Installed intake, now Check engine light
the check engine light is on after i installed my K&N High flow intake, i already did a search and couldn't find anything, any ideas? i'm getting a tune up soon should i just wait and let em handle it?
Re: Installed intake, now Check engine light
Read this thread
http://forums.maxima.org/showthread.php?threadid=45274 Did you reconnect everything you may have disconnected? The above thread will tell you how to get the trouble code, and may also offer how to fix. Good luck.
Re: Re: Re: Installed intake, now Check engine light
Originally posted by RedMax95
yep, take a look, hope u didnt mess with your MAF
Re: Re: Re: Re: Installed intake, now Check engine light
Originally posted by AltezzaMikeGTR
well i don't know whata"MAF" is but there is one "plug" thatwas on the stockair box thatisjust there, and not pluged into anything? Is this why the light is on?
*my experience*
Yea, that happens sometimes when you start up the engine without completing the job
It happened to me...I followed ALL the instructions on how to reset the check engine light and it STILL STAYED ON
One day tho, it just went off! I thought it had blown but from that point on, it worked like normal. soooooo my advice is to do the reseting of the ecu, and just ignore it until it either goes off or get your check up (then blame it on them) lol! nah, don't blame them, that's a hon-duh move!!
If your car still runs I would assume you have a 95 and it is the ambient air temperature sensor that is disconnected. You'll need to remove the old sensor from the old stock air box and reconnect it then reset your ecu. Get a Haynes manual too. Hope this helps. Again, post your year, or pics if you have em.
REDmax, sweet sig picture.. okay this thread, before not to damage the maf meter.. This can be damaged by the K&N oil filter if you oiled it. the oil has to dry. i would let it sit over nite if possible to make sure its dry. if not, MAF is sensitive, reset the ECU so the light will go off.
there is one plug that will not plug into anything. i can't remember what that piece is called, but I just zip tied mine to something away from the engine block. check all your hoses and make sure everything is tight and nothing is leaking. it really does sound like your Mass Air Flor sensor though. I think if you have a leak somewhere...your check engine light will come on. if your car can't idle...they a hose came off...
well i can idle, i think it is on b/c of that plug that isn't pluged into anything, it sounds ok and is runing fine
Re: *my experience*
MAXSE5SPD
Aug 23, 2015 12:06 PM
bassmann
Aug 3, 2015 07:53 PM
