15~16 miles/gal.(premium)
Old Dec 13, 2007 | 10:22 PM
hermtm2's Avatar
Hi.
I don't have any CEL and all of the O2 sensors and knock sensor were replaced 3 month ago. After all the sensors replaced, it made 20~21 miles/per for about 1 month. But now the gas mileage is 15~16 mile/gal. The car, which is 96' 132k on it, is always feeded on Shell premium only. What could be wrong with the horrible gas mileage?
O2 sensors?
Knock sensor?
Any other problem?
What can I do?
Thanks.
Old Dec 13, 2007 | 10:32 PM
roggeezy's Avatar
yah my car gets around the same gas mileage. On average how many miles per tank? I can never break 300. Also i mainly drive to and from school which isnt alot of highway and alot of stop and go. So driving conditions can affect gas mileage too.
Old Dec 13, 2007 | 10:38 PM
MaximaPimpin's Avatar
I used to get 300 to the tank also, but now i get around 430 to the tank using premium and driving it hard. I do mostly highway miles so i get around 28 mpg, but in city i get around 21mpg. Try using some Lucas Fuel Injector Cleaner, it works wonders . You can also clean out your TB, it will make the throttle response much better and smoother.
Old Dec 13, 2007 | 10:46 PM
KillaJakez's Avatar
Ha! I should be so lucky. I can't break 230 on a tank, v-power shell. Or any 89 or 93 octane gas. My car is still being worked on .... new iridium spark plugs, clean idle speed control valve and throttlebody, new fuel filter, new goodyear eagle f1 all seasons for the front, rear motor mount, new oem lower radiator support, and new undershields.
Once I get the car back from the shop, we will see how much I get per tank. My mechanic said that mileage goes down with the winter blended gas as well, I wonder how true that is.
Old Dec 13, 2007 | 10:57 PM
psu2fan's Avatar
Wow. It sounds like you guys/gals are mostly up on maintenance.. that kind of mileage seems quite low. Granted I don't drive overly hard and most my driving is mixed city/hwy but most people in your situation get AT LEAST 18mpg. Something must be wrong imo. Have you checked for gas/air leaks? The reason I mention that is last winter I added a fstb to my car but it was designed for 3rd gens and actually broke a small hose, dropping my gas mileage a good 2-3mpgs.
Old Dec 13, 2007 | 11:11 PM
DizzyEdge's Avatar
What does that mean?
Yeah that's pretty ridiculous, the past two tanks I've gotten about 350 miles per tank, and that's with a o2 sensor code, knock sensor code, 2 heavy tool boxes in the trunk, and it turns out my rear tires were underinflated at only 20 psi. All city driving, although almost always in the evenings when traffic is light... any chance brakes are dragging slightly? done a compression test lately?
Old Dec 14, 2007 | 12:36 AM
KRRZ350's Avatar
Let's start by checking 4 things:
Check all fluid levels & conditions
Scan for ghost codes
Jack up each wheel and make sure they spin freely.
Check long-term fuel trims for B1 & B2 (obdII scanner required)
Old Dec 14, 2007 | 01:42 AM
wiggafly808's Avatar
Dont forget tire air pressure..
I filled mine up and my mpg went up from 14 to 17
It was like 20something psi to around 40.
Old Dec 14, 2007 | 03:34 AM
max ride 41's Avatar
wow, 40 psi is really high unless you have bigger tires than stock, i have nitogen and stock tire size and its 33 psi. and the guy that said hes getting 430 miles per tank is foc, unless hes drivin like the exact speed limit all the time. 300 to 350 miles per tank is normal for our cars, fluids in my car are all fresh and topped off and i never get any better than that. thats a 4th gen for ya.
Old Dec 14, 2007 | 03:35 AM
99BlackMaxMS's Avatar
I got 16.777 mpg last time I filled up (297mi/17.5gal) and it has been a constant decline since cold weather has started. I never got great gas mileage to begin with (always averaged about 18-19 city and 24-26 highway) but I think short 2 mile trips to school, warming up the car 5 mins early in the AM, and having some fun in the snow don't help my MPG very much.....
Old Dec 14, 2007 | 05:12 AM
ROCKART's Avatar
wants an I35
Originally Posted by hermtm2
Hi.
O2 sensors?
Knock sensor?
Any other problem?
What can I do?
Thanks.
i noticed you didnt have FUEL FILTER or AIR FILTER on your list. make sure to check/replace those. should cost no more than 20 dollars and an hour or two.
you should also be checking your intake for leaks/dirt in the IACV and TB.
im gettin 350+ driving hard - in a city environment (lights every mile)
i rarely use the highways. maintenance items ive done:
new KS
new platinum plugs
tire pressure is 31-33
new OEM air filter
only using 93
on checking for ghost codes (ks.....) and checking if wheels are spinning with minimal friction
Old Dec 14, 2007 | 07:48 AM
maximized98's Avatar
Addicted to the Org
Not another mpg thread
Old Dec 14, 2007 | 08:48 AM
kvg's Avatar
kvg
In the winter colder air will drop your mileage, take it on the hiway blow out some carbon. I get close to 30 miles per. a y-pipe made a huge diff in mileage for me.
Old Dec 14, 2007 | 08:53 AM
xlr8r's Avatar
Ghost codes I got better mpg AND more bhp when I replaced my knock sensor
ALso, I got a big boost in mpg when I cleaned my MAF. A well spent $8 for the can of cleaner spray.
Old Dec 14, 2007 | 09:02 AM
alcatranz518's Avatar
Over the years here on the .org, I have noticed this when this style thread comes up. Other veterans here help me see if I am correct. I know this is how most other cars work, but usually an AUTOMATIC trans car with get ~ 10mpg less than a Standard shift. I noticed on this list of posters also. The people getting upper 20's not only drive freeway, but have a standard.
My Auto will not get over 22mpg on the highway, thats doing exactly 65 (cruise control) to Niagara falls and back (which is one full tank trip and only two stops including one to the rest stop). Just background, I have all new wheel bearings, knock/O2 sensors, etc., running premium all the time and not to mention a maintenance schedule that is religious (granted it has 180,000miles on it).
My Civic-the beater- is another good example. I get 38mpg (using cruise control also set at 65 on standard 87 oct gas) with it, but is a 5spd (and it has 200,000 miles on it HAHA - show me a Cavalier that can do that). The auto Civics only get around 28-30mpg highway. I drove it to Niagara Falls also which was a 3/4 tank trip.
FYI: Niagara Falls is exactly 414 miles round trip for me with NO stops unless I need a drink or go pp (lol).
My Point: The Autos avg ~18-22mpg, the Standards avg ~25-30 mpg. The 5/6 speeds can be better depending flywheel weight and shifting/ driving habits. Our Autos suck so bad b/c of gearing, but mainly the torque converter weight...so how much to do a swap? I think thats gonna be my next mod. I've contemplated doing before, the mpg is my selling point.
Old Dec 14, 2007 | 09:20 AM
MaxGordon7's Avatar
AUTO gets 20-22 city and 24.5 with even 50% highway which is perfect (8 gallons x 21 mpg city = 168 and 8x28mpg highway = 224 total of 394 miles over 16 gallons =24.5mpg for full tank) never driven a full tank on highway. I also live in the regulated gas area of Wisconsin so if i used normal gas i would tack on 1~2 more mpg. In the winter it gets bad around here, i don't use overdrive to heat car faster and i hear there is a winter blend gas here. You should get 20 mpg city, other wise something needs to be replaced. Infiniti parts car i got, last owner reported 26 mpg with highway driving. Something you over looked, you put in the right time, in the right place she will put out!!!!!!!!!!!!!!
Old Dec 14, 2007 | 09:24 AM
MaxGordon7's Avatar
My Civic-the beater- is another good example. I get 38mpg (using cruise control also set at 65) with it, but is a 5spd (and it has 200,000 miles on it HAHA - show me a Cavalier that can do that). The auto Civics only get around 28-30mpg highway. I drove it to Niagara Falls also which was a 3/4 tank trip.
auto get fine mpg
Old Dec 14, 2007 | 10:09 AM
TunerMaxima3000's Avatar
Air filter
Fuel filter
Clean TB, IACV
Check for ghost codes
Service/inspect brakes
biggest one as stated is check that the brake calipers are not sticking, this is very common.
Old Dec 14, 2007 | 10:17 AM
x8ver2007's Avatar
I agree with the person saying auto and 5 speed. My maintence is so-so I have a 5 speed 97 GXE with Sunoco 93 I get 430 miles per tank still with not lighting the yellow gas light. Yes I drive mostly Highway with no traffic proper shifting on the avg 3500 revs sometimes even 4000 but not going over 95 but a constant 75-85 so I did not know the automatics are so bad. I do have proper tire pressure, high speed balanced, and alignment. Michelin tires and the tight suspension has helped out alot on the braking so I feel I getting better mileage. The maxima is giving way better mileage in gas than other smaller engines because they can not handle the highway speeds.
Old Dec 14, 2007 | 11:27 AM
Yeah i forgot to mention that i drive a 5 spd. Thats another plus for a manual . More fun to drive, more mpg, and more control.
Old Dec 14, 2007 | 01:23 PM
NmexMAX's Avatar
dot dot dot ...
Actually, the EPA gave the 4th gen (A32) 4AT (auto) better MPG #’s This is due to both the final drive and ‘short’ 5th gear.
Old Dec 14, 2007 | 03:41 PM
DizzyEdge's Avatar
Nice sounds like I have something to look forward to
Old Dec 14, 2007 | 05:43 PM
i never drove a stick, and i disagree with more rpms but agree with gas mileage. i must be lazy, cause i want to multitask when i'm driving not friggin play with a clutch and have no free hands to play with all my toys. its all preference, i like auto.
Old Dec 14, 2007 | 05:46 PM
ROCKART's Avatar
wants an I35
yea im lazy too
Old Dec 14, 2007 | 05:53 PM
^^^^^ yay for lazy people!!!
Old Dec 14, 2007 | 07:46 PM
psu2fan's Avatar
Well I think I'm gonna have to disagree with you there. I live in the Rochester, NY area and have a friend in Columbus. Granted I do have a 5spd. but my mileage when visiting her is roughly 27mpg to Columbus and 32mpg on the way back. As I'm sure you know the wind is pretty stiff on I-90 (I assume you travel that route) and is the reason mileage differs so much each way. I cruise at 74-76 all the time. I have to assume and would bet there's something wrong that's limiting your mileage. In mine and my father's exp (he's owned 2 max's) the manuals get a lil better mileage in city/mixed normal driving while at hwy the mileage is essentially the same.. that's in our family. I just can't believe your auto can't get over 22mpg and at 65mph, it just doesn't make sense. Maybe I'm wrong but that's my experience. Even if you have mods that slightly lower mpg it shouldn't make that much of a difference. I don't know, if you were driving 90 each way then it'd make more sense to me.
Old Dec 14, 2007 | 09:15 PM
Thats what drove me to replace everything and clean as thoroughly as possible, replacing sensors bearings etc. I do not drive erratic, yet my max will NOT get better gas mileage than 22mpg. Unless maybe I did overlook something. Then as time progressed, I always would notice many other Auto owners saying theirs got roughly the same. Whereas most manual owners never seemed to claim under 25 and up to 30, if not more. I wasn't claiming it to be a huge finding, just something I'd noticed and pay'd attention to reading over the past 3 years.
Old Dec 14, 2007 | 09:17 PM
I don't get why people believe that just because you drive a stick you can't multitask. I can switch gears while talking on the phone and playing with my ipod. Once you get used to the feel of your cars shift points it becomes automatic for you, i don't even think while switching gears, i just do it because i can hear when its time by the engine and i know at what mph i should switch it at.
Old Dec 14, 2007 | 09:21 PM
psu2fan's Avatar
yeah, i never really pay attention when someone says they get bad mileage in city/mixed driving because there are so many factors going into it, but on the hwy with cruise on is where it seems way out of whack, unless people are driving up mountains
Old Dec 14, 2007 | 11:58 PM
hermtm2's Avatar
Mine is Auto tranny. The air filter, fuel filter, and spark plugs were replaced a month ago. And I don't have any CEL. When the O2 sensors and knock sensor were just replaced three month ago, the car made up to 330mile by 16 gal.(premium). By the way it was only 3 times happen. After the 3 times made the normal mileage, it get back to the 250 miles again so far. I don't know why??? It wasn't changed anything. The car is driving the same distance and time because I'm a full-time student. I just doubt the front two of O2 sensors are UNIVERSIAL so they could be something wrong even though they don't show the CEL to me.
Thanks.
Old Dec 15, 2007 | 06:35 AM
Bobo's Avatar
I consistently get over 500 miles to a tank on straight highway driving. I have exceeded 550 miles, about 3 or 4 times. The vehicle is a 5-speed.
Canadian gasoline is better than US gasoline.
Automatics are supposed to get slightly better fuel economy on the highway and slightly lower fuel economy in the city.
I over inflate my tires to about 36 front, 35 rear.
Tire pressure should be checked more frequently in colder weather as radial tires can lose about 2 pounds per month.
Old Dec 15, 2007 | 01:59 PM
njmaxseltd's Avatar
Not true. Some auto's are geared much lower allowing them to cruise with lower engine RPM's then their equivalent 5 or 6 speed sporty manuals. Todays new auto trannys are also very efficient at transfering power. The computers that control them actually monitor your driving habits and tune the tranny to your driving style.
Example, the BMW 3 series and yes, I own one.
My auto consistantly gets upwards of 28 or 29mpg cruising at just about 80 mph. Thats just over 400 miles per tank. I drive mostly highway, 75 miles round trip every day.
Perhaps you should increase your crusing speed.
Old Dec 16, 2007 | 09:34 AM
Haha, don't I wish...When I cruise at 80 (which is rarely) I can almost watch my gas gauge fall.
Car is garage kept over winter, so no drivy-drivy in cold weather/snow. I have no ghost codes, TB/mani cleaned every spring, all new calipers and wheel bearings, new knock sensor, new copper plugs every 30,000 miles, FF changed every 3500 miles, air filter cleaned at same. Premium gas always. Car runs/idles perfect except for mileage.
So what could it be? I ran out of options.
Old Dec 16, 2007 | 10:37 AM
Bobo's Avatar
I'm not sure what the problem is. What tire pressure do you use?
There is absolutely no need to replace the fuel filter every 3500 miles. I replace mine every 30k as called for.
Cleaning the throttle body and manifold every spring is more than a tad ****!
Old Dec 16, 2007 | 12:18 PM
I use 35psi...and oops, I missed a "0" on the FF/AF mileage. I change/clean them about 30-35,000. I'm not that ****, but I am a bit obsessive, I'll admit.
Old Dec 16, 2007 | 12:44 PM
Delvin's Avatar
Yup thats what I was going to add to this. In most cases cars with manuals get better mpg than their automatic siblings do. I bought a 99 5sp that I gave to my brother (this was before I got my 98 auto) and when I went from driving my 98 to his 99 I noticed that the 99 had a significant difference in cruising RPMs at lets say in the 70-75mph range. The only way I get 400+ mpg in my 98 is when on a road trip. I once got about 530 miles when I was trailering a big rig who was cruising at about 85 for 3 hours.
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
MannyMonroe
Sep 24, 2015 08:45 AM
