manifold stays hot for A WHILE!...
I only got about 170k miles out of mine, it has had a very slow seep for about 2 months now, and my alt has been making noise for over 4months.
I just went ahead and replaced radiator/alternator/thermostat/both radiator hoses/clamps. Car runs great now...
Old Dec 12, 2007 | 05:44 PM
19Maximus98's Avatar
Although this may have been done already, a write-up would be nice especially one with pics!
Old Feb 3, 2008 | 09:27 AM
clownshue's Avatar
did you replace any of the hoses or take any pics?
the Maxis radiator is going south after 261000 miles and I am contemplating tackling it myself. I have a 93 300zx 2+2 radiator from a previous project and was wondering if that would fit into the Max.
The specs are very similar
300zx
Core Size: 15-3/4 X 27-1/8 X 11/16 Inlet Header: 27-3/16 X 1-3/16 Outlet Header: 27-3/16 X 1-9/16 Inlet Connection: TOP 1-3/8 RIGHT Outlet Connection: BOTTOM 1-3/8 LEFT Transmission Oil Cooler: YES Engine Oil Cooler: NONE Mounting: Notes: ONE ROW, ALL METAL
Maxi
Core Size: 15-3/4 X 27-5/16 X 1-5/16 Inlet Header: 27-3/16 X 1-9/16 Outlet Header: 27-3/16 X 1-9/16 Inlet Connection: TOP 1-3/8 DRIVERS SIDE Outlet Connection: BOTTOM 1-3/8 PASSENGERS SIDE Transmission Oil Cooler: YES Engine Oil Cooler: NONE Mounting: Notes: TWO ROW, ALL METALanyone have any suggestions?
Old Feb 3, 2008 | 10:34 AM
oldngivout's Avatar
Willing to learn
Yes it will. but it is common knowledge on the 300ZX forums that the Max radiator is a litle larger capacity, but the same dimensions. So the NA 300ZX guys use the Max radiator as an upgrade. Now you can make an informed decision.
Old Feb 3, 2008 | 11:11 AM
WhiteMaxima9600's Avatar
Any of you had the koyo rads. from the GD forum? I bought one from there about a year ago from importrp. It fits perfect and was an excellent deal!!
Old Feb 3, 2008 | 11:42 AM
clownshue's Avatar
The radiator that the NA 300 guys use is from the 3rd gen Maxi... I did not know if there were major changes from platform to platform.
Old Feb 3, 2008 | 01:45 PM
nick's Avatar
I just installed KOYO radiator for the GD, it fit right up with no issues. I've managed to get 157k out of the stock OEM radiator. I wonder what brand of radiator the Radiatorbarn sells.
I bought one from them while back for my brothers 97 Olds Aurora, and it was a quality product. I wanted to go with them again, but somehow the GD convinced me to go with KOYO. (which is made in Indonesia BTW)
Old Feb 3, 2008 | 01:48 PM
nissanguy8's Avatar
don't forget to keep burping the system and keep checking the fluid level once everything is done, squeeze the hoses too. it takes a little bit to fully get all the fluid back into the system.
Old Aug 28, 2008 | 09:06 PM
Chalzor's Avatar
Koyo 300zx radiator
I have a Koyo radiator in my 300zx, which is basically a parts car now. When i was installing it in the Z it looked like it had a place to tap a hole for the smaller rad hose that I believe goes to the automatic tranny, my question is what would I need to get to properly tap this hole and attach the hose in place?
This is for a 93 Max GXE, VG30E
Chalzor
Old Aug 28, 2008 | 09:48 PM
pmohr's Avatar
No more Maximas...
Chalzor
http://forums.maxima.org/3rd-generat...a-1989-1994-8/
And why not get the correct radiator for the car? Just because the header has the spots for a trans cooler connection, there may or may not actually be a trans cooler in the radiator core.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
