Anyone in ever had water leaks in the Trunk
Old Dec 20, 2007 | 03:24 PM
maxx0831's Avatar
Hey Guys, Anyone ever had any water leaks in the trunk like wen its raining the first half of the of the trunk is wet but not the back part. Ever since its been raining so much my trunk has been getting soaked inside and i had to take out my woofer and amp. I check the rubber seal around the trunk and it seems fine. And whats funny abt it is the front part of th carpet is soaked but not the walls of the trunk or the trunk hood wen u lift it up.
Old Dec 20, 2007 | 03:37 PM
andrei3333's Avatar
pull the carpet back and look, check the sides anyways, the carpet there doesnt touch the walls, look into the spare tire jack area, and on the opposite side
i had this happen on another car and the fix will probly not apply here since you dont know where its coming from yet
Old Dec 20, 2007 | 03:38 PM
kzoosho's Avatar
Mine leaks bad . but i just move stuff to keep it from getting wet lol.
Old Dec 20, 2007 | 03:46 PM
matty's Avatar
Only real way to fix the problem is to take everything out of your trunk, including your spare and dry it completely. Then with someone INSIDE the trunk with a flashlight, wet down the outside really well with a constant stream of water. *NO NOZZLE*
Mark the spot or spots, and fix the leak. Its most likely one of your tailights which is an easy fix
-matt
maxx0831's Avatar
lol, damn it im just thinking of using silicone and jus go crazy everywhere
Old Dec 20, 2007 | 03:50 PM
matty's Avatar
NO dont do that. You will make it worse. Do what I said and it will be gone forever.
If you just start putting silicone everywhere you will not fix the leak. You need to find it first, then take off whats leaking, clean BOTH areas, and silicone it up
This is same way body shops do it.
-matt
Old Dec 20, 2007 | 03:53 PM
kzoosho's Avatar
A lil water wont hurt lol.
maxx0831's Avatar
-matt
alright thanks i will give it a try. Wut to use if i find the leakage?
Old Dec 20, 2007 | 03:55 PM
matty's Avatar
Go to a local auto parts store. They will tell what stuff you should use.
Old Dec 20, 2007 | 03:56 PM
maxx0831's Avatar
alright thanks alot matty and everyone else
REDinLV
Aug 15, 2024 12:30 AM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
