Shift Knob Removal...
Old Oct 25, 2001 | 11:23 AM
vmok's Avatar
Shift **** Removal...
Any tips on how to get it off without tearing up the threads on the leather? Both my buddy and I have both tried to untwist the stock **** off and it just won't budge. We even tried putting a towel over it and using big pliers, but it seems that when you get that much leverage, the pliers, even with the towel in place, just wants to rip the threads off the ****. It won't budge. Any help on how you got it off or how it can be broken off would be great. Thanks.
-V
btw, the car is a 1997 5sp and the shifer **** has never been off.
Old Oct 25, 2001 | 11:27 AM
Sprint's Avatar
turn that baby real hard to the left..
if not.. hit the weight room
the dealer took mine off to do my STS.. so they left it kinda loose so i can pull mine off.. but you just need to turn it.. it will come off
Old Oct 25, 2001 | 11:41 AM
vmok's Avatar
I guess I better do the latter and hit the weight room.
I can get the **** on and off my Miata fine. But the Max is like FROZEN on there. It doesn't budge. Even with two guys trying to turn it with large pliers with a towel over it. There no other locking screws or anything right? Does the car come from the factory with LocTite or anything like similar that I'm working against and don't know about? Thanks for the reply though... now I know what to do
-V
Old Oct 25, 2001 | 01:11 PM
SuDZ's Avatar
-V
I was actually suprised because mine came off without to much work. Basicly while I was driving I wondered how it came off and with a good grip popped it right off. If you really cant do it grab a wrench with a big enough head on it to fit around there and take it off using the leverage.
SuDZ
Old Oct 25, 2001 | 01:22 PM
Tai Mai Shu's Avatar
try standing on both seats while straddling the shifter, then grab it with both hands and pull up hard, but remember to keep ypur sunroof open.
Old Oct 25, 2001 | 01:26 PM
SuDZ's Avatar
And make sure nobody is watching if you do it that way. Unless you like the stares.
SuDZ
Old Oct 25, 2001 | 01:46 PM
MDr's Avatar
MDr
Re: Shift **** Removal...
SEARS strap wrench is the tool for the occasion.
Old Oct 25, 2001 | 01:49 PM
madmax26
same exact problem
mine didnt screw off either, what i did was use those lil dremel circular saw things and had to cut it right across the middle then rip each side off, it has threads, but then i looked and the stock was double sided taped to the threads which made no sense, it was a hassle and it makes a big mess, so i got a nice momo **** that pops on and u just screw in allen wrench screws, its cool, but i cut the lever under the threads a couple days ago, so i suggest gettin a **** that doesnt screw on, the momo does just fine
Old Oct 25, 2001 | 03:35 PM
Anachronism's Avatar
Is there anything that can be damaged when your put a lot of force on the shift **** trying to get it off?
Old Oct 25, 2001 | 04:46 PM
Mishmosh's Avatar
I'm assuming you mean down below. Nah, the shifter rod and linkage hardware is pretty strong and can easily resist rotational forces around the shifter rod.
The **** appears to be held in by both the threads AND some glue. I used a vise plier thingy with some cloth wrapped around the lower part of the ****. I definitely couldn't muscle it loose by my bare hands.
Old Oct 25, 2001 | 08:15 PM
JUDE's Avatar
I had the same problem getting mine off. The problem is that there is glue holding it in place and I don't care how strong you are, you won't get it off. Both my cousin and I tried together and we couldn't get it off. Get a strap wrench, you can use a towel if you want, but the leather still got messed up with the towel. Once you get the strap wrench in place twist it and you'll hear a pop (the glue breaking) and then it will unscrew after that. Don't worry, none of the internals get messed up in the process.
Old Oct 26, 2001 | 12:12 AM
vmok's Avatar
When you say strap wrench, are you referring to the oil filter strap wrenches? That's a very interesting idea... I think I"ll try it...
-V
Old Oct 26, 2001 | 01:13 AM
norton2099's Avatar
well what i did was i used a hand towel and a vice grip (that sucker was on there pretty good) and just twisted it until i got it going then it was all good after that.
Old Oct 26, 2001 | 01:24 AM
vmok's Avatar
I tried by hand, my friend tried by hand, then we put on a towel with channel lock pliers around it. It looked like it was actually pulling the leather skin off the leather as well as almost causing the threads to split at the seems. The **** didn't budge. I'll try the strap thing tomorrow as it's late and I"m tired now . I think you're right though, as soon as it starts, it will be easy going.
Can't believe this is the show stopper for a short shift kit install!
-V
Old Oct 26, 2001 | 01:45 AM
norton2099's Avatar
-V
Haha gooshi gooshi.
Old Oct 26, 2001 | 04:46 AM
nismo2020's Avatar
Needs non-Maxima Friends
i have a gxe with the non leather shift ****. i had to take a razor and shave the **** down to the threads then wrench it with pilers. ranks up there as one of the hardest things i ever done to my max.
Old Oct 26, 2001 | 05:33 AM
smithdl4
Yu guys might try heating the glue with a hair dryer/heat gun. May take awhile but sure beats the gorilla tactics you are using now. Kinda aim the dryer from the floor up to get the heat to the glue inside the ****.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
